Question about Panasonic KXTGA939T - - Phone
I cannot get a dial tone or use the hand phone perhaps it is on mute how do I return to normal use
5 Suggested Answers
SOURCE: We have KX-TG6051 two hand
We unplugged the whole unit and phone jack -- then plugged it back in. It worked.
Posted on Jan 12, 2009
  • 270 Answers
SOURCE: no dial tone on hand set battery is new lights up
Make sure your connection to the phone jack is secure.
Use another wired phone to make sure connection is good to your phone.
Secure connection in back of phone, and plug it in. The base MUST have power to transmit the signal to the handset even if the handset has a fresh charge.
Although the handset is normally linked to the bases, check to make sure via the instructions. To determine if the base recognizes the handset, press the "LOCATE HANDSET" button.
If the hadset responds, the links is there.
Hope this helps
good luck and don't forget to vote!!!
Posted on Sep 27, 2010
SOURCE: 4 phones on a boat,model # KX-T7030 No Dial Tone
pdf.textfiles.com/manuals/.../Panasonic%20KX-T7030%20Reference%20Manual.pdf -
Above is a user manual, below is your reference manual.
http://www.scribd.com/mobile/documents/8790207
below is the circuit diagrams.
http://www.eserviceinfo.com/downloadsm/4832/Panasonic_KX-T7030.html
These phones all operate across pairs of wires. Usually the phones plug into a main box called a EMSS, (Electronic Modular Switching System) It has to be set up first, sort of "Programmed" before it will all work together. You need to also obtain the information on the EMSS unit, as this is the "Brains" of it all. The EMSS unit has a power connection, the phones generally do not. There must be wiring from the EMSS module out to each phone.
Once you sort that out, the phones should all simply work, when connected.
Posted on Nov 13, 2010
SOURCE: no dial tone, rings but cannot answer
Turn off the mains power at the base unit for a few seconds, then turn the power back on.
Posted on Mar 17, 2011
I not have manual for Uniden dect 6 cordless phone on my phone I can't get any dial tone,I think I pressed a button on the phone either mute, intercom or redial, how to reset phone
If you have no dial tone the problem is most likely the base station has failed, nothing you can do will kill the dial tone (no button you pushed etc.) except a failed base station.
Dec 19, 2016 | Uniden DECT 6.0 Cordless Phone
My phone dialtone is intermittent - how can I return it to normal. It was disengaged earlier and calls sent to mobile. The problem is now sorted but my landline phone is still intermittent.
Usually the dial tone Beep Beep Beep means that you have a voice mail. This is a service or feature that your phone company provides. Sometimes it just a matter of dialing your home number from your home phone and it will prompt you to listen to or erase your messages. If this is not the case, call your phone company and ask them about the feature.
Feb 03, 2015 | Lands Phones
M7310 Non-Stop Dial Tone
Intercom button/s provide dial tone when they are pressed. They are required to call other phones on your system.
Sounds like your button is stuck or issue with the motherboard.
Dec 17, 2012 | NorStar Meridian M7310 Phone
I keep a dial tone, even when I dial a phone number...can't make an outgoing phone...I keep getting the dial tone. can you please help?
1) make sure is the phone is working good
2) there are tone dial
3) see the steps before o.k see ,if there are another phone having the same problem. The problem is service provider.
4) eliminate any background noise., mute the cordless handset before dialing.
God bless you
Sep 26, 2012 | Lands Phones
How do I activate the handsfree mute button on Norstar M7310? When I push outside line, then handsfree, I get dial tone, but cannot dial outside number. When call is incoming, after answering, I cannot...
familirize with devices user manual whether has feature functions requested. Second, ascertain that device was least malfunctioning since acquired. normally, familirising with innovative devices makes expertise in functionality.
Jul 20, 2011 | NorStar Meridian M7310 Phone
Want to silent keypad when typing or dialing
Hi nanro346,
Editing the Normal - Message Profile 1.Touch >Settings > Sound Profile >Normal. •Touch the name field and not the radio button to the right. 2.Touch drop-down menu (upper-right of the screen) and selectMessage. 3.Touch the Message Alert Type field, select one of the following and touchSave: • Melody: the phone rings using the ring melody selected in the Ring tone menu. • Vibration: the phone vibrates 3 times. •Vibration & Melody: the phone vibrates and plays a melody simultaneously. • Mute: the phone is silent and does not play a melody or vibrate. 4.Touch the Message Alert Tone field, touch to select a ringtone and touchSave. 5.Touch the Message Alert Repetition pull-down and select one of the following options and touchSave: • Once: repeats the message alert once. • Periodic: repeats the message alert periodically. 6.Drag the Alert Tone Volume slider to the volume level you desire (range is 1-7). 7.Touch the Vibration Pattern field, then touch to select Vibration 1 - 3. 8.TouchSave to return to the Sound Profiles menu
Apr 29, 2011 | Samsung SGH-A877 Impression Cell Phone
Samsung SGH D900I- cannot turnoff keypad sound
The steps are outlined in the article below:
D900 FAQ – How do I disable or mute the keypad tone on my SGH-D900? admin March 6, 2009 --> Note: In order to disable the keypad tone, the Dialing Display Font Type must first be set to “Normal”
To change the dialing display font type follow the steps below:
  1. From the standby screen, press the left soft key for Menu
  2. Select Settings (9)
  3. Select Display Settings (3)
  4. Select Dialing Display (6)
  5. Select Font Type (1)
  6. Highlight either Normal or Theme, using the navigation keys
  7. Press the left soft key to Save the Dialing Display Font Type setting
To turn off the keypad tone follow the steps below:
  3. Select Sound Settings (4)
  4. Select Keypad Tone (2)
  5. Highlight Off, using the up navigation key
  6. Press the left soft key to Save the Keypad Tone setting
Aug 29, 2009 | Samsung SGH-D900 Cellular Phone
I need to find out how to return to a normal tone
There should be a button on the phone labeled 'tt/pulse'. The button should be moved to the 'tt-touch tone' position.
Apr 16, 2009 | Lands Phones
The phone will have a dial tone and call out but no sound on phone
Look if the VOIP321 speakers are not muted on your computer.
cheers
Mar 19, 2008 | Philips VOIP3212G/37
No dial tone at all!
I assume you put the battery in and charged it for 12 hrs. If everything is plugged in correctly then it's time to return the phone as it is defective. GE does not have a very good rep with phones.
Oct 29, 2007 | GE 25865 Cordless Phone
Panasonic KXTGA939T - - Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
