Question about Vehicle Parts & Accessories
Fleetwood rv manuals
Looking for the circuit breaker location
  • 219 Answers
SOURCE: machine wont drain or spin the manual says to check hoses and
just unplug it to try and reset it. should show some code
Posted on Mar 31, 2009
VtToolMan
  • 704 Answers
SOURCE: RV Air Conditioner Keeps Tripping Circuit Breaker & Compressor
It sounds like the unit was miswired at the factory, since when the A/C is "off" at the thermostat, there should be no calls for cooling or for the fan to run.
You also stated the most puzzling issue, with the breaker turned "off" the same thing happens. This shouldn't happen at all, when the power breaker is turned off, there should be no power being supplied to the unit and it shouldn't be able to do anything. Very strange indeed, but likely a major error done when the RV was manufactured, or some wiring in the loom has somehow become shorted and is supplying power from another breaker/source.
I think a call to the manufacturer is in order since there is no easy solution aside from possibly rewiring the A/C circuit.
Not sure when your RV was made, but definately time to call the manufacturer and break out the wiring schematic in an attempt to isolate and resolve the problem.
Hope you find this helpful and best regards!
Posted on Aug 06, 2009
class_of_200
  • 26 Answers
SOURCE: onan genset generator in rv is running but no
on your generator ther is a reset if thats not it check for fuses if still no then u neda check the wires in the pluges if no then ur generator it self needs re bilt
Posted on Aug 29, 2009
motor1258
  • 6674 Answers
SOURCE: AC runs for 5 minutes and then circuit breaker
What else do you have running on hydro while AC is running? Such as coffee maker, microwave, water heater, fridge. That 30 amp breaker is your main breaker I assume, or breaker on pole your plugged in to. Keep in mind your AC will normally draw approx. 15-17+ amps momentarily when compressor kicks in to cool, then drop back to 12-15 amps when running normal. If your AC is drawing too much current, then you would only normally trip 20 amp breaker for AC in your panel. Try switching other appliances to gas operation while running AC, such as water heater, and fridge. Make sure incoming voltage is up to specs as well . (115-120 volts)
If water heater takes 5-8 amps, and fridge takes same when they are calling for power, you'll be close or over the 20amp mark when you consider your on board converter etc. as well. That only leaves approx 10 amps for AC that requires approx 15 amps to run, and up to 20amps when compressor kicks in. If you switch all those other items over to propane, and it still happens, then a current draw test should be done on AC unit to see if perhaps a capacitor is faulty, or possible compressor faulty.
Posted on Jul 25, 2010
SOURCE: Circuit breaker location
I have 2004 1/2 700 sportsman that had the same problem. The circuit breaker is in front of the handle bar, under the plastic cover. you will have to remove front luggage rack if you have one. Look at the wire harness and locate a plastic sealed rectangular holder about 3 inches long. It is automaticly reset when it cools down.
I kept having power loss that could be restored by tapping on the plastic holder.
I cut it open and found the connections corroded on the 20 amp circuit breaker inside. Seal plastic up if you cut it open to keep it from shorting out and to keep moisture out.
Posted on Mar 18, 2012
None of the recepticals in my RV have power. every thing else works. 1994 ford F350 Fleetwood tioga
find your 110 circuit breakers. reset. if it will not. its blown need replacement, just like a homes breakers. just pull out and replace
May 10, 2017 | RVs
Circuit 329 location in 2008 fleetwood excursion big slide wont open
notify an rv center service dept or fleetwood service for assistance
Dec 21, 2016 | Cars & Trucks
Looking for Owners Manual of 32' Fleetwood Terra Motorhome.
Carl, could not find much on this one, maybe contact fleetwood through the links below. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Fleetwood RV Parts and Service
http://www.fleetwoodrv.com/library
http://fleetwoodrv.com/partsandservice/manuals/2007_fiesta_terra.pdf
http://www.oconnorrv.com/brochures/fleetwood/2007_terra_lx_bro.pdf
Apr 18, 2016 | Cars & Trucks
Manual for 2006 FLEETWOOD prowler camper
Even though Fleetwood no longer manufactures Travel Trailers you may still want to call Fleetwood RV Owner Relations at 1-800-322-8216 and see if they can help you out with locating a manual.
You could also try ebay and see if anyone is selling a manual.
You could try facebook for an rv community.
or try this link
http://www.rvingthemidwestconnection.com/manuals1990newer.htm
Oct 23, 2015 | Cars & Trucks
I have a 1979 Southwind Fleetwood RV I need to replace the circuit breakers and or fuses located in the rear circuit breaker box unit.is there a difference between RV and home circuit breakers?
It could be if your breakerwhen you remove it says 120 volt or 240 volt than no same but if it is saying DC volts than yes different should say what it is on side of breaker or on in side of breaker box door I would think age of rv mostly 120volts
Feb 22, 2015 | Heating & Cooling
Where to find the fuse block location in our RV92 Fleetwood Bounder
it is accessible from the top of the dash. The left panel is secured with velcro and should just pull up.
__________________
Apr 03, 2014 | Rv Motorhome Dual Co & Lp Gas Alarm...
FURNACE WON'T TURN ON: I have a 1999 Fleetwood, Prowler RV. The furnace won't turn on.
Check the exhaust port of the furnace. Wasps like to build nests in there and it will not allow the furnace to ignite if blocked. You have a gas detector and it is turned on I assume? I forgot this many times.
Apr 20, 2013 | Heating & Cooling
Headlight fuse location
Headlights do not have fuses. They have circuit breakers (thermal cutoffs) ususally in the headlight switch. Headlight circuits aren't fused because once the fuse blows, you're out of luck. At least with a self-resetting breaker, when the circuit cools off, you again have light.
May 04, 2009 | Buick Regal Cars & Trucks
Roof top AC
sound like a electric short some where, other than themostat. most likely some where close to the motor or the motor itself.
Oct 31, 2008 | Dometic Rooftop RV Air Conditioner
Vehicle Parts & Accessories Logo
408 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
