Question about Toys
Nexus V789 helicopter problems
Helicopter will not charge. I opened it up and cables are still connected
3 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: Brookstone Silver Bullet Helicopter: When I
This is a battery fault, unfortunately pretty common. How old is this helicopter? It may still be under warranty.
Let me know, there is not really much of anything you can do on your end... you are doing everything correctly for sure.
Tim
Posted on Oct 09, 2010
SOURCE: I can't seem to charge
You should see the orange LED glow when you first plug the cable in. Once you plug the heli in, the LED should go out. Once the heli is charged, the LED will come back on.
Posted on Mar 09, 2011
The battery in my Nexus 7 will not charge. how do i replace it.
you really cant change the battery but if you feel brave you can try to open the nexus up
HOWTO Remove and Replace Nexus 7 Battery
Dec 19, 2014 | Google Nexus 7
Remote will not control the helicopter
did you charge the helicopter.... you need to put the charging cable in to the copter. and charge up can use a usb power plug. when charged the light on the usb cable should light up or flash. also if you take the plastic cover off the front there is a battery in there and a board check to see what number its set on. it takes around 5 seconds for the remote to recognise the unit.
Dec 26, 2013 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
Nexus 7 wont turn on for longer than a second, then it says powering off.
Charge your nexus using the ASUS wall charger that came with your nexus.
Once you connect your Nexus to the wall, just push the power button once (do not hold). A battery animation should appear showing that the tablet is charging. Let it sit for a while, then power it up.
If you suspect it's a hardware problem and if you feel comfortable opening up your device, please let me know so I can give you a step by step walk through to figure out what exactly is going on with your device.
Apr 06, 2013 | Google Nexus 7
Samsung galaxy nexus no charge
Hello My Dear Good Morning:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 23, 2012 | Cell Phones
On what part of the helicopter do i connect the remote charger to, I can't find it?
When the helicopter is sitting upright, locate the on/off power switch located on one side of the helicopter. The charging port is located on the opposite side and will look like a tiny square hole/plug (usually white or beige).
Note: The charging cable can only be plugged in one way, because it's notched / keyed so that it can only be plugged in one way. If it does not seem to be going in smoothly one way, flip it over, and try gently plugging it in again.
Dec 26, 2011 | SYMA Toys industrial New Syma S107 Radio...
I just got an r/c helicopter ( gyro s032 ) i've just tried it once but then i tried charging it for second run, but when i plugged the charger cable in the helicopter. It din't want to charge,i looked,and...
couple of things possible. 1) change outlet. 2) call customer service for the helicopter (should be on manual in contact section) 3) the helicopter has a loose cable connected to the battery inside the helicopter so you probably need to sodder it.
Dec 26, 2010 | SYMA Toys industrial Syma S032 Ready to...
My sharpshooter and remote both turn on, but the helicopter does not react at all, what should i do?
I had this problem yesterday as well :)
My helicopter charged once worked and flew once for about 5 minutes. Then the helicopter stopped responding to the controller and it wouldn't take a charge. When I connected the remote to the helicopter the CHG light came on solid for about 30 seconds. This means that the controller is waiting to be plugged into the helicopter.
A couple of points to check before you go further:
1) make sure that the helicopter is turned OFF before charging!
2) When charging the red CHG light will blink.
3) When finished charging the red CHG light and the green Power light will blink at the same time.
4) After a certain amount of time both lights will stop blinking to save the batteries.
After taking the helicopter apart this is what I have found:
*The helicopter has a 140mA-H 3.7V Li-Po battery.
*The battery has a little board with 2 tiny computer chips. When the battery is empty these 2 chips will completely disconnect the battery. This prevents damaging the battery and this is why the helicopter stops responding when the battery is empty.
*There are two connections between the battery and the little board - a long connection which wraps one time around the battery and a short connection. My problem was with the short battery connection.
Solution --The little board has a short piece of foil which connects to another short piece of foil on the battery. These two pieces of foil are simply pressed together and then glued. In my case this connection broke. To fix the problem I removed the yellow tape and glue and used a soldering iron to solder the 2 foil pieces together. Make sure that you put tape (any household tape should be OK) back on the battery to prevent any shorts.
Dec 26, 2010 | Master Heaters Air Hogs Sharp Shooter...
How do you charge the mini ah 64
Turn the remote over and look for the sliding door on the back bottom right (it has a circle and some arrows on it, push in the direction of the arrows) the cable is under this door. Then connect that cable to the helicopter by plugging it into the white slot next to the on/off switch.
Dec 25, 2009 | SYMA Toys industrial SYMA 3 Channel S012...
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
