Proview monitor problems
Not sure what her (my Mom)computer is besides being a Compaq Presario and the monitor came with the computer. But never had a problem then one day the left side of screen is dark. What is wrong LED does not blow out like other lights.
  • 386 Answers
Hi Lori,
You're correct, LED's do not blow out like other lights, but they do go bad. It sounds like the left side LED has burned out.
You can try to hook it up to another computer and see if it does the same thing. If it's still dark, the moniitor needs to be replaced.
If it works on a different computer, reconnect it to your Moms computer and make sure that it is securely fastened to the video connector on the Motherboard, or Video Card if one has been installed. Also, check to see if it securely attached to the back of the monitor.
Hope this helps,
Please Rate
Thanks,
Gary
Posted on Jul 10, 2013
  • 349 Answers
SOURCE: Compaq Presario v5000 won't turn on
If the laptop posts: (power on self test) and you see stuff on the screen, no matter how short ,do the following:
if you have a bootable anti virus disc use it to check for any viruses , if not
try a recovery disc,
both will try to access the hard drive.
if they do not work,(nothing has changed) nothing comes on the screen.
laptop does not post:
remove the screw(s) holding the cover plate where the ram lives
remove the memory sticks, clean the gold edges with a pencil eraser both sides and re-insert them, (not an ink eraser as it will do damage)
swap them around if you have more than one,
if you only have one, borrow one from a friend or try the ram in your friends laptop ,if that's possible, or take the ram to your local pc shop and ask them to check it for you (they may or may not do that for you)
if you can establish that the ram is ok, and anti virus and recovery disc's do not work,then it is most likely, the motherboard has failed .
good luck with that and let me know how you get on.
Terry
Posted on Mar 29, 2008
SOURCE: Compaq Presario SR1000 desktop boot up problem
nothing to do with the ram ... this motherboard sometimes locks, ( dont ask me why) but if you take out the power cord for 5-10 minutes and then press and hold the front power button on the machine (about 10 seconds) it will reset the board. Plug in the power cord and the basic items, sound, video etc ( some usb devices tend to stop it booting to) boot into windows. Then add the rest of your usb devices ..
Posted on Dec 01, 2008
techniwiz
  • 275 Answers
SOURCE: Monitor goes blank after seeing XP during boot up.
did u replace the video card with the same kind of model ? i guess yes ... when system starts hit the f8 key and than go in to safe mode ... mouse wont work so use arrow on the keyboard .. and in the safe mode just log in to admin account if available or login to ur account and see if that still happens .. and if it doesnt ... remove the drivers for the graphic card from add and remove programs and restart the system and go in the normal mode and than install the drivers again ... and if the display disappears in the safe mode or u have install a different graphic card than ... reseat the memory cards and that should resolve the issue .... if that doesnt work out when the system starts hit f1 and stay on the BIOS screen for 30 mins if the system doesnt loose display than u need to reinstall OS ... that will surely work out ... the resolutions given above if u follow them correctly u will have a working system in no time
Posted on Feb 07, 2009
Oz1286
  • 31 Answers
SOURCE: Black Screen Compaq Presario
Do you see the BIOS splash screen or anything?
Try booting into safe mode by pressing F* as soon as you power on the computer. If the monitor works, then it is a bad driver. Roll back to a previous restore point, boot to last known good coonfiguration. Last Known good configuration is available from the same as the safe mode screen.
If this is helpful, please comment and rate. Have any other questions, please let me know.
Oz
Posted on Feb 12, 2010
joecoolvette
  • 5660 Answers
SOURCE: compaq presario S0000/8000 won't turn on. Green
No, I would approach it a different way, with the diagnostic LED's that are blinking.
Indication is that the Power Supply has a weak Voltage power rail. If you test the 12 Volt power rail, I think you'll find it's less than 11 Volts.
(11 to 13 is okay. Less than 11 requires a Power Supply replacement)
You can test with an economical multimeter, (Usually $5 to $12), or an economical power supply tester.
One example, http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5250576&CatId=5471
Or, you can substitute the power supply in the computer now, with a KNOWN to be Good, Compatible power supply, for a test unit.
[Compatible being:
1) Right size and shape of case. The cas is approximately 6 inches Long, 6 inches Wide, and 3-1/2 inches Tall.
It is an ATX style of Power Supply.
