Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
MM875 electric lawnmower
The lawn mower stopped completely during a mow. Smelled of burnt metal. Is there a fuse that can be accessed easily or is it something else that has gone wrong.
  • 1 more comment
  • jrotten Nov 04, 2007
    mower stopped running, is there a fuse or restart button?
  • DeBrute Ruhl Apr 16, 2008
    causes breaker to flip power off when you pull the start cable??? any help?
  • 123peds Mar 02, 2009
    During a mow with long grass, blades seized up, motor stopped. Won't start again, even after cleared the grass from the blades
    Champion:
  • 313 Answers
Check motor if armature are not broken & see if the rectifier not burnt. rectifier works from ac & convert it to dc to run the motor.
if you need diagram for parts see toolpartsdirect.com
Posted on May 31, 2008
The lawn mower starts, then cuts and the motor produce smoke.
Posted on Feb 20, 2009
6ya staff
SOURCE:
Lawn mower just stopped during mowing, there is no spark. what do we need to do to get a spark please
there is a wire connected to the carby at the end of the throttle cable
that wire makes contact with the throttle plate when the engine stop is required
if that wire has fallen of or burnt through or touching the plate it will stop the engine and there will be no spark
Oct 01, 2016 | Garden
Why doe a fuse on a yth2348 law mower keep blowing
1) Something is shorting before completing the circuit. Look for any bear wires that may be touching the metal of machine, nicks or burnt spots on wires. 2) Overload on ampherage. For more information you might try visiting the Lawnmower World Forum. They have a lot of helpful ideas and more experienced people.
Jun 08, 2014 | Briggs & Stratton Briggs Stratton...
My lawnmower stopped
Check the oil. I bet you seized the engine.
May 18, 2014 | Honda HRC216HXA Commercial Lawnmower
Bits of burnt stuff coming out of lawn mower
that was burnt carbon coming out and you did overwork that lawn mower not dangerouse but keep mowing long grass you will end up buy anew one soon
Dec 04, 2011 | Briggs & Stratton Briggs Stratton...
I tried to mow the grass even though it rained this am. our grass was really high and i saw a little smoke come out of the lawnmower. is that because the grass was still a little wet or the grass was...
Nope. If the grass is too high, knock it down to size with a weedeater first. These electric mowers cannot handle the tall, high stuff. If you do, you will surely burn it up.
Aug 14, 2011 | Black & Decker 18", 6.5a Electric Mower
Shaft turns while trying to remove blade on B&D MM875 elec. mower
Here's the scoop on the MM875: it has a plastic piece called a "blade insulator" (part # 241381-01) that "locks" the shaft to the blade, so that you can remove the nut by stopping or blocking the blade. If it has been damaged or stripped out, then stopping the blade won't do anything. However, the metal spacer directly under the nut IS still locked to the shaft (because of its shape), so you can use a pipe wrench or something to hold that in place and unscrew the nut. You might even be able to get someone in a home improvement store to do this for you. But you will still need to replace the insulator, which is only a few dollars.
Jul 22, 2010 | Black & Decker 19" Electric Lawnhog...
Electric Lawnmower stopped working.
You were NO help at all. I asked for a location to have an electric lawnmower repaired in my area. You gave me a source 2500 miles away. Obviously I cannot count on assistance through this site. What happened to REAL PEOPLE who can offer some intelligent reply? If I could repair a lawnmower, why would I need to ask you?
Dec 02, 2009 | Black & Decker Garden
AS I WAS MOWING THE LAWN I SMELLED A ELECTRICAL BURN. THE LAWN MOWER DIED. I REPLACED THE SELONOID. WHAT NEXT TO TROUBLESHHOT. HELP
Does it crank over at all? I would look at all the fuses, and check the wiring going from the battery to the starter. Also check the key switch for corrosion.
Sep 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
1,077 people viewed this question
Top Black & Decker Garden Experts
gggg
Nick Olsen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
