I am seeking a circuit or service manual for a LA40A450C1DXXY
I need a service manual or main PCB Circuit for a Samsung LCD TV Model LA40A450C1DXXY as I am a retired TV & Video Tech trying to fix my sons TV I have been told that the main board (part BN94-02127B)is no longer available in Australia and is not supported by the USA for parts or ic's etc the problem is a vertical red Chroma bar aprox thirty five inches wide from the left side however the tv will work with extra heat sinks and a fan on the main board I have already changed all caps in the PSU inverter etc and am trying to either replace the main PCB or isolate the shorted SMT and replace it but I need a circuit or complete service manual with CRO wave forms etc can you help?
  • 4 Answers
We tried to turn on tv and it will not show a picture or sound can you tell me what is wrong with it
Posted on Jul 10, 2013
5 Suggested Answers
bestdarngood
  • 3037 Answers
SOURCE: sharp lc26sh20u 26"flat panel has vertical lines on left side,What coulb be problem?
This line would either indicate a horizontal problem cropping up or a power supply problem
I would suggest getting a service tech to look at it to determine where your problem is coming from but most likely it will be the power supply /deflection board that is the problem but I can't know for sure, it will have to be checked.
A lot of sets have had damages after a long hot summer a/c flipping off and on and current demand being peeked from the utilities storms or quick power loss off and on can cause problems like this to occur
Please let me know if you have any other questions, thanks
Posted on May 14, 2008
jerryg50
  • 1667 Answers
SOURCE: Plasma TV
Your set is servicable with proper troubleshooting. Normaly, the defective boards are swapped out to service these sets. This fault can be in the address decoder, or the display drive boards. It is also possible that the failure is in the display assembly itself.
My preference would be to give the set to the authorised service rep to have an estimate to deterine if the set is worth to service.
Jerry G.
Posted on Jul 16, 2008
  • 21 Answers
SOURCE: NM2168(020731) 14" TV. Vertical circuit
The spark that you saw was probably caused by a cold solder ..remove the old solder,clean the pcb make sure that the track is still ok..if there is a break its ok to jump it with no.22 AWG solid copper wire.Some tv version gets the 24vdc supply for the vertical circuit from the flyback transformer.Also check the vertical IC for cold solders ..hope your problem is confined to cold solders only..good luck
Posted on Dec 30, 2010
eagle338
  • 4889 Answers
SOURCE: right side of samsung ln52a580p
This is not an issue with the main board . Its a clear case of faulty LCD controller board or the LCD panel itself is faulty(most likely). I suppose the sound is not affected?
Posted on Feb 15, 2011
What is a 41-E code means on a Samsung refrigerator
41e = Main LCD Comm Error
The main PCB and the LCD display are not communicating properly. (Verify the wiring and both PCB's).
(PCB = printed circuit board)
Jun 14, 2017 | Samsung Refrigerators
Samsung LED40"UA40EH5000R no picture sound ok
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
May 16, 2015 | Samsung Televison & Video
A samsung fridge RF4287HARS has error codes 40E, 21E and 22E
Hello Jerry Fuller,
All your codes point to the same circuit pack.
Main Control Board ...DA41-00884a
PCB "CN76" low voltage condition... Low Voltage condition
(PCB = Printed circuit board)
CALL...
If you have any questions or comments relating to Samsung products,
55 STANDISH COURT MISSISSAUGA,
ONTARIO L5R 4B2 CANADA
Please contact the SAMSUNG customer care center.
SAMSUNG ELECTRONICS CANADA, INC.
TEL : 905-542-3535 FAX : 905-542-3835
1-800-SAMSUNG (7267864)
www.samsung.com/ca
owners manual
Samsung RF4287HARS User Manual
Service MANUAL (CODES on page 60)
Samsung RF4287HARS Service Manual
Feb 13, 2014 | Samsung RF4287HARS French Door...
La40a450c1dxxy service manual
i have been told that my power suppy board has gone out and i need to know how to fix it and where it is
Jul 10, 2013 | Televison & Video
Replaced lamp
There is some short circuit at the main circuit board. Seek help of any experienced service technician.
Aug 01, 2012 | Samsung HL-P6163W 61" TV
SOUND INCREASES AND DERCEASES ON IT'S OWN
This is due to fault with its audio control circuit. Might be to main board fault. Seek support of any experienced service technician. The work is skilled one.
Jun 07, 2012 | Samsung LN32A330 32 in. LCD TV
Hi - We have an error code on a Canon Model 2800 : E000001-0002 Any ideas on how to fix the problem? Thanks! Paul
E001
0000 The main thermistor detects 250°C or higher.
0001 The main thermistor or the sub thermistor detects overheating (hardware
circuit detection).
0002 The sub thermistor detects about 295°C or higher.
Main cause The fixing film unit is faulty (i.e., the thermistor has a short circuit). The
main power supply PCB is faulty. The DC controller PCB is faulty.
Caution To clear the error, execute the following in service move:
COPIER>FUNCTION>CLEAR>ERR.
Action
1. Fixing film unit
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of
the connectors (4-pin) of the thermistor for electrical continuity. Is it 0 ?
(short circuit)?
YES: The thermistor has a short circuit. Replace the fixing film unit.
REF.
If the thermistor has a short circuit, the indication in service mode
(COPIER>DISPLAY>ANALOG) will be as follows from the start: FIXC=250°C
for the main thermistor; FIX-E=310°C for the sub thermistor.
2. Main power supply PCB, DC controller PCB
Try replacing the main power supply PCB. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
BUT FIRST: under service mode *28* copier, function, clear , err turn off and on maybe it will work.If it works check that you have good air flow around the copier.
Apr 19, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Need a services manual with codes and fixes
E000 : The main thernistor is opened.
E001 : Thermistor in short circuit.
E002 : SSR faulty
E003 :SSR and PCB faulty
E004: SSR in short circuit.
E005: Fixing web taken up.
E010: The main motor defected.
E012:Drum motor blocated.
E013:Wastw toner feedscrew faulty.
E014:Fixing motor defect.
E020:Hooper motor failure.
E032:PCB defect.
E061:Laser unit faulty.
E100 :The DC controller PCB malfunction.
E110:Laser scanner motor defect.
E121:M4 cooling fan defect.
E196: EEPROM faulty.
E202:Scanner home positin faulty.
E204:ADF controller faulty.
E220:Lamp inverter faulty.
E225:Xenon tube malfunction.
To reset in service mode press COPIER-FUNCTION-CLEAR-ERR.
Aug 11, 2009 | Canon imageRUNNER C6800 Copier
Samsung le32r black screen
Hi.
Your problem sounds like inverter has failed.
To prove this you need to remove the back from your tv set.
Then switch it on and look carefully through the small holes on the metal shielding that is directly over back of screen you are looking for bright white light.
If you cant see it easily try doing again but in A dark room.
If you can see white light through the holes in metal shielding the inverter is working & fault is else where.
If no light can be seen problem is with inverter you will need to remove the inverter pcb & check the transformers with ohm meter to see if one is open circuit. Allso look on same pcb for any smd circuit protectors that may be open circuit.
http://dysonmanuals.llc.nu/
Chris..
Jan 03, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Electro Med Services...
