Question about Vehicle Parts & Accessories
Replace Rear passenger window - Vehicle Parts & Accessories
    New Friend:
  • 53 Answers
What vehicle? Usually all you need to do is remove the inside door panel then unbolt the window glass and remove the damaged window.
Posted on Jul 10, 2013
I have a 2008 GMC Acadia and the right rear power window will not go up, it will go down, any ideas
Do you know which one of these your vehicle is equiped with ? Do you know where the vehicle RPO code sticker is ?
Power Windows Description and Operation (RPO AXC/AXE)
Power Windows Description and Operation (W/O AXC/AXE)
Power Window System Controls
The power window system will operate anytime the retained accessory power (RAP) system is active or when the ignition switch is in the ACCY or ON position.
The driver and passenger door lock and side window switches are integrated control module switch assemblies. The DDS and PDS switches are normally open, 3 position rocker type switches, with detents for up, down, and express down. The DDS rear passenger window switches are normally open, 2 position rocker type switches, with detents for up and down. The DDS rear window lockout switch is a push button type switch that provides an active signal to the DDS whenever pressed. Whenever the rear window lockout switch is pressed the DDS will activate or deactivate the rear window lockout function depending on the current state and illuminate the switch indicator whenever the function is active.
The PDS contains a single power window switch that is an integral component. Closing of this normally open, rocker switch provides the PDS with a request for the front passenger power window operation. The switch for the front passenger window has 3 positions UP, Down and Express Down. Each of these switch positions is a direct input to the PDS.
The rear passenger door power window switches are normally open, 2 position rocker type switches, with detents for up and down.
Do you know what DTC'S - diagnostic trouble codes are ?
DTC B3822 00: Right Rear Window Up Control Circuit
Circuit/System Description
The body control module (BCM) monitors the window UP/DOWN command from the driver door module(DDM). When the rear window UP or DOWN command is received, the BCM sends a signal to the appropriate rear window switch. The rear window switches continuously monitor the up and down signal circuits, if no function is being commanded, the signal voltage is at approximately B+ voltage. If the UP or DOWN function is commanded, the BCM signal voltage drops approximately 0.5 volts and the appropriate rear window switch will then command the window in the UP or DOWN direction.
How to test computer controlled door locks Subaru same concept for your vehicle .
GM factory test procedure
Circuit/System Testing
Ignition OFF, disconnect the harness connector at the appropriate rear window switch.
Ignition ON, test for greater than 9 volts between the signal circuit terminal A and ground while commanding the rear window UP with a scan tool.
? If less than the specified range, test the signal circuit for a short to ground or open/high resistance. If the circuit tests normal, replace the BCM.
Test for greater than 9 volts between the signal circuit terminal C and ground while commanding the rear window DOWN with a scan tool.
If all circuits test normal, replace the rear window switch.
Your best bet maybe to take it to a qualified repair shop
Mar 27, 2018 | GMC Cars & Trucks
How do you remove the right front door panel on a 2004 buick le saber
Did you test it or are you guessing just because it won't open or close ? How To Install Remove Front Door Panel Buick Lesabre 00 05 1AAuto com both right an left are the same .
Power Windows System Components
The following components are used to control the power windows:
Driver Door Module (DDM)
Passenger Front Door Module (PDM)
LH Rear Door Module (LRDM)
RH Rear Door Module (RRDM)
Driver Door Switch Assembly (DDSA)
RH Front Power Window Switch
LH Rear Power Window Switch
RH Rear Power Window Switch
LH Front Power Window Motor
RH Front Power Window Motor
LH Rear Power Window Motor
RH Rear Power Window Motor
Class 2 serial data circuit
Power door serial data circuit
PWR WDO 30 Amp Circuit Breaker
DRVMDL Fuse (10 amp)
Driver Door Switch Assembly and Driver Door Module logic, Driver Door Module internal driver operation
PASS MDL Fuse (10 amp)
Front Passenger Door Module logic and internal driver operation
RRDR MDL Fuse (10 amp)
Left Rear Door Module and Right Rear Door Module logic and internal driver operation
Do you know about computer controlled power windows ?
