Question about Microwave Ovens
Ge spacemaker microwave oven
Keypad shorted service may be needed on display
    Top Expert:
  • Microwave Ovens Master
  • 12,223 Answers
You must open the keypad, disconnect the microwaves, and disconnect all connector, specially from the ribbon or plastic very carefully, use pencil erase and clean it from corrosidon and dirty, the contact clean it contact solver or use alcohol isopropyl to 100% and fix it.
God bless youGe spacemaker microwave oven - 16c6f291-8cef-4ebb-be28-ee64a68ed6ec.gif
Posted on Jul 10, 2013
  • Fernando Alvarado Jul 10, 2013
    Thank you!!! Good bless you... Now I have another problem though... Only certain Burtons respond like, clear/off, the number "1 and 6", add 30 sec., start/ pause, power level and other certain ones... What could out be??? Please and thank you...
  • 95 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Disassembly of GE JVM1460 microwave oven door to clean
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 10, 2008
vitg55
  • 70 Answers
SOURCE: My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
Posted on Dec 15, 2008
  • 4090 Answers
SOURCE: ge spacemaker microwave JVM1330BW002 making noise, food not warm
bad news I am afraid. the heart of the unit has had a coronary and needs a tech to intervene
Posted on Aug 01, 2009
Keyboard shortage
The keypad control board or smart board needs attention," membrane in keypad is shorted"
Mar 27, 2012 | GE Spacemaker 1.5 Cu. Ft. Over-the-Range...
Microwave keypad shorted
looks like your buying a board unfortunately not worth the repair get a new microwave boards cost way to much
Nov 14, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My keypad is also dead.
No, but as with all electronic items faulty ones typically show themselves up during the first few months of use.
You've probably just been one of the unlucky ones.
Sep 08, 2009 | GE Spacemaker JVM1540 Microwave Oven
GE JVM1540 keypad only works for some buttons
Membrane keypads are not very durable, and do fail after a relatively short time.
The only method is to replace them as a spare part.
Aug 20, 2009 | GE Spacemaker JVM1540 Microwave Oven
GE micowave, keypad will not work
GET THE OVEN NUMBER AND SEE HOW MUCH THE TOUCH PAD COST, SOME TIMES THE TOUCH PAD COSTS AS MUCH AS MICRWAVE OVENS NOW DAYS
Aug 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The keypad does not work. The display screen says "Press -----k". I'm assuming it's telling me to press clock to set time. But none of the keys work when I press any. Earlier only the Start/Pause key...
try powering down for 30 seconds. if that doesn't work the keypad is shorted or open. do not spray cleaner directly onto key pad when cleaning. it will short it out. rather spray cleaner onto a rag then wipe.
Jul 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave display is flashing. Keypad is unresponsive. Boiled water for a long time under the unit. Person attempted to operate microwave. Loud boom and then this. There is a smell of...
Microwave is 16 years old. Replaced it. Service call was going to be half the cost of a new one with no assurance that problem could be fixed once it was diagnosed.
Jan 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave f3 code
You have a shorted touch pad.. here is a link for a replacement.. http://www.pcappliancerepair.com/model-display.php
If you open up everything and examine the touch pad, you may see something that is causing the short and fix it, oherwise, you'll have to remove and replace it.. Hope this helps..
Sep 12, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave malfunction
On a GE microwave F3 means you have a failed keypad.
We replace these for customers nationwide with our guaranteed $39.95 service.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 29, 2006 | GE JVM1861SF Microwave Oven
Microwave Ovens Logo
954 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
