Question about Dishwashers
No water in Bosch dishwasher
No water in the dish washer. took the hose of the "load" end of the water inlet valve. no water flow. the weird thing is i get 110V on each side of the solinoid when wires are plugged into the solinoid prongs. when I remove the wires i only get 110V on one leg. the strange part is i do not get 110V across both the wire when off the prongs... also the solinoid reads 1000 ohms across it. Shouldn't i get 110V across the wire? i want confidence before i get the part.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 48 Answers
You should get 110v if you meter across the 2 wires while not on the solenoid. A lot of machines now switch neutral to keep the amperage down. So you may not have voltage because no neutral has been switched in the controls ( timer or board). Solenoid may be ok 1000ohms is about right. You can try making a test lead and just switching on the solenoid.
Posted on Jul 10, 2013
  • 13 Answers
SOURCE: Bosch Dishwasher SHU9922
It is the inlet valve, some are located inside the appliance, some mounted in the back panel. Occationaly some have the valve at the end of the hose in a box. The price for repair the first one cheapest the last most expensive. regards Appliance Doctor
Posted on Feb 02, 2007
  • 1462 Answers
SOURCE: My Bosch dishwasher model #SHU43C05UC/14
open machine when running and check both spray arms rotating - you will get a bit of water out. if spray arms not rotating, usual cause is debris in the arms. the spray arms only rotate by water jetting from angled jets at the end of the arms. take them out and make sure all debris removed
Posted on Jul 14, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Bosch Dishwasher SHU43C Not Washing Dishes
Check for plugged nozzles
Posted on Feb 08, 2009
SOURCE: Bosch SHU 4000 series dishwasher; Water keeps on filling
Follow-up: I was able to fix the problem on Bosch model # SHU 4002UC. Purchased water inlet valve (part number 425458) from Sears Parts Center. I required the Sears unit number from the original invoice as Sears computer system apparently cannot identify the Bosch model number. The valve is as described by meyerjr above; however it is located at the bottom front of the machine so could be replaced (not so easily) without removing the machine. Cost of part was $30.50 Cdn including tax.
lwou
Posted on Apr 20, 2009
  • 135 Answers
SOURCE: frigidaire Dish Washer. no water is coming into
Verify that water is getting to the valve and verify that 110 volts is getting to the valve. If either one is missing then you know what the problem is. If you have both then replace the valve.
Posted on Sep 05, 2009
Testimonial: "Thanks I will give it a try"
Hy, I have a washmasine bosch WAE28267SN that sow me an error E02 that's the error. Somebody can help me with some tips Thanks
The E02 error means that the washer is slow to fill. This can be caused by a problem with the incoming water hoses, the water valves or the washer draining as it fills.
The first thing to check is the incoming water if you have very little water in the washer. Make sure that the shut-off valves have been opened fully. If they were fully open, close them. If they were closed, check if that solves your E02 problem. Next remove the water hoses. A damaged anti-flood hose can reduce the water flow to a trickle. Clean the filters at both the shut-off valves and the intake valve on the washer. Replace the hoses at the shut-off valves. With a bucket below the hoses, turn on the shut-off valves and check that you are getting good flow. Now, attach the hoses to the washer. Check if the washer fills properly.
Check that the drain hose is positioned so that the outlet is above the water line of the washer. If your E02 issue continues and no water gets into the machine, then the inlet valve could be stuck in the closed position. If the washer is filling and the E02 error persists, then the water flow sensor may be a problem. This sensor has air tubes that can become clogged. Make sure that they have no dirt. There are other parts in this sensor that could be damaged.
Unfortunately, I don't have a source for parts for this washer. Some Bosch water inlet valves are available here: http://www.appliancepartspros.com/bosch-washer-valve.html . If your washer is under warranty, contact Bosch.
I hope this helps.
Jun 15, 2016 | Bosch Washing Machines
Dishwasher not washing or drying dishes properly
F7 - Flow meter failure
Water inlet valve (WVI) is switched on and water indicator (WI) is on (full).
  • Flow meter (FM) sends too few impulses (less than 10 imp. in 10 sec.).
