Question about Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
Error code E6 on brother fax machine - Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
checkitright
  • 1362 Answers
SOURCE: error code fax
check this link and go to error codes/fax error
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
Posted on Nov 27, 2007
bowdo
  • 78 Answers
SOURCE: brother fax machine intellifax 2600
Fuser or overheat error it will probably be followed by a 77. Menu, mode and 0 quickly in that order will give access to user maintenace mode (lights will flash once your into the mode). Hit 91 to reset the machine. If this doesn't work you have a major problem with your fuser unit and it will need to be replaced. DO NOT DO THE ABOVE PROCEDURE MORE THAN ONCE AS YOU WILL START TO MELT STUFF IF THERE IS A MAJOR PROBLEM.
Posted on Feb 07, 2008
  • 47 Answers
SOURCE: Brother Fax 4750 System error 76
try resetting the machine by pushing the features button, and then *2864 in quick succesion, if done correctly you will enter test mode, then enter 91, and then after that clears enter 99 to exit test mode. make a copy to see if it works, and if it doesn't it is time to replace the fixing assy.
Posted on May 12, 2008
  • 215 Answers
SOURCE: change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Posted on Jan 28, 2009
  • 43 Answers
SOURCE: machine error 78
It means you need to replace the fuser. Depending on what model it is it may be cheaper to replace the fax.
Posted on Apr 20, 2009
Brother sewing machine nx250 error message E6
Search for:
Make Model error E6
https://www.google.com/search?q=Brother+sewing+machine+error+E6&ie=utf-8&oe=utf-8
Aug 25, 2017 | Brother Sewing Machines
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
Brother sewing machine screen displays E6
E6 is an error code. You didn't state the model number, but if you look in your instruction manual, it will list the error codes. If you don't have a manual, go to Brother.com and you can get the answer.
Oct 01, 2009 | Brother Sewing Machines
A9 ERROR CODE CAN NOT FAX
A9 is Brother's code "Abnormal scanning reference voltage"; try restarting the fax machine and trying again, or replace the scanner unit. (per Brother's website)
Jun 24, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
