Question about Garden
Tecumseh Engine Valves
My Tecumseh 6.5 hp LV195XA has excessive valve clearance, how do I know if it's the valve or tappets that need replaced and is it even worth it? I'm do this job for someone. I think with the condition of the oil, I'll find more internal damage It's a self-propelled lot of work to take apart.
  • Eugene Smith Jul 12, 2013
    When I say excessive valve clearance I'm get a reading over 0.010, the setting is 4-8 thousance. would it be the valve stem wore down or the lifters, or maybe the cam?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
Ask your how old is it how long will it last best replace the moter aslong as the rest of the machine is in good shape i would do the cheaper than buying a selfpropelled and you no what you got make sure to go trough the machine put down parts it needs add them to the new motor half rebuild it
Posted on Jun 07, 2014
How do I fix the tapping sound from the engine when i accelerate after it has reached running temperature
Adjust the valve tappets (yes, they 'tap') AKA Rockers or find out why the hydraulic self adjusting tappets don't work?
They transfer the downward motion of the cams on the camshaft to depress the valves. There is a thin clearance of about 8 thousandths of an inch with the engine cold. As the engine heats the clearance reduces. Over tightening causes the valve edges to burn, too much clearance causes tapping.
Manual tappets get quieter usually as the engine heats. Hydraulic tappets gets worse as the engine heats as the oil thins.
Oct 03, 2015 | Cars & Trucks
Timing belt problems
IF the belt slipped or broke there may be damage. to check for valve damage remove valve tappet cover and check valve clearance ,if the clearance is excessive there is damage . bent valves and damaged pistons .
Jul 03, 2014 | Holden Astra Cars & Trucks
I have problem with my engine 4K toyota. It heard an engine noise during idling, for my little knowledge in engine repair, can you give me any procedure mannuals in adjusting engine valves for my...
Valve Clearance Valve clearance is there to allow the valves to cool in between combustion events (spark), and to make sure the valve closes properly and contains the combustion explosion. You need to cool the valves a little bit, the exhaust valve moreso than the inlet, as it's what sees the most heat as spent burnt gases go past it into the exhaust port. Run too little clearance and you'll cause the valve to "weld" a little bit to its' seat every time it closes, and then take seat metal off again when it opens. Do this enough times and you burn out the valve seat and need the head reconditioned. However, by running less clearance, the valve stays open for that little but longer, and you get more air in and out of the motor, and make more power. Run too much clearance and your motor just sounds like a diesel and loses power and tappet rattle annoys you while you're driving, so it's better to err on the side of caution.
The stock valve clearance (0.008" inlet / 0.012" exhaust, warm) is pretty good for any of the cams I've listed above, they're well-sized street cams, not really wild top heavy race cams that require super high compression to work, so don't be afraid to close the valves up a bit from the suggestions of the cam grinder, which will usually say between 0.010" and 0.014". There are a few ways to set your valve clearances:
Yellow Book Method This is from the factory 3K/4K/5K engine manual, aka The Yellow Books. It's the quick and lazy method.
Set engine to #1 TDC. Crank pulley timing mark should be on 0, distributor rotor should be pointing towards spark plug 1 or 2. Set tappets (counting from the front) 1, 2, 3 and 5. Rotate engine 360 degrees, crank pulley to 0 again, distributor rotor turned 180 degrees. Set tappets 4, 6, 7 and 8.
Nine Method I've never really gotten into doing this, takes too much time and maths for my liking :P Rotate the engine through its' range of movement, as one valve is "on the rock" of its' max lift, subtract the valve number from 9 and that's the tappet you should be setting. For example, if #8 valve is open, set clearance on valve #1. If valve #7 is open, set clearance on #2. And so on.
Stewart uses this method, and rotates the camshaft through its entire base circle and sets the clearance at the highest point. Which is a pretty good idea, as it compensates for the possibility that the base circle has been ground unevenly, and allows you to run the proper valve clearance that you want to run, instead of something that may be a few thou larger in reality.
Feb 10, 2011 | Toyota Corolla Cars & Trucks
Find tdc and adjust valves on a 325 i
With the tappet cover off, rotate the engine in the normal direction of rotation until you see #4 cylinder valves rock - open/close in succession. This will be TDC on #1 - set the valve clearances. Turn the engine until your see #2 valves rock, set #5 valves, turn the engine till #6 valves rock, set # 3 valves, turn the engine until #3 valves rock, set # 6 valves, turn engine till #5 valves rock, set # 2 valves, turn engine till #1 valves rock, set # 4 valves. Once you have located #1 TDC (the second mark in the pulley should be lined up with the cover mark), it is only 60 deg. to get to the next cylinder to set. If you accidentally go past the setting point, go back and approach the setting point again in the direction of engine rotation. When you come to setting # 6 the TDC marks should be aligned again.
Jan 29, 2011 | 2003 BMW 325
I have H.Activa 2005 model.After getting it serviced ,abnormal sounds started coming from the engine.Even pick up is also poor.I think the abnormal sounds are coming from the valves.Could anyone please...
The piston must be at Top Dead Centre to adjust the valve tappet clearances. This will only stop it from ticking. Have you checked the type of and amount of oil in the engine?
Hope that helps.
Dec 27, 2010 | 2005 Honda Activa
I have a Tecumseh 12.5 hp vertical ohv engine Model OV358EA (OHV110-135) The rocker has come loose, pushrod jumped out and stopped engine. I need to reset valve clearances, I have no manual to give me...
My 13.5hp ov358ea is .004 both valves. Would like to know model of your engine. I want to replace the non-adjustable carburetor of my 13.5hp ov358ea with an adjustable carburetor.
Retired Airline Mechanic
Jun 26, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Valves "Unadjustable" 2004 Dl-650
If the valves were bent, the engine wouldn't run worth a darn, if at all. What I suspect is that the exhaust valves have sank their way into their seats and are now positioned too far upward in the cylinder head to attain adequate tappet clearance. Exhaust valves have more of a tendency to do this because of their high thermal loading during operation. Then, as the engine continues to be operated - and the tappet clearance diminishes, the valves run even hotter, causing damage to the valve and seat ares.
So, to answer your question; yes, the previous owner did neglect it - by failing to keep the valve tappet clearances set correctly.
The only cure for this, sadly, would be to remove the head and replace the exhaust valves and recondition the cylinder head's valve seats. Of course it may turn out that the cylinder head valve seats are worn beyond repair, requiring a new cylinder head.
Nov 01, 2009 | 2004 Suzuki DL 650 V-Strom
Top-end rattling after it heats up, assume its piston slap. Is it time for rebuild? Do you recommend to rebuild head as well (valves and seats)?
First, let's assume that the valve tappet clearances are set correctly and the cam chain is properly tensioned. This will eliminate these as possible sources of excess mechanical engine noise.
If the noise is, in fact, 'piston slap' - then a teardown and inspection of the top end is called for. And yes, in addition to resolving a worn piston and cylinder bore, it would be an ideal time to examine the valve train for needed service. At a minimum, remove the valves and clean all carbon from them and the cylinder head and ports. Check for excess valve-to-guide clearances and pitted or worn valve seats. Usually, these engines are just fine with a cleaning of the parts and a re-lap of the valve seats. Replace all the gaskets and valve guide seals - and you should be ready to rock and roll.
Oct 27, 2009 | 2005 Honda CRF 450 R
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
