I have recently installed Windows 7 on my Dell Inspiron E1505 (Inspiron 6400). The driver that i have for my graphics (Inbuild-Default) card is not compatible with Windows 7. Where can I find the required driver?
you can always find dell drivers on their website. the ones for ubuntu will not work in windows. windows 7 64 bit are on this page http://www.dell.com/support/troubleshooting/uk/en/ukdhs1/Product/inspiron-15-3521
do you have another card slot to use? try it there and make sure it's seated well btw, you might check to see it's compatible with Dell too, since the card is not plugging into the windows 7 software.
Drivers can be found at this link: http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=PLX_PNT_P4_CEL_170L
However, you might want to consider the instructions below, as many people have had the same issue you're having with getting those drivers to work with Windows 7:
You may need to install the drivers in compatibility mode
for Windows XP
To run the driver installation program in compatibility mode Configure the driver installation program to run in Microsoft
Windows XP Service Pack 2 compatibility mode. To do this, follow these
steps:
1.Locate the executable file for the driver installation program.
2.Right-click the file, and then click
Properties. 3.In the PackageName Properties dialog box, click the
Compatibility tab. 4.Click to select the
Run this program in compatibility mode for check box, click Windows XP (Service Pack 2) in the
Run this program in compatibility mode for list, and then click
OK. 5.Double-click the executable file to start the installation program.
Most of newly users of windows 7 face this problem, so don't worry, you should uninstall your graphics driver, and install more compatible one with windows 7, if you didn't find windows 7 compatible windows vista driver will work.
your audio driver is not helpful for sound card which is you install on your pc.
plaese change this driver.
all windows have different driver for different devices.
so you install the driver compatible with window vista and sound card.
