Question about Epson Stylus C84 InkJet Printer
Ink and paper lights flashing red and I cannot print
There appears to be a problem with the printer carriage parking station on my Epson Stylus C84 printer which is causing this problem and I wonder if there is a solution. When I turn on the printer, the cartridge holder moves to the left then back to the right and then stops. It does not go through the head cleaning process as it should do and once it has parked up, the paper and ink warning lights start to flash together and the power light goes out. The black ink cartridge needs replacing but this cannot be done as the flashing lights have taken control. I would be prepared to open up the printer to rectify the problem if necessary as the cost of paying for a repair would be uneconomic. Any ideas?
  • 3 more comments
  • deirdre wilkie Nov 10, 2007
    Thanks everyone for trying to help. Somehow and I don't know why, the printer corrected itself without my doing anything to it. However, since then the lights have started flashing again. I have another printer which I am using now but I will let an Epson registered repairer have a look at it. If it is not an economical repair then I will ditch the printer but you never know it might be something simple. Thanks again for the suggestions.
    Thanks to everyone who suggested solutions. The problem seemed to cure itself without intervention on my part but it has since returned. I have another printer which I am using now but will take the faulty one to a recognised Epson repairer for an opinion. If it is economical I will have it fixed but if not I will ditch the beast.
    Many thanks again.
  • albert newton Dec 14, 2007
    I have same problem . Red lights keepflashing and nothing works cannot remove ink cartrages. [email protected]
  • tmevansjr Dec 20, 2007
    When I turn on the printer, the cartridge cart (for lack of a better term) moves all the way to the left of the printer, smacks the edge and then moves back to it's original position. The red lights then begin flashing, and everything shuts down. Any ideas?
  • Anonymous Dec 20, 2007
    I have the same problem. I went through the little exercise on Epson's website and their conclusion was that I had a hardware problem. They helpfully emailed a list of service providers with the caveat that service was expensive and I might consider buying a new printer. Gee, thanks.
    I'm now websurfing to see if the C84 is still available so I can use the two sets of ink cartridges I still have.
    It's frustrating, but until the meltdown, this was a nifty little printer.
    Lewis
I have solved the problem, its a dodgey chip on a printer cartridge.
Cyan was the last cartridge i changed, so i guessed that was the one that was causing the problem.
Turn your printer on, when the printer carriage is returning - manually stop it from disappearing underneath the housing (normal stop point for changing the ink). Either replace all the ink, or do a process of elimination by just putting 1 cartridge in at a time and turning your printer off and on.
I hope that solves your problem.
Posted on Nov 10, 2007
The ink cartridge needs the cartridges put back in. one will be out of sink
Posted on Nov 05, 2007
    Sergeant:
  • 390 Answers
No body wants to take it to repairs, we all hate spending money if it can be avoideded. Do't fret. First, i would bet you have a paper jam that you have missed. This would stop the carriage and head cleaning. Open up the cover as if replacing ink. Get a torch and really thoroughly check for tiny paper jams or ujo's(unidentified jamming objects)check where paper goes too. Now close cover turn off, unplug, all cables, replug, turn on, try printing now. Post back if no good. Cheers lilacgerry
Posted on Aug 31, 2007
SOURCE:
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Ink and paper icons are alternately flashing
If you download SSC Srevice utility from the net (FREE) all you need to do is to reset all your counters and that should solve your problem.
Apr 06, 2009 | Epson Stylus C84 InkJet Printer
My printer epson r230 is not working. the two red light are blinking. is it my counter reset is end?
my printer epson r230 is not working. the two red light are blinking. is it my counter reset is end?
Mar 10, 2009 | Epson Stylus Photo R200 InkJet Printer
I just replaced all 4 ink cartridges on my epson stylus c84 printer. The 2 left buttons on the printer are flashing and it will not print. I have tried turning it off and then on but it still won't print....
See the on-line handbook
http://support.epson-europe.com/onlineguides/en/sc84/index.htm
and look in Problem Solver, Diagnosing the Problem, Error indicators. If the two lights are flashing together, you have a paper jam. If this is the case, you should be able to pull the paper out from the front or top. If the lights are flashing together, and you can't see any paper jamming the printer, post a new comment to this effect for more help.
If the lights are flashing alternately (Unknown printer error), it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you should change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back with a new comment and I will provide further help.
Mar 06, 2009 | Epson Stylus C84 InkJet Printer
Epson CX2900 problem
HI,
Try to reset it :
SSC Utility has the latest version SSC Utility 4.30... This time it can now reset the Epson Stylus CX2900...
Download the latest version and Install it...
Under Configuration...
Select Installed Printer (EPSON Stylus CX2900 Series)
Under Printer Model
Select EPSON Stylus CX2800...
I hope this will help you. Link
Aug 02, 2008 | Epson Stylus C84 InkJet Printer
Repairing
I have a epson stylus c65 printer. My printer is keep flashing the two red light. The out of paper and the out of ink. what do I have to do to stop the problem. The two red light is keep on flashing alternately
Jan 19, 2008 | Epson Stylus Photo R200 InkJet Printer
Flashing Red Lights
it means that some time you are using low quality ink
or the paper not loaded correctly
thank you
Jan 11, 2008 | Epson Stylus C84 InkJet Printer
Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
Epson Stylus C84 InkJet Printer Logo
273 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
