Question about Dell 5210n Laser Printer
Search Fixya...914.00 Service DC Pick Motor
Motor keeps running, will not print
What is code 67 on a LG PTAC
Hi Jason, The link below is a web page, Click the 4th down for an LG Ductless HVAC & PTAC Error Codes manual.....
https://www.google.com.au/search?q=LG+PTAC&oq=LG+PTAC&aqs=chrome..69i57j69i61&sourceid=chrome&ie=UTF-8#q=LG+PTAC+error+codes
Code 67 ODU fan motor not rotating or proving rotation. Verify fan motor plugged in correctly & fan rotates freely. This can be a failed motor, failed board or motor could have failed and caused board failure as well. Verify 310V DC on motor wires separated by empty terminals on plug with motor plugged in, 0V DC = failed PCB, 310V DC = likely failed motor. Next step: Unplug motor and manually spin the fan (keep it spinning): on same wires you just tested, 0V DC indicates motor failed and caused board failure. 14-30V DC indicates a good motor
Mar 31, 2016 | LG Heating & Cooling
Whre i can rewind the coil of my wahl clipper in manila?
  • Order parts from Australia?
  • http://wahlspareparts.com.au/
  • or rewind in manilla
  • Coil rewinding • companies • Quezon City • Metro Manila ... www.tuugo.ph > Metro Manila ? Coil rewinding ? Quezon City ? Metro Manila ? Philippines ? Electromechtech Industrial Services, Inc. ? Breaker, Capacitor, Coil rewinding, degasify ...
  • Motor Rewinding, Philippines Motor Rewinding Suppliers ... www.alibaba.com/countrysearch/PH/motor-rewinding-supplier.html Philippines Motor Rewinding, Motor Rewinding from Philippines Supplier - Find Variety Motor Rewinding from motor engine parts ,electric motor ,motor oil pump, AC ...
  • Filipino Coils Manila Manufacturers ' Suppliers of ... https://panjiva.com/Filipino-Manufacturers-Of/coils+manila Filipino manufacturers and suppliers of coils manila from around the world. Panjiva uses over 30 international data sources to help you find qualified vendors of ...
  • ELECTRIC MOTOR REWINDING - DC ELECTROMASTER
  • www.dcelectromaster.com.ph/about us.htm DC Electromaster Service Center opened its door on rewinding electric motor since 1979. Only quality materials, unique winding system and techniques of coil insertion ...
  • Motor Rewinding in the Philippines - Philippine Business ...
  • www.philippinecompanies.com/search/motor-rewinding Motor Rewinding in the Philippines - Search Results from PhilippineCompanies.com
  • Feb 04, 2016 | Wahl Health & Beauty
    Keep getting meesage "Main Motor
    Hi Chris,
    This Error Code indicated that the "main motor that drives the OPC, ITB, and Pick-up is faulty".
    Troubleshooting the symptoms is quite technical but If you like it to fix it yourself, just give me your email add and I will send to you the copy of the service manual to guide you steps by steps. Instruction on how to dis-assemble the unit is to long to write here.
    Jdvillanueva
    May 13, 2011 | Samsung CLP-510 Laser Printer
    Clock dial doesn't move
    You posted under Intermatic outdoor sprinkler timer.
    Intermatic clock motors can be replaced.
    Clock motor has identifying numbers printed on motor.
    Tip mechanism out of box using thumb spring located inside box at top.
    Google search for that motor number, for example WG1573 is 240V clock motor for T104 timers.
    Aplus sells Intermatic clock motors:
    http://www.aplussupply.com/intermatic/timermotors.htm
    Electric supply sells clock motors
    http://www.electricsupplyonline.com/prod/intermatic-motors.php
    Intermatic online store is expensive option:
    http://www.intermaticstore.com/
    Add a comment for more free help.
    Also take advantage of fixya phone service.
    For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
    Fixya is always less expensive than a service call.
    Feb 10, 2011 | Intermatic T8845PV - Sprinkler-Irrigation...
