Question about Home Security
How to factory reset hormann garage door receiver
The remote controls work intermittently.
TJBENGR
  • 121 Answers
SOURCE: Garage Door Key Pad
Assuming, from what I read, the remote works..The inside switch is just a doorbell switch which will wear out or have the contacts get bent or dirty. Take off wall, and change for new one or see if the contacts can be cleaned or adjusted. If the pad is electronic (coded) the wires may be bad or the control defective. Usually momentary contact of the two wires will cause the door to actuate.
Posted on Apr 21, 2008
SOURCE: Garage Door Remote Not Working Consistently
Lift Master Security Plus remote works only intermitenly, It seems to lock after a few tries, Works from inside garage, Seems to lock up after few tries, Wall opener fine. Changed batteries several times. Can't understand why it works and then doesn't. Tried cleaning sensors and wires,
Posted on Oct 29, 2008
drumbanger
  • 1199 Answers
SOURCE: neither remote control will open door but wall mounted button wil
Make sure the code set inside the remote is the same as in the main reciving unit code.
Posted on Dec 06, 2008
  • 3197 Answers
SOURCE: Craftsman Model 139.53684 Security+ Keyless Entry
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Posted on Dec 08, 2009
swolfinor
  • 504 Answers
Have you tried a new battery??
Posted on May 29, 2010
Hormann garage door
If the courtesy lights on the motor unit aren't turning on, there may be no power getting to the machine, or there may be a fault in the control board. If the opener is getting mains power, I would suggest calling a Hormann dealer.
Sep 17, 2013 | Building Materials
How do I reset hand held door opener for horman silent drive 5500 series
The instructions for programming are on page 34 of your owners manual. If you do not have the manual you can go here.
http://www.hormann.us/assets/1/Page/SilentDrive_TR10H004D_0710.pdf
May 12, 2012 | Sears Craftsman LiftMaster Chamberlain...
My garage door receiver does not have a "learn"
The 900 series remote control only works with door openers having an orange learn button see the liftmaster remote 971 manual 4th one down
Feb 19, 2011 | liftmaster 971 Lm Remote
Garage door dosent work whit remote control, but i works manuelt
check the remotes batteries and take a finger nail emery board and lightly sand the battery and remotes terminals,also try getting up close to the receiver with the remote maybe its a blocked signal,also make sure the antenna on the receiver is out in the open and not wrapped up somewhere,then also remove the receiver boards and check those connections too for corrosion and reinstall and see if this helps
Jun 20, 2010 | liftmaster Chamberlain Garage Door Opener...
Intermittent remote trouble
Your wall control is hard wired and doesn't use the receiver portion of the logic board. The remotes do. Your receiver is going bad.
Jan 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Wireless key pad and remote openers for the cars work intermittently have tried re-learning
Your remotes and your keypad are small transmitters that send a signal to the receiver. If all your units are intermittent then it is the receiver that is bad. The receiver is part of the logic board.
Jul 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
2 different openers stopped working by remote at the same time
Both the older genie and a newer chamberlain (3-4 yrs old) both run on 390Mhz frequency. sounds like you will have to change your receivers on both operators (365LM 315Mhz) then get 3 button remote so you can program both doors on one remote.
Jan 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens on it own and light blinks
  • Stuck remote control button. Check all remotes. check LED on receiver.
  • Staples around Multi-Function Control Panel bell wire could be cutting into that wire. Remove wires from opener and test. Replace staples causing intermittent short.
  • Multi-Function Control Panel could have sticking door control push bar. Remove wires from control panel and test. Replace control panel if defective.
Dec 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
No remote control function
Set the large remote to "ALL" or "AMP" and it should work,the small remote is for zone 2.
hope this helps.
CABLE GUY.
Jan 13, 2008 | Yamaha R-V1103 Receiver
Remote problem
It sounds like an intermittant Infared sensor problem or there is an intermittant solder connection between the sensor and the controler chip. Good Luck
Apr 08, 2007 | Kenwood VR-407 Receiver
Home Security Logo
51 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