  • Water tap closed during water inlet
  • Water inlet hose blocked
  • Water inlet valve (WV1) defective
  • Flow meter (FM) defective
To erase the failures, you must push the start button longer than 1,5 seconds.
Dado
May 11, 2015 | Whirlpool 24 in. ADP5966 Free-standing...
How to fix a bosh dishwasher with E 01 code
The E01 error may mean that the water flow into the washer is restricted or that the flow meter is not reading correctly. Sometimes the control board near the washer inlet is faulty and can't read the signal from the flow meter or send that message to the control panel.
First check your shut-off for the dishwasher and make sure that it is open. Next turn the valve off and disconnect the inlet hose. Connect a new hose to the valve and position a bucket under the hose. Open the valve and check the water flow. If you have good water flow, try connecting this new hose to the inlet of the dishwasher. (Unplug the dishwasher. For an under-cabinet dishwasher, you'll need to pull the washer out. Make sure to keep the discharge hose from pulling loose. Then disconnect the old hose from the fitting and connect the new hose instead. Then slide the washer carefully back into place without pinching the hoses or cables.)
If you add a comment with the model number, I may be able to give more specific directions and replacement part information. Of course, if the dishwasher is under warranty, contact Bosch.
I hope this helps.
Apr 12, 2015 | Dishwashers
Bosch she43f15uc just stopped pumping water. Any ideas? it is only 18 months old.
My Bosch dishwasher had the same problem. After checking the over flow pan I removed the inlet hose to check water flow. There was none. I checked my cut off valve...open...I had water at the kitchen facet...scratch my head...I looked closer at the Bosch supplied braided water hose. It is directional (label indicating which end to hook to supply)....closer inspection reveals maybe there is a back flow valve in that side of the braided hose. Disconnect, blow air through...air passes freely...reconnect and bingo water flow at the dishwasher. In line back flow valve...can you imagine what a repair man would have charged for that?
Apr 04, 2012 | Dishwashers
Water not coming in to washer
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 27, 2011 | Bosch 23 in. SHU303 Built-in Dishwasher
Bosch dishwasher does not fill with water
Hi
Daniel
Jul 19, 2011 | Bosch Dishwashers
Dishwasher will not run or fill with water. check water light comes on
Possible that the inlet valve is not working . check the voltage of the inlet valve when the program is put ON. If there is voltage with no water flow the valve is faulty if not the program controller is having errors and must be checked out.
Sep 24, 2010 | Bosch Classixx WFL 2066 Front Load Washer
GE dish washer model gsd2600go2bb will not fill with water or just a little water,its not getting the water its suposed to.
This is due to one of two issues, either the water from the house is restricted or the valve in the machine needs replaced.
To determine which it is, you will need to turn off the water to the dishwasher, the valve for the dishwasher water is usually under the sink. Remove the hose/pipe from the dishwasher inlet valve. The image below shows the water valve as part 744, it is accessible on the front left corner once you take off the lower kick panel.
With the hose taken off of this valve (744) put the hose in a bucket or put towels on the end and turn the valve back on from under the sink. We want to make sure you are getting good water flow to the dishwasher, if this is slow then you will need a plumber to find out why the water in the home is slow if this is flowing good then you will need to replace the valve on the dishwasher (744), the part number to use when purchasing the new valve is WD15X10003
May 24, 2010 | Dishwashers
There is no water getting to the dishwasher. Nothing has changed with the water line. Looks like there is a problem with the dishwasher. (Bosch Brand)
Hello, your problem is going to be with the inlet valve. Remove the panel at the front bottom of the dish washer, turn the water and power off. You will see the inlet valve normally on the left side underneath your dishwasher (sometimes on right) connected to the water supply. Remove the water supply hose/pipe and then remove the wire harness from the valve. Now you can remove the valve from the machine. Just inside the inlet there should be a screen...check this for debris. If debris found clean out and reassemble, If no debris replace the valve and then reassemble. If you have any other questions please feel free to comment again. Good Luck!!! Mike
Sep 08, 2009 | Bosch Dishwashers
Feb 02, 2007 | Bosch SHU9922UC Built-in Dishwasher
Dishwashers Logo
57 people viewed this question
Top Dishwashers Experts
Owen Barnes