    57 service
    57 (or 57.1) SERVICE Message (Main Motor Failure)
    The 57 SERVICE indicates that the DC Controller PCA detected a
    general motor failure. The Main Motor drives all moving
    components in the printing process. The Main Motor is a 4-phase,
    DC servo motor controlled by the DC Controller PCA.
    The formatter detects a Main Motor failure when:
    • The Main Motor does not come up to speed within one second
    of receiving drive voltage.
    • The Main Motor deviates from the correct speed for one second
    after reaching the correct speed.
    Main Motor Functional Checks
    • Inspect the gear train for debris that would block the free
    operation of the gears.
    • Check the gears in the Toner Cartridge for wear and binding.
    • Reseat J211 (or J214 on the HP LaserJet 4 Plus/4M Plus) on
    the DC Controller PCA, and the main connector on the Main
    Motor Assembly. Refer to Figures 7-16 and 7-17 for the DC
    Controller PCA connector locations.
    • If the problem persists, check that the +24B Voltage is present
    on the DC Controller. If the voltage is not present, replace the
    DC Controller. If the voltage is present, and the motor does
    not rotate, replace the Main Motor Assembly (see Figure 7-11
    for location).
    Oct 21, 2010 | HP LaserJet 4 plus Printer
    What is error code e000014-0000 on canon IR3300
    This error is idicating that the fuser motor is not turning. Rotate the green fuser knob to see if it is hard to turn. If freely turning then a gear, motor, or DC Controller board is bad. If hard to turn then try to find what is keeping it from turning. The motor Assy is behind the cover right next to the fuser knob. Good Luck.
    Rate my response!! Thanks, SF
    Jan 28, 2010 | Canon (6981A002AA) for imagerunner 2200,...
    Error code 000051
    From service manual E051-0000 At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
    Main cause The horizontal home position sensor is faulty. The horizontal registration motor is faulty. The DC controller PCB is faulty.
    Action
    1. Connector
    Are the connectors of the horizontal registration home position sensor and the horizontal registration motor connected?
    a. DC controller PCB (J304) <-> relay connector <-> horizontal registration home position sensor
    b. DC controller PCB (J304) <-> relay connector <-> horizontal registration motor
    NO: Connect the connectors.
    2. Sensor lever (damage and interference), Sensor
    Is abnormal noise heard from the horizontal registration assembly in keeping with the motor rotation?
    YES: a. The horizontal registration assembly is out of place because of
    damage to the sensor lever. Replace the sensor lever.
    b. The horizontal registration assembly malfunctions because of the
    presence of foreign matter. Remove the foreign matter.
    c. The sensor is faulty and cannot detect home position. Replace the
    sensor.
    3. Horizontal registration motor, DC controller PCB
    Is the horizontal registration motor control signal generated by the DC controller PCB?
    J304-1/2: 24 V, J304-3/4/5/6: motor excitation signal
    YES: The horizontal registration motor is faulty. Replace the motor.
    NO: Replace the DC controller PCB. Usually E 051 is the horizonal motor problem, you can take out the pick up ***'y. On the motor have a small gear, sometime this gear broken.
    Or the horizontal reg motor became stuck in the wrong position. I was able to manually move it back and rebooted copier. Not sure why the motor was in the wrong position-cust related?
    Oct 10, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
    59.40 error code
    That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
    Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
    Printer error code 5952 - ?
    From the service manual:
    An error occurred with the magenta printcartridge drive motor during startup or rotation.
    To fix:
    1. Check that connectors J5003 on the magenta print-cartridge drive motor and J207 on the DC controller are seated correctly. If they are then:
    2. Replace the magenta print-cartridge drive motor. If that doesn't work then:
    3. Replace the DC controller.
    Jul 08, 2009 | HP LaserJet 3600n Printer
    HP LASERJET 4 PRINTER
    Failure)
    Nov 06, 2008 | HP LaserJet 4 plus Printer
    Dell 5210n Laser Printer Logo
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
