Question about Sony VAIO Computers & Internet
Keyboard removal Sony CR290? - VAIO Sony Computers & Internet
    Top Expert:
  • Sony Master
  • 12,223 Answers
See the video and use the common sense and fix it. God bless you
Posted on Jul 10, 2013
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
How to remove the keyboard?
Remove all of the screws on the bottom, as well as the RAM, hard drive, and CD/DVD drive. Then, while the laptop is open, lift up the upper plastic covering on the bottom (you might need a key to get in there) from here, you should be able to see the keyboard mounting screws, make sure you remove the keyboard cable from the motherboard as you remove the keyboard.
May 04, 2011 | Sony VAIO VPC-CW17FX/W PC Notebook
I cant use my cam on my sony vgn cr290 with windows 7
1. Click on Start, in the search bar type "Webcam Companion" or Camera Capture Utiltiy and press the enter key to use the webcam with the computer.
2. Check if the drivers are installed for the camera in device manager.
Press the Windows logo+R keys together to open the Run window, then type devmgmt.msc to open device manager.
Then, locate the Imaging devices in the device manager window.
3. Reinstall the Camera Capture Utility.
For VGNCR290 click the below link provided and select the appropriate version of Windows 7 Operating System:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCR290
Select the drivers listed under the camera category for the computer and install.
For VAIO VGNFE880E click the below links to install the camera capture utility and its updates:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFE880E&upd_id=2410&os_id=28
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFE880E&upd_id=2494&os_id=28
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFE880E&upd_id=2679&os_id=28
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFE880E&upd_id=2712&os_id=28
Note: The links and drivers provided for VGNFE880E are only for the Windows Vista Operating System.
Apr 30, 2011 | Sony VAIO VGN-FE880E/H Notebook
I need help for my vaio vgn-cr290 camera driver..from philippines
follow these steps:
a.go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGN-CR290
b.select your O.S.
c.select Camera -here are two file you can download it form here.
Here you also find all the driver's you need for your notebook.
Feb 20, 2010 | Sony VAIO VGN-FE880E/H Notebook
Replace keyboard Sony
Hi..
I will provide you a solution this solution are very useful with you. You can do it with your self to follow this instructions. There are some image on how to replace the keyboard.
These instructions will help you to remove and replace keyboards on various laptops. I will not be able to cover all models but you’ll get the idea. Steps for removing and replacing the keyboard are similar for most laptops.
Warning!
- if your laptop is still covered by the manufacturer’s warranty, do not open the case or you can loose the warranty
- always remove the battery and unplug the AC adapter before you open the laptop case
- if you damage the keyboard connector on the motherboard you’ll have to replace the whole motherboard
- proceed on your own risk
Sony laptop
I took these pictures from a Sony Vaio PCG-K33 (model PCG-9S1L) notebook. Should be similar for some other Sony notebooks too.
sony-keyboard-1.jpg Insert a small flathead screwdriver under the keyboard bezel and carefully lift it up. Continue releasing plastic latches and removing the keyboard bezel with your fingers.
Be careful, on some models the bezel might be connected to the motherboard as it shown on the picture above. If you accidentally pulled the cable, connect it back. It is not necessary to disconnect the keyboard bezel from the motherboard in order to remove and replace the keyboard, just put it aside so you can access the keyboard screws.
sony-keyboard-3.jpg Remove three (or more) screws from the top of the keyboard. Carefully lift up the keyboard from the laptop case.
sony-keyboard-4.jpg The keyboard connects to the motherboard via a flat ribbon cable. Before you pull the cable from the connector, you’ll have to unlock the connector.
sony-keyboard-5.jpg The image above illustrates how to unlock the keyboard connector. Carefully move the connector lock 2-3 millimeters up and after that pull the keyboard cable. To install the keyboard, follow the above mentioned steps in the reverse order.
Toshiba laptop
The following pictures were taken from a Toshiba Satellite A135 laptop. The keyboard removal instructions will be almost the same for most modern Toshiba laptops.
toshiba-keyboard-1.jpg The keyboard bezel removal procedure is similar to the above mentioned Sony Vaio laptop. Lift it up with a small screwdriver and remove using fingers. On most Toshiba laptops the keyboard bezel doesn’t have any circuit board underneath, it’s just a piece of plastic and you don’t have to worry about cables.
toshiba-keyboard-2.jpg After the bezel is removed you get an access to the keyboard screws. Remove two (or more) screws. Release the plastic latch pointed with the red arrow and lift up the keyboard. Carefully put the keyboard aside so you can access the connector underneath the keyboard. Do not forget that the keyboard is still connected to the motherboard.
toshiba-keyboard-3.jpg Before you remove the keyboard, you’ll have to open the connector and release the flat ribbon cable.
toshiba-keyboard-4.jpg Here’s a closeup picture of the keyboard connector on the motherboard. Be careful, this type of connector is fragile. On the left image the connector is closed. On the right image the connector is opened. Unlock the connector by moving the lock up as it shown on the right image and after that release the ribbon cable. Remove and replace the keyboard. For assembly instructions follow all the steps in the reverse order.
Hope it is helpful for you!
Thanks for using Fixya
Regards
ICmanServer
Aug 02, 2009 | Sony VAIO VGN-BX543B Notebook
Hi, i need the XP driver for my webcam is for a vaio VGN-CR290.
just install the XP OS.. after go to control panel ang click add hardware..
Jul 14, 2009 | Microtek Eyestar U2s Webcam
I have vaio vgn-cr290.. xp drivers
open google.com and enter ur driver no and you will get the drivers .............
Jan 26, 2009 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
