Question about Healthtrainer 701 Treadmill Walking Deck
Release latch broken
The release latch on my treadmill is broken and It is stuck in the upright position. suggestions on how to repair it would be appreciated.
    Top Expert:
  • Healthtrainer Master
  • 12,223 Answers
Is better to replace go to www. treadmilldoctor.com or
www.fitnessrepairparts.com and get it.
God bless you
Posted on Jul 11, 2013
2005 quattro , battery is dead and hood wont release.Is it an elecrtonic release?
Heidi, No electric release. The latch is probably stuck. While you pull the interior hood release have an assistant push down and pull up repeatably/vigorously until hood releases from stuck position. Lube latch and cable before closing hood. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Open Hood How To 2001 2005 Audi Allroad Quattro 2002 Audi Allroad Quattro...
2007 Audi A4 2 0t hood latch fix when you can pop the hood
Hood Latch Release Cable Broken How to open hood
Help Hood release cable disconnected somewhere any ideas how to open hood...
Apr 15, 2016 | 2005 Audi Allroad Quattro
Drivers seat won't latch
Will it latch if you push the release handle down, you know opposite of trying to get it to release? It might be a broken or dislodged retaining spring that pulls downward pressure on the release handle. If this is not the problem then the teeth on the gear that the release handle engage are possibly worn out.
Apr 22, 2013 | 1999 Toyota Camry Solara
Third row seat latchs are broken and seats stuck in upright possition
There is a plug (cap) that goes into the pivot point of the release handle for the third row seats. If that plug is missing, you can stick a penny in there temporarily to enable the release and fold the seats down. The replacement part is called a "release handle plug" -- I found it at moparpartsovestock.com, part number 1ED82BD1AA for under $4.
Jul 01, 2012 | 2006 Jeep Commander
My epic 425 mx treadmill doesn't fold properly.
1. Hold the upper end of the treadmill with your right hand
as shown. Using your left hand, pull the latch knob to the
left and hold it. Pivot the treadmill down until the frame is
past the latch pin. Slowly release the latch knob
I will strong that you see your owner manual. If you do not have manual.
here is the web page for you download free right now:
http://www.iconservice.com/CustomerService/manualsProductManuals.do?model=EPTL88105&modelName=EPIC+425+MX+
sincerely.Good luck.
Nov 22, 2011 | Epic 425 Mx Treadmill EPTL88105 !
2000 Jimmy- 3 problems- 1. Heater just blows cold air 2. Can't get the hood latch to release even when pulled all the way with vigor 3. Rear window wiper stuck in upright position and won't respond to...
The no heat problem could be a stuck open thermostat, plugged heater core, the air mix/mode actuator, or the control module. You might be able to have someone push down on the hood while pulling the hood release to get the hood open, the latches often stick, or the release cable maybe stretched and not operating the latch enough to release it. The rear wiper motor is probably bad.
Oct 23, 2010 | GMC Jimmy Cars & Trucks
The latch for the door on my '92 Corsica is stuck upright preventing me from closing the door. What can I do to get it open.
You should be able to pull the handle and while holding the handle use a screwdriver to pop the latch back to a "open" position. If the latch does not release then it might be broken and stuck in that position. Just use the screw driver and insert it into the latch opening to simulate the latch hook. The try moving it back while holding the handle open. Hopefully this gets the latch back into position. You should also lubricate the latch with a small amount of white grease to keep the latch from sticking.
Dec 29, 2009 | 1992 Chevrolet Corsica
Hood release under the dash has no tension on it. Hood will not latch closed
The latch is stuck in the open position. I always found white lithium grease worked best on those latches but any good lubricant will work. Try moving the latch manually with a screwdriver. After applying the lubricant move the latch a few times. You should see the tension return to the release, if it doesn't you have a broken release cable.
May 10, 2009 | 1988 Ford F 150
The foot release latch has broken or become unlatched on my uprig
I had this problem once before. The only thing I did was loosen the back 2 screws, take the release latch and just play with it until it catches, rea simple.
Mar 19, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Healthtrainer 701 Treadmill Walking Deck Logo
87 people viewed this question
Top Healthtrainer Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Healthtrainer Exercise and Fitnes Expert? Answer questions, earn points and help others
