Question about Refrigerators
Change thermostat on RM6401 electrolux fridge
We have bought a new thermostat for our 3 way caravan fridge, but it has a long coil coming from it, on the old one it disappears into the top of the fridge, seemingly into the freezer box, does it just push into the hole or does it connect to something
  • Refrigerators Master
  • 16,387 Answers
You have to take the unit apart to get to the coil in order to detach the old one and install the new one. There is liquid in the coil dont kink it.
Posted on Jul 10, 2013
Trifect7
  • 57 Answers
SOURCE: refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Posted on Mar 04, 2008
SOURCE: fridge freezer
there is a fan inside freezer behind back panel. if pipework behind panel is covered with ice, it will prevent air circulation and the fridge is affected first
take back panel off and check for ice build-up and that the fan is working
Posted on Jun 23, 2008
  • 61 Answers
SOURCE: Amana XRSS287BB side by side fridge freezer (3 years old)
you may try hard restart by shuting the fridge off and unplugging it from the wall . plug in back in and after 5 min turn it back on . close both doors and wait one hour . check the temp. if the unit still will not respond calll the local woranty amana repairman only. hope this helps you
Posted on Oct 20, 2008
BNewberry
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
  • 18 Answers
SOURCE: ZANUSSI ELECTROLUX -- FRIDGE (TOP HALF) NOT WORKING?
If ice is buiding up its usually due to the defrost system not working. There is a timer located at the rear to the right of the compressor which every so often turns on the defrost cycle. To check it , remove the plastic box and with a screwdriver turn the clock around until it clicks. This is then on the defrost cycle. After a short time water should start to drip out onto the top of the compressor. If it does not , the heater may be faulty. If it fails to stop defrosting and move back to freezing , the timer is faulty.
Posted on Jan 01, 2009
I am having to replace the 230v 135w heater unit in my Electrolux RM6401 fridge in my motorhome. There are two brown wires from the unit along with 1 earth wire. One of the brown wires has a larger plastic...
The small and large spade connectors are keyed to corresponding connectors on the switches. Although you can jam a small spade connector into a large spade connector, you should try to match large to large, small to small. This may be an oversimplification of your wiring problem.
Jun 24, 2016 | RVs
Hi, we have a caravan which has an electrolux RM360 gas/electric fridge installed. There is a very weird smell coming out when the fridge is turned on. Its like an ammonia smell it is really strong,
Travel refrigerators use an ammonia coolant instead of freon. So the smell is telling you that you have a leak in the sealed system.
Suggest you look for a replacement fridge OR a rebuilt unit because that is usually cheaper than taking it to a service center for repairs.
Jan 25, 2012 | Electrolux Refrigerators
The f/f does not get cold enough and there are long intervals when the motor doesn't run . Is this because the machine needs a new thermostat and is there an overide on the compressor . if it rquires a...
hi change the stat assy...this should cure your prob.....yes it comes out of light section...************ TURN FRIDGE OFF AND REMOVE PLUG FROM WALL BEFORE REMOVING ANY PANELS**********
Dec 30, 2009 | Electrolux Refrigerators
Our caravan fridge electrolux rm4206 gets cold on both gas and 240v mains but does not seem cold enough ie freezer compartment is not quite frozen and fridge compartment is not cold enough. Any...
remove the fridge from caravan, now turn upside down and leave for as long as possible. what this does is get rid of any air locks in the gas. once left for a month or too turn back and leave for a day to setal and refit to caravan.this should solve your problem, it has been tried and tested on our caravan and worked. (This will not work on a domestic house fridge because they work on a different system)
Aug 27, 2008 | Electrolux Refrigerators
Electrolux RM 4270 caravan fridge
Thankyou for your assistance, but i found the solution with electrolux direct.
Hope to use your site again sometime.
Aug 04, 2008 | Refrigerators
We have caravan electrolux rm 4230 light is on for 240 chilling, but fridge does not cool. appliance does however cool fine on gas.
Problem is either thermostat or heating element...not sure which yet..but found website supplying most usable parts for RM series fridges. Hope this link is of use.
http://www.leisureshopdirect.com
http://www.leisureshopdirect.com/caravan/ventilation/Dometic-Electrolux_Spares$$6.aspx
Jul 05, 2008 | Electrolux Refrigerators
Fridge prolems Electrolux ERE 3500
Disconnect the power cord (or switched power off) and wait an hour or two until compressor has cooled. When you now switch the power on, the clicking is heard only once and compressor starts (weak noice and vibration noticed). When compressor gets warmed, the compressor will stop and clicking starts again (clicking comes from electric circuits when compressor is switched off and on repeatedly, but it will not start because it has stucked - this is typical fault in old compressors said maintenance expert to me). Buy a new fridge.
Mar 29, 2008 | Refrigerators
Fridge not working
Fridge is not working then don't worry we will be here to help you.Just dial Dialfix.in number. Refrigerator Repair Services in Hyderabad DialFix
Aug 13, 2007 | Electrolux ER7926B Bottom Freezer...
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
