Question about Continental Refrigerators
Replace refrigerator door handle - Continental Refrigerators
  • Continental Master
  • 17,164 Answers
What is the make and model number? What happened to the old one?
Posted on Jul 10, 2013
Handles loose on Frigidaire fridge doors
Jeff, If you can not see any visible screws, look for molded removable trim caps on the handle, remove and tighten screws. If no trim caps then your handle is probably mounted to fridge with screws in slotted slide, which get slid off by pulling straight up on handle, normally takes a lot of force to slide up and out. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix loose Refrigerator Handle
How To Fix Your GE Refrigerator Handle by removing the cap and tightening...
Refrigerator Door Handle How To Replace
Refrigerator Repair Replacing the Door Handle Frigidaire Part 218428101
Jul 10, 2016 | Frigidaire Refrigerators
How do I do fix the handle of my Matag refrigerator #M1TXEMMW803. It is loose on the bottom.
Maytag Repair - YouTube
? 2:17
https://www.youtube.com/watch?v=KcPy_PWb_Iw
Aug 27, 2013 - Uploaded by hpaiz69
Maytag Side by Side Loose Door Handle Repair. ... RefrigeratorDiagnostic & Repair - Not cooling ...
LG Refrigerator Repair (Part #AED37133117) - YouTube
? 1:01
https://www.youtube.com/watch?v=BXupc6y_wgw
Jul 9, 2013 - Uploaded by RepairClinic.com
The most common reason for replacing the handle is when it . ...Fridge Freezer Door Handle Replacement ...
How to fix a loose Refrigerator Handle - YouTube
? 0:30
https://www.youtube.com/watch?v=4IO60zkMXpw
Dec 12, 2013 - Uploaded by Charles Joyner
How to fix a loose Refrigerator Handle .... Refrigerator Repair - Door & handle, Amana , Whirlpool, Maytag ...
Jan 05, 2016 | Cars & Trucks
Remove door handles
Search Results
    Refrigerator Door Handle - How To Replace - YouTube
    ? 2:54
    https://www.youtube.com/watch?v=O5q0WhxMfmQ
    Sep 17, 2012 - Uploaded by AppliancePartsPros
    Follow these simple step-by-step instructions to replace theRefrigerator Door Handle on Whirlpool, Maytag ...
    How to remove or take off Whirlpool fridge door handles ...
    ? 2:22
    https://www.youtube.com/watch?v=tmYz4FVqVnw
    Oct 3, 2014 - Uploaded by way22good1
    How to take off whirlpool refrigerator door handles. ... How To Fix Your GE Refrigerator Handle by removing ...
    Whirlpool Refridgerator Door Handle removal - You
Dec 20, 2015 | Refrigerators
How do i replace the freezer door handle on samsung rf263
Usually you have to remove all the screws around the inside door panel...which are behind the door gasket, and throug the inside door panel...
May 25, 2014 | Samsung RF265AA Bottom Freezer French Door...
Replace dooor handle side by side kenmore coldspot 10656833602
There is a cover on the handle. Remove with a screwdriver by gently prying...careful not to break the plastic clips. Once removed, unscrew the main handle & replace.
Dec 17, 2013 | Kenmore 18.3 cu. ft. Top Freezer...
How do you replace a door latch on a Dometic RM2652 fridge?
Remove the two screws holding the latch/handle assembly on. With the door open, roll the handle outward toward the edge of the door. Then install the new handle assembly.
Aug 31, 2013 | Dometic RM2652 Refrigerator
GB2FHGXB01
Are you sure of the model number? I don't see a Whirlpool GB2FHGXB01 ; I do see a model GB2FHDXWB01.
For this model, there are several different door handles. One has a Philips head screw hidden under a trim piece. To expose the screw firmly push the trim away from the center of the handle. (This is for a standard Whirlpool fridge door handle.)
The French door style refrigerators have slightly different door handles. One uses Allen screws as set screws to secure the handle. (This screw needs a 3/32" Allen screw (hex key) and you can access it through a small hole in the underside of the handle on the loose side.) Be careful not to overtighten the screw or you may strip the threads and have to replace parts.
The other option has the handle mounted on brackets on the door. To access the bracket, grasp the freezer handle and pull it to the left. Then pull the handle away from the refrigerator.
For pictures of the handles, see pages 9 and 10 of the manual. It's available here: https://www.whirlpool.com/digitalassets/MLPDF/User%20Instructions%20-%20W10366204.pdf .
I hope this helps. If you do have the GB2FHGXB01, check if any of these directions help. Most refrigerators use one of the above door handle designs.
Apr 28, 2012 | Whirlpool GB2SHDXP Bottom Freezer...
I have a new door to replace the right side one on this refrigerator but for the life of me I can't get the door handle off the old one. New one didn't come w/ the handles/hinges, etc, obviously. The...
Are you sure...
To move refrigerator through a house door, it may be necessary to remove the refrigerator door handles.
NOTE: Handle appearance may vary from illustrations on this page.
1. Removing Refrigerator Handle
• Grasp the handle tightly with both hands and slide the handle up (1)(this may require some force).
• The keyhole slots (2) on the back of the handle allow the handle to separate from the mounting screws (3).
CAUTION: The handle could be damaged if you hit it with a hammer while removing or attaching.
CAUTION: When you assemble or disassemble handle, you must push or pull with reasonable force.
Jan 21, 2011 | Refrigerators
The handle on my refrigerator door (Admiral side by side model LSD2615HEZ) is loose. How do you tighten the handle?
There is a plastic card that came with the refrigerator. Pull the handle towards you and slide the card between the door and handle on the top side of the lower handle. Slide the card until it stops, I believe its 11/16". Next slide the handle upward to release it. It may take some force to release the handle. Once its removed, you will see a bracket on the handle. In my case, the screws were loose. Tighten the screws and replace the handle and its fixed. To reinstall the handle, line up the handle with the brackets on the door. Slide down until you here a click that indicates that the handle is installed properly.
Dec 30, 2009 | Refrigerators
Refrigerators Logo
42 people viewed this question
Top Continental Refrigerators Experts
John Tripp
John Tripp
Tom Chichester
Are you a Continental Refrigerator Expert? Answer questions, earn points and help others
