Question about Refrigerators
Water accumulates underneath freezer Neff k4664
The fridge freezer appears to work fine but there is an accumulation of water droplets on the underside of the freezer unit and down the back of the fridge. This is a recent occurrence.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 48 Answers
I've found this when the door seals aren't sealing correctly and also I have seen it when the rear panel of the freezer has moved out of place.
Posted on Jul 10, 2013
2 Suggested Answers
catriver
  • 878 Answers
SOURCE: water dripping inside fridge
jeets, remove the bottom panel from the freezer by removing the 2 quarter inch screws up front. See if you have a sheet of ice under it. If you do, you probably have a frozen drain tube in back. When the unit goes into defrost the water is running down the air vents instead of the drain tube. If this is the case, you will have to remove the back panel in the freezer and clear the drain hole. Use hot water if it is frozen over....Catriver..post back.
Posted on Mar 15, 2007
Why does water in the fridge keeps accumulating
It is most likely that the defrost drain is blocked in the freezer causing the water to drain through the air vents into the fresh food area. You will most likely have to remove the rear panel in the freezer and pour hot water in the drain trough until the drain clears up and the water drains down the drain tube. You may want to place a small tub in the top shelf to collect all the water that will pour through the vents and have some towels. it can get very wet.
Some models have a drain collector in the control panel assembly at the back and this runs into a drain grommet. this collector can plug up. You will have to remove this and clean out the collector tube.
I have found that some Frigidaire and some of the Kenmore refrigerators made by Frigidaire have a problem with water droplets accumulating in the air duct and when it defrosts thee droplets run down and drip into the fresh food section.
Aug 15, 2014 | Refrigerators
I have water accumulating in the bottom of my fridge, what can I do to stop this?
It is where the freezer defrosts and melts the ice. There is a small drain hole in bottom of fridge or freezer. use a vacuum cleaner and **** out trash. prob lint blown in by fan. clean all dust under it whill at it.
Aug 15, 2010 | Neff K9525X4
For some time, water was accumulating on the floor
before you call check the bottom of your freezer, if it is full of ice, yuou more than likely have a clogged defrost drain
remove the back panel of the freezer and ensure the drain is free and clear,
check the fill tube of the ice machine to be properly installed
Oct 13, 2009 | Refrigerators
Water accumulation underneath the bottom vetable
Two solutions
1 If a frost free fridge/freezer - ice build up in internal cooler - defrost totally until no more water
2 if ordinary fridge/freezer look inside at the back, you should see a very shallow 'V' shaped plastic channel running to a small drain hole which leads to the rear outside of the unit. This channel collects the water drips from the cooler
Clear this hole with a pipe cleaner or cocktail stick or similar
Sep 27, 2009 | Samsung Refrigerators
Neff fridge freezer K4664 broken door handle
Go and find your frig paper work there are areas with parts and how to order them
May 13, 2009 | Neff K4664 Top Freezer Refrigerator
Water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
Apr 04, 2009 | GE GSL25JFPBS Side by Side Refrigerator
I have a large Neff refrigerator with a small freezer compartment at the top (the model no is not on the booklet or the fridge) the freezer door is broken - can i get a replacement? thank you Paul...
Hello Paul,
Try looking on ebay for a second hand or spares repair model.
Also try some of the refurb places where the cosmetic returns get sent with minor damage or faulty components.
PS:any chance you have fitting instructions for an integrated K4664 model ?
Mine came with no instructions how to reverse the door and fit to the wooden kitchen doors so and cant find any on the Neff website.
Thanks
I
PS:
Mar 01, 2009 | Neff K4664 Top Freezer Refrigerator
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