2.Has the correct power cables, and the correct amount of power cables. If there are more power cables than needed, they are tied up out of the way with zip ties ]
May sound a little far fetched, but I have known people to have computers with a KNOWN to be good Power Supply, that are sitting around, and no longer being used. The Power Supply is borrowed for a test unit.
Generally, the cause of computer failure can be attributed to the inside of the computer, and the inside of the Power Supply is dirty.
The Power Supply has two cooling components.
One being the Fan, the other are Heatsink's used inside the Power Supply.
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Once the cooling components are coated with gunk, the cooling capacity drops tremendously.
Heat = Wasted Energy
The more heat, the more the Power Supply strains to keep up with the call for power.
Eventually components inside the Power Supply fail, and the Power Supply fails.
The second cause of Power Supply failure is that it is a low quality unit, and low quality components are used inside.
Next are Power Surges, lightning strikes, and brownouts.
To summerize:
I believe you'll find you have a bad Power Supply.
If you wish to test it with a multimeter simply state in a Comment.
(Upper right of your page)
If you wish help in finding a replacement unit, also let me know.
Posted on Jun 29, 2010
Replace ribbon cable going lcd compaq presario screen
Please replace it with a brand new flex cable. Please post the "4 tiles miniature screen".
Feb 12, 2014 | Computers & Internet
My monitor has kicked into sleep mode and won't "wake up".
Unplug all the Cables from Compaq Presario 5103 CL and leave the Keyboard, mouse and monitor cable pluged in.
Now make sure the power cable of the monitor should be pluged in and the power cable of the tower should be pluged in.
Now to check if the montor is fine just unplug the video cable only which will show no input signal on the screen. If it shows this signal the monitor is fine. Plug back in the video cable.
If the monitor is going to sleep mode it might be possible that the old computer ( Compaq Presario 5103 CL ) is in stand by mode. hit any key on the keyboard and it should come back .
If it is not in the stand by mode then do one thing. Check the same monitor with the new computer. If it is working. Perfect ..!
Do one thing now ..!
Unplug all the cables from your old system and then press the power button for 30 sec and let it go. Now plug the keyboard, mouse and the monitor try again.
If it works Perfect. If not ..!
Then you need to open the tower and check on the processor FAN is it running..? If its not running you will not get the display as the fan is responsible for the display on the screen. Otherwise...!
Check the Tower possibly the Tower is not getting the power.
Try these steps and let me know If it works
May 04, 2010 | Compaq Presario 5000 PC Desktop
Yellow power light on HP SR1420NX
For reasons yet to be determined, your computer is not talking to your monitor.
This could be the monitor cable came loose from the tower (this is our favorite, because it is such an easy repair), or something on the motherboard (that is, anything) that is not functioning and preventing your computer from starting.
Unplug the connecting cable, and plug it back in again, making sure that it is seated properly.
Do you hear any sounds besides the fans? You should be able to hear the faint clicking of a hard drive starting up also. If you hear this, the problem is not in the computer, but in the communication to the monitor.
Good luck
tony
May 23, 2009 | HP Compaq Presario SR1420nx...
Heat problem in compaq presario cq45 207tu
hi there,
that's it fans make your power supply cool,make sure this is functional,beside check also your battery sometimes distorted battery easily heat up upon power on or upon charging,make sure
still capable of holding stored capacity.
Apr 13, 2009 | HP Compaq Presario SR1920NX PC Desktop
Dell Fx500 Monitor with Presario 4860 and Windows2000
Where did you get drivers when compaq does not have the drivers for win 2000. That usually means you lucky if it is working.
Sorry, no ideas, also win 2000 is not supported anymore.
Mar 29, 2009 | Compaq Presario 4860 (309000-003) PC...
Monitor takes a long time to come on.
blown capacitors on the power board replacmetn is recommended
Dec 03, 2008 | Computers & Internet
Cost to repair popped ic
Sounds like the vga on the board has gone wanky I would look for a replacement on ebay nothing really you can do with this besides replace the pcb board with the processor on it.
Aug 05, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Flat screen monitor
I would open the monitor and look for bad capacitors on the power board
May 27, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Connecting a monitor to a different modem
is there a vga port on the modem? if so make sure the inputs to the modem are wired correctly, just keep in mind the monitor is there for you to see the video not to create one.
Jan 06, 2008 | Proview PL926WBi 19" LCD Monitor
Proview 900w
this prob is memory is in monitor so contact sevice engg of proview
Dec 11, 2007 | Proview PL926WBi 19" LCD Monitor
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
