Question about Toshiba DKT3020SD Corded Phone
Reset phone seems to be frozen and the counter keeps going like the phone line is in use
Water dispenser not working ice maker okay water line to valves okay appears line in door frozen
GE has a fix for frozen water line in freezer door. WR49x10173 is a heater kit that is installed in the dispenser area. It uses a minor amount of energy, but enough to keep the area warm. You have to pull off the dispenser board, remove the 4 screws to remove the dispenser cradle and unplug the wiring. Then follow instructions to crimp on the heater wires. Allow about 3 days for frozen water line to defrost. .
Jul 15, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
I changed the drum and there's still a message saying order drum....is there a way to reset that?
(from Okidata's support site)
After replacing the image drum cartridge, reset the drum counter to keep a correct count of the number of pages printed on the image drum.
1. Turn the printer on while holding the MENU 1/Menu 2 button. USERMNT displays in the control panel window.
2. Press MENU 1/Menu 2 three times. DRUM CNT RESET displays.
3. Press ENTER. The counter will reset and the printer will go ON-LINE.
Jun 30, 2010 | OKI Electric Industry B4600 Laser Printer
I've changed the black ink cartridge and it still says the ink is running low. I've done all the clean ups and everything seems oka
you have to reset it and the counter also ..if it do not have a separate reset for the drum and counter and ink level ..just reset it general...and should work ...if it has a reset button keep it pressed for about 10 seconds ..if not ..power of ..remove the cord..from plug ..than plug the power cord...and when you power it on keep the power button pressed..this should reset it ..
if not ..look in the manual for more exact ways to reset it or the counter ..
Apr 20, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
We did a reset on the phone now it is frozen
Sometimes, the iPhone 3G gets so frozen that the standard force quite process for program doesn’t work. In that case, you’ll need to reset the iPhone.
To do that, hold both the sleep/wake and Home buttons together for at least 10 seconds.
The red shut down slider will show up at the top of the screen and then disappear. Keep holding the buttons. The screen may even go black, but don’t let go of the buttons until the Apple logo shows up. When it appears, let the buttons go and the phone will start up normally.
Mar 06, 2010 | Apple iPhone 3G
Says to change drum, changed drum and still says "change drum", will not print.....
Dec 16, 2009 | OKI Electric Industry B4600 Laser Printer
Screen frozen at at&t logo, keeps restarting
try soft reset on the phone by removing and re-inserting the battery after one minute.
Jun 28, 2009 | Samsung Propel A767 Cell Phone
Frozen touch pad
I had the similar problem. Found this suggestion on the web to reset iPhone 3G to it's original settings. You may have to restore your media and data files after resetting. It's the only way out for me since I can't get beyond the "Apple Logo" thingy, and I am too lazy to bring it down to the Apple Store.
Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Thank
Good luck.
Oct 15, 2008 | Apple iPhone Smartphone
Visual panel seems to be frozen with 43 seconds showing. The vent keeps opening and closing....No way to turn it off! Very heavy to lift out and unplug.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Apr 22, 2008 | Microwave Ovens
Nokia n95
You could try this, it worked on my N95. But not on my mates. So it's up to you, this will reset the phone, or not, but whichever way it won't damage it.
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know, you need someone to press the ON button.
Mar 11, 2008 | Nokia N95 Cellular Phone
Minolta Error code C0500
1. Test Mode Operations
• The Test Mode is performed from the copier’s Tech. Rep. Mode.
1-1. Entering the Tech. Rep. Mode
1. Press the Utility key.
2. Touch [Total Check].
3. Press the following keys in order: Stop → 0 → 0
→ Stop → 0 → 1.
NOTE
Be sure to keep the display procedure for the Tech.
Rep. Mode from any unauthorized persons not
involved with service operations.
4344S504CA
link to a service manual that explains tech mode
Dec 02, 2007 | Konica Minolta DiALTA Di200 Copier
Toshiba DKT3020SD Corded Phone Logo
19 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
