Question about tacoma cover, alternator rear end
Alternator wiring mixup? Car won't shutoff when started.
I pulled my alternator out to have it tested. I forgot to take a picture of the wiring setup. Now I don't know which ones go exactly where. I looked up a basic diagram on the web, then hooked everything up. It started up fine, when I tried to shut it off is when I realized I had a problem. I had to disconnect the + cable to shut him down.
    Top Expert:
  • Toyota Master
  • 21,873 Answers
Not sure I follow you. The alternator should have a main wire going to the battery, and a plug with 3 wires molded into it. It should be almost impossible to hook it up wrong.
I can get you the diagram but I don't know if it will help much.
You may need to go to a salvage yard and get a wiring harness to fit the alternator plug.
On a 2000 model 4 cyl the red wire goes to the gauges fuse, the yellow wire goes to the warning light, and the small white wire goes to the 7.5amp alternator fuse.
Posted on Jul 14, 2013
Just got a new battery 2 months ago, now my battery light is on an the battery died.
Just had a similar issue with my 09 CVPI.
Charge the battery, start the car.
Car starts and is running, good.
Now disconnect the ground from the battery.
The car still runs. Battery or wire issues something is draining the battery.
Car dies. The alternator is shot.
Got to junk yard find one for your vehicle.
My "battery" light came on and I pulled both the battery and the alternator too them to be tested. Both tested good on their systems. Did the above test and changed the alternator. No issues as of yet and no "battery light. Problem solved.
Junk yard alternator $25.00, $5.00 core.
New alternator $355.xx plus tax and $15.00 core.
Core is money I will get back when I turn in the old alternator.
May 25, 2014 | 2004 Toyota 4Runner
Battery Light still on
The new alternator is probably ok.
I would say you burned a fuseable link in the wiring harness.
The alternator has a fuse wire between it and the battery to protect it from overload.
Have someone check the wires coming out of the back of the alternator. The big wire should have battery voltage, the small wires energize the alternator when you start the engine.
Dec 18, 2012 | 2004 GMC Canyon
If i take long distance maybe stop at the garage ma honda ballade 150i model 99 won't start until jumpstart by another car what could be the coz for that.
This could be a alternator that is not charging good or battery or starter or a bad wire or battery connection.
this is easy to figure out , first drive the distance you do and stop at a shop. then try to start car, if car does not start then have them first test the battery to see if it is low, then have them jump it and test alternator, if the battery is good and the alternator is putting out the correct amps then next check starter. if the starter is getting the 12.8 volts and the small wire is also getting the voltage with key in start postion then starter is bad, but with car not starting a shop will find the problem.
Oct 21, 2012 | Cars & Trucks
1991 ford escort battery keeps dying
Check and clean and tighten all battery, starter, and alternator connections. Also the battery and engine to chassis grounds. Did you have the battery " load tested" as a good test requires?
Take the battery out and have it charged up. If the alternator is good, you should not have any more problems. But if you need a jump after a few days to start it, then either the alternator or the battery is just not up to par. Have the alternator tested while on the car and running.
Good luck.
May 16, 2012 | 1991 Ford Escort
Why won't new alternator charge battery when car is running
Many cars have a voltage regulator that is integral to the alternator. Check to be sure it is properly connected. One year later afternoon the day before the Turkey was to be cooked I replaced the Alternator. I drove 200 hundred miles and had the car die at the gate to my destination. I failed to properly connect the Voltage Regulator on the Alternator. Look in that direction for a bad wire, fuse, connector.
May 15, 2012 | 1986 Pontiac 6000
1994 Plymouth Acclaim 2.5, 4 cyl won't start
on the backside of the alternator there should be a large black/grey wire. check to see if there is battery voltage on that wire. If there is not than you have a blown fusible link that is inbetween that wire and the battery. If there is power there than check for power on the dark green with dark blue wire. There should be power anytime the engine is running. If there is no power than there is a problem with that wire in between the alternator and the ASD relay.
Check those two out and let me know what you find.
Feb 09, 2012 | Plymouth Acclaim Cars & Trucks
Replaced altornator 3 times and wire to battery but still won't charge.
if you replaced alternator 3 times , have you had your battery tested ? if battery is bad usually that will cause alternator to keep going bad . try having battery tested . might just need a battery
Nov 09, 2011 | 1994 GMC Sierra
The battery has tested fine, the alternator is fine. But it won't start or hold a charge.
REPLACE POSITIVE BATTERY CABLE.CHECK ALTERNATOR FUSE AND CHECK ALTERNATOR VOLTAGE REGULATOR WIRES FOR DAMAGE.HOOK VOLT METER TO BATTERY FEED WIRE MAKE SURE 12 VOLTS GETTING TO ALTERNATOR FEED WIRE TO ALTERNATOR POSITIVE HOOK UP IF NOT YOU HAVE BLOWED FUSE TO WIRE FEEDING ALTERNATOR COULD HAVE FAULTY BATTERY POSITIVE CABLE OR CABLES CORRODED NEED CLEANING.
Aug 27, 2011 | 2005 Ford Ranger
Battery tests good & alternator tests good on 2002 buick lesabre. keep charging battery and then it does start, but not after driven for about 20 miles, then it won't start again.
Hook a digitalmeter to the battery in your driveway while the car is running. It should read 13.5vdc. If it doesn't, something is pulling it down. We can start there. Looking forward to hearing from you again.
Jun 06, 2011 | Buick LeSabre Cars & Trucks
My son's 96 grand cherokee kill's the battery when engine is shutoff and also when running the volt meter will be o.k. for a bit and then nose dive to 0 volts. had alt. checked o.k.. seemed to start acting...
start the vehicle up and unhook the pos cable from the battery if it dies its going to be a bad alternator or the battery has gone bad.one sure way to know if its the alternator is to un hook the pos cable while the car is running.they can test good even when they arent.
Aug 18, 2008 | Jeep Grand Cherokee Cars & Trucks
tacoma cover, alternator rear end Logo
Top Toyota Vehicle Parts & Accessories Experts
ashburton
Colin Stickland
Colin Stickland
jamie suver
Level 1 Expert
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
