Question about Starlite Next Play Clock Radio with iPod Dock NP105CR
Manual how do I set my radio channels? Thank you.
  • 3 Answers
Hello there i have a sony lbt d-905 the same same system like you guys and lost the user/ owner manual or misplaced cant find it now and want to connect the system could you please share the manuals you got by sending them through an email i will be grateful to you thank you and you can mail me on ben_ima_armedsqn@yahoo.co.in
Posted on Jul 12, 2013
How do I program a Midland GXT760VP4
After installing and charging the battery pack (or installing alkaline batteries), turn on the radio by turning . Then press Menu once to set your Channel. Press Menu additional times to set other features. To set the channel to listen to Weather Radio, continue pressing Menu to the Weather Channel sub-menu (Channel 1 is 162.400 MHz). If you press and hold Menu for more than 5 seconds with the radio in GMRS mode, the radio will scan all 10 weather radio channels.
Midland has the manuals to many of their products here: http://www.midlandradio.com/Two-Way-Owner-Manual . The direct link to the manual is http://www.midlandradio.com/Resource_/OwnerManual/201/GXT760%20Owner%27s%20Manual%20.pdf .
Please let me know if there is a specific item you want to set up on the GXT760VP4.
Nov 18, 2011 | Midland Radio Communications
How do I reset my KENWOOD TK-3170-K 4 to original settings?? Thank you!!
- Power the radio OFF
- Power the radio ON
- Push and hold The UP arrow, DOWN arrow, and MON keys and power the set ON
- Release the keys when the message rESt (reset) appears on the display.
Need the manual? You can download and print it, at no cost, here:
http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Communications/LMR/Manuals/TK-3130_B62-1486-20.pdf
Bill B.
Nov 22, 2010 | Kenwood Protalk XLS TK-3130 (2 Channels)...
Motorola Talkabout FV700 not transmitting nor receiving
To troubleshoot: Unlock your keypad lock, then reprogram your radios to the following settings. (Check function after each change)
1) Shut off the Interference Eliminator (set to zero).
2) Turn off the Qt filter.
3) Vox setting to off.
By shutting off all the "bells and whistles" of the radio, you will take it back to being just simply on a frequency. If your radios do not communicate with one another then, or with your friend's radios, you have radio which is failing to operate.
If the radios do work in this simple mode. One by one add the special features back until you discover the culprit.
Dec 26, 2008 | Radio Communications
Scanner problem
To unlock a channel, press 'manual' & keep pressing it until you reach the channel that's locked out, then press 'L/O'. Repeat until all channels are unlocked.
To program, press 'manual' until you get to the first "empty" channel, then enter the desired frequency using the keypad, then press 'E'. Repeat as needed.
Dec 21, 2008 | Uniden BC72XLT Handheld Scanner
T5950 2-way
Initially, pls check that the displays of both radios are identical. This is important to establish that the channel/frequency, Interference eliminator settings and all others are the same that both are paired. In some instances, the radio settings may not be changed if it is locked. Top unlock, press on the MENU button for about 3 seconds. For all other settings, pls refer to the user's manual.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | Motorola Talkabout T5950 (7 Channels)...
Uniden washington base station
I need the wireing information for uniden washington CB radio,thank you.
Oct 28, 2008 | Uniden PC78ELITE 40-Channels Base CB Radio
Stucxk on vibrate
As per instructions of the manual:
"...Your microTALK® radio can alert you to incoming signals by
sounding an audible call tone, by vibrating silently or both. To change call settings:
1. Press the Lock/Mode button until the Call Setting icon flashes on the display. The current setting (“01” vibrate + ring, “02” vibrate only or “03” ring only) is displayed.
2. Press the Channel Up or Channel Down button to change the call setting.
3. Choose one of the following:
a. Press the Lock/Mode button to enter the new setting and proceed to other functions.
b. Press the Hi•Low/Enter button to enter the new setting and return to Standby mode
Should you need a copy of the manual, it is available here.
Mar 16, 2008 | Cobra 22 CHANNEL 2-WAY RADIOS
Starlite Next Play Clock Radio with iPod Dock NP105CR  Logo
181 people viewed this question
Top Starlite Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Starlite Audio Player and Recorder Expert? Answer questions, earn points and help others