Power Windows Operation
The vehicle is equipped with power windows controlled by the door modules. Each passenger door window can be operated, either from a switch built into the driver door switch assembly (DDSA), or from a switch mounted locally to its associated door. The driver door window can be operated only from the driver door window switch built into the DDSA.
When a window is operated from the DDSA, the DDSA interprets the window switch signal as a specific window switch request and sends the information to the driver door module (DDM) via the power door serial data circuit. The DDM examines the request and checks to see if it has received any class 2 serial data messages from any of the other vehicle modules (i.e. ignition switch position) prohibiting the movement of the window. If the window being operated is the driver door window, and if no prohibitive class 2 messages have been received, the DDM then applies voltage and ground to the driver door window motor to move the window glass as requested. If the window being operated is a passenger door window, and no prohibitive class 2 messages have been received, the DDM sends the request, via the power door serial data circuit, to the appropriate passenger door module. The passenger door module then applies voltage and ground to the passenger door window motor to move the window glass as requested.
When a passenger door window is operated from the power window switch mounted locally to its associated door, the passenger door module first checks to see if the DDM has received any prohibitive class 2 serial data messages. If there are no prohibitive messages, the passenger door module powers the associated passenger door window motor.
Both front door windows have the express down feature. This allows the front door windows to be fully opened by momentarily pulling the appropriate window switch lever to the second detente and then releasing.
Oct 30, 2016 | Buick Cars & Trucks
How to fix the right passenger rear window that fell off track to 1994 Mercedes-Benz e320 right passenger rear
REMOVE THE REAR DOOR PANEL AND REPLACE THE REGULATOR ASSY. VERY COMMON ON THIS MODEL.
Apr 20, 2015 | Mercedes-Benz Cars & Trucks
HOW DO I REPLACE REAR PASSENGER POWER WINDOW ON A 4 DOOR AUTOMATIC 1996 NISSAN MAXIMA
Go to you-tube and enter your question and see if someone has do this before and then you can follow their instructions.
Mar 05, 2015 | 1996 Nissan Maxima
Rear passenger window made a cracking noise when it went up and now it is loose and won't retract
the roblem came from the window regulator cable need to replace the window regulator
Sep 06, 2014 | 2006 BMW 325 325
Rear passenger window dropped down 2006 yukon denali
Hi, please replace window glass motor system.
Jun 17, 2014 | 2006 GMC Yukon Denali
Power windows
It's the motor. If the motor turns at all, the switch is good. Make sure the glass is not binding in the track. If it works with a little help, replace the motor.
Jul 30, 2017 | 1999 Toyota Corolla
How to repair broken winder cable on rear passenger window mercedes e430
Remove the inner door panel & replace the
regulator cable assy,switch motor over the new one
if possible
Nov 18, 2012 | 2001 Mercedes-Benz E-Class
How do i replace rear passenger window
Did they break the larger window? or the smaller one?
The larger one is the easy one, remove the door panel, adjust the window mechanism until you can see the bolts on the bottom window track, undo these bolts and remove the old track, To fit the new window it's simply a matter of removing the side window guide rail and sliding the window in on an angle and wiggle it around until you get it inside the door, the seat it in the rail and replace the guide rail. Then bolt the window to the mechanism and re-assemble the door panel.
If it's the smaller one you need to remove the larger window first then remove the frame between the smaller and larger piece of glass, You can then replace the glass.
I would suggest calling around and you may get a good price for an expert to replace it as it is a pain to do.
Mar 13, 2012 | 2003 Mazda Protege
Rear passenger window on my 2003 ford expedition
replace the window mechanism on that door
Oct 12, 2009 | 2003 Ford Expedition
Vehicle Parts & Accessories Logo
50 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
