Question about Refrigerators
Drainhole gets blocked with ice proline fridge freezer
Drainhole gets blocked with ice when fridge defrosts itself automatically.Have checked drain pipe to tray and water when poured into drainhole drains to bottom tray
  • Refrigerators Master
  • 16,181 Answers
Sounds like the defrost cycle is too short! What is the make and model number?
Posted on Jul 10, 2013
3 Suggested Answers
SOURCE: bosch fridge leaking water
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I have the same problem,warranty just ran out but its been leaking on and off for ages,must be this model.This much Ive figured out,what happens is the drain hole gets blocked from ice freezing over the hole at the back of freezer, the drain water has to go somewhere, since it cant leak out of the drain hole where it suppose to it ends up pooling under the vege compartment before ending up on the kitchen floor.Now if this is your only problem,someone suggested to me to run a piece of copper wire from the defrost heater to the drain hole so no ice can build up there,hence no more leakage.To do this you'll have to take the back panel off and see for yourself,I did this and Im a novice.Make sure you turn off and unplug the fridge first and wait for it to defrost.
Now I think I have other things wrong with mine,after leakage problem the refrigeration compartment wont cool anymore but the freezer part remains working as usual.Ive nailed this down to one of the following not working... Thermostat / timer / defrost heater.So one or more of these needs replacing.Im just trying to look for a manual which shows the nuts and bolts or the refrigerator (not the "How to use" type manual which I have).
Posted on Apr 05, 2009
heatman101
  • 43501 Answers
SOURCE: We had water draining into the fridge from the
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Feb 25, 2011
My Bosch KGU3420GB fridge freezer keeps getting a thick layer of ice in the bottom of the freezer which then 'welds' itself to the bottom freezer draw. Any idea how to fix this?
Sounds like the drain is blocked and defrost water is collecting in the base. Try a full defrost and check the drain hole clears.
Apr 23, 2012 | Refrigerators
I have an Electrolux Refrigerator FRT18B4AWA and it is leaking all over the floor. Temp holds good but the leaking won't stop. How to I fix it.
The most common cause is ice built up and plugged the drainhole as not defrosting Auto in time. Unplug the power de-ice. Locate the drain hole. Insert soft wire or cordto clear drain Open back of fridge. Locate drain tube and pan. And checkinserted wire or cord is coming out. Gently shake wires and pull out. That'sall. Now Drain tube is cleared. And also empty the drain pan, if water is huge to condensate.
Jan 28, 2011 | Frigidaire FRT18B4A Top Freezer...
I had leaking from the freezer. Cleaned the air intake and it was plugged with dust.Turned it back on and noticed more ice buildup at drainhole. The coils at the bottom of the freezer coils were red hot. I...
It sounds like your freezer was going through the automatic defrost cycle but the water couldn't go through the plugged drain. Clean the drain so the water can go out.
The refrigerator side gets cold by the cold air that comes from the freezer, so in order to have a cold refrigerator you need a cold freezer.
After you have cleaned the drain, turn all back to original settings.
Hope this helped, let me know.
Thank's for using Fix-Ya
Jan 10, 2011 | Refrigerators
There is ice built up on the freezer side. The ice is on the floor of the unit. How can I prevent this?
Behind the back wall of the freezer there is a defrost drainhole that is clogged. You will need to clear this drain so water from cols during defrost can drain to the pan by the compressor. Use a hair dryer and finish off with 1 cup very very very hot water to open completly . Hope this helps.
Feb 13, 2010 | Refrigerators
Water dripping from bottom of freezer casing
Your drain line is frozen. Ice thawed by the heater in the freezer normally drains down a tube into a pan on top of the compressor, where it evaporates from compressor heat. If the drain freezes the water runs into the freezer bottom instead of the tube then into your fridge. To solve this remove everything from your freezer and remove the access panel in the back or bottom depending on your model of fridge. Turn off or unplug the appliance. Upon removing the panel(s). you will likely see that the bottom of the freezer is full of ice. Use a hair dryer or heat gun to thaw ice and remove. In the very back bottom you will uncover the drainhole. I usually use very hot water and a shop vac to thaw the drain hole. When you finally clear it you will hear water running into the pan on top of the compressor. Somethimes it takes a lot of hot water to clear the drain. Hope this helps!
Jul 08, 2009 | GE Refrigerators
Drainhole location on my Whirlpool 2004 freezer top frig?
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Jan 23, 2009 | Whirlpool ET1FHTXM Top Freezer...
Ice collects in bottom of freezer
Heya Johnpc,
The best way to check the fan is to open the door and to push in the door switch wait about thirty seconds and you should be able to hear the fan run. If you cannot hear the fan the chances are you should call domestic refrigeration tech out.
Another thing that also makes water gather in the freezer is the freezer door seal is old and not sealing correctly.
Is the freezer working all right still?
Jan 08, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Water inside bottom of freezer after defrost cycle
Oct 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Fridge only cools to 55 deg F
check the bottom of Ref. see if it close right, sometimes the rubber near the bottom parts broken.
Jul 08, 2008 | KitchenAid KSRS25IL Side by Side...
Refrigerators Logo
219 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
