Question about Lands Phones
My M&S system model mc602 doesn't work. It only
2 Suggested Answers
SOURCE: I have the Panasonic KX-TG4500 4 line cordless
what did you end up doing? i have the same problem.
Posted on Oct 25, 2011
MY TV WENT OUT LAST NIGHT THE POWEWR LIGHT JUST FLASH AND NO PICTURE IT IS A SHARP LCD 32 '
Hello; Your model # shows that is a 30 in. set. First try unplugging both pieces and plug both back in a minute or longer (doesn't matter). If still bad, your monitor has bad inverter boards or main unit. The set has 2 or 4 of them. You must replace all. About $700.00. Sharp told me to replace all 4 , but I was able to force them to stay on, which proved they were OK. Later I took in the same model for repair. I swapped the main units ( the big board in a metal box ) and my first set started working! The Main unit is not available, but it can be sent to Sharp for repair ( about $250 - $300 ). The swap that I did proves the problem can be inverters OR the main unit. A lot to gamble with here! You may find these boards cheap on the net ( EBAY, Shop Jimmys dot com & many others. To get your part #'s go to Encompass Parts dot com and key in your model # . John
Oct 06, 2011 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Hi, I have a Denon AVR-1709 & recently set up Zone 2 to operate my outdoor speakers via AMP Assign. The system is working but I''m only getting limited volume through the outdoor spears and the...
zone 2 volume can be adjusted by zone2 remote control (small one which came with the unit) or by main remote control if you switch it to zone2 mode. My main rem control has a slide switch i have to put in zone 2 position to operate zone 2 amp.
Sep 03, 2011 | Denon AVR-1905 Receiver
I have an intercom system in my house. It is M&S model MC602. It keeps blowing the 2 small glass tube fuses. Where should I start looking for the short?
Start looking anywhere a cable might be regularly flexed. Next, where critters can get to it (attic, crawl space) and chew.
If anyone has recently hung a picture, or done anything else that would have penetrated a wall nearby, try pulling the nail or screw or whatever out to see if it's shorting through the cable.
After that, it's time to just run some new wire, or get one of the newer wireless units - you'll drive yourself nuts trying to find the problem.
Jul 06, 2011 | Audio Players & Recorders
I have a MC602 system that keeps blowing fuses. What's causing this?
You have internal short in the unit. could be power transistor along with their load resisitors.
good luck
Jun 27, 2011 | Audio Players & Recorders
Have M&S systems Model MC602 Can't seem to reset after power outage.
I called the company and this is what they said:
Based on the problem description, there is nothing you can check to try and get the radio to work again. The most likely cause is a Tuner Module failure due to electrical surge. You will need to send the MC602 to us for service. We will need you full address, phone number, and the serial number or date code from the back of the MC602. The serial number/date code will be on a white sticker and may have a barcode on the sticker as well. When receive you information, we will issue you a Return of Product Authorization (RPA) number and instructions for returning the unit. There will be a repair charge and that can be provided with the RPA number.
Sincerely,
James Williams
Senior Applications Engineer
Linear LLC
Technical Services
(800) 421-1587
Sep 23, 2010 | M&S Systems Audio Players & Recorders
My indoor outdoor thermometer is only displaying the inside temperature and I lost the manual and can't remember how to reset it?
often removing the batteries in both units will reset. replace batteries in indoor unit firs, let it settle down then insert batteries into outdoor unit. There may be a button on outdoor unit to initialise the connection.
Alternatively you might find the manual here or get the instructions from their support.
http://www.orbyxelectronics.com/manuals.asp?choice1=3&choice2=14&hidPickIndex=2
Nov 04, 2009 | NexxTech (NOMR)
Source code for stack using arrays in c++
stack in c using arrays
/* Program of stack using array*/
#include
Dec 05, 2008 | Computers & Internet
M&S Systems MC602 Master Unit and M&S MCD6 6-disc CD Player
mc 602 system---volume stuck on 32 and not playing main speaker
Mar 05, 2008 | Audio Players & Recorders
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
