Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
How to change system - Sony FD Trinitron WEGA KV-32FS100 32" TV
    Top Expert:
  • Sony Master
  • 12,223 Answers
What system sir?
Posted on Jul 11, 2013
What dialog box can you use to change the computer name after windows 7 is installed?
1. Click Start button
2. Click Control Panel
3. Click System
4. Under the title "Computer name, domain and workgroup settings", click Change Settings.
5. In the System Property dialogue, click Change button.
6. Do the changes in the names in Computer Name/Domain Changes dialogue box.
Jun 13, 2014 | Computers & Internet
Need hep programming a new uniden bcd396xt scanner
Unfortunately, you didn't specify if you needed assistance with programming digital or conventional radio systems.. but here is the info for conventional systems. Since a conventional system is really a collection of frequencies, the first thing you need to know is the frequency for each channel you want to program.
  1. Go to the Program System menu and choose New System .
  2. The scanner will prompt you for the System Type. Select Conventional .
  3. When the scanner prompts you confirm, tap YES .
  4. The scanner creates the system with a default name. Select Edit Name if you want to change it.
  5. If you need to change any of the system properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Create at least 1 channel group Each conventional system can contain up to 20 channel groups, and all systems must contain at least 1 channel group.
  1. On the Program System menu, select the system you just created.
  2. Go to the Edit Group menu and select New Group .
  3. If you need to change any of the channel group properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Create at least 1 channel in each group Each conventional system can contain up to 1000 channels in each group, and all groups must contain at least 1 channel.
  1. On the Edit Group menu, select the channel group you just created.
  2. Go to the Edit Channel menu and select New Channel .
  3. Input the frequency for this channel in MHz.
  4. If you need to change any of the channel properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Mar 04, 2011 | Uniden BCD396T Handheld Scanner
Service 100 thousands miles
The 04 was pretty straight forward.
Change the oil and filter when the display tells you to. (Don't forget to reset Oil Life system!)
when the display tells you to change engine oil... Do the following as well:
~Lube Chassis Components
~Check Tires for Air and Damage
~Inspect Break System
~Check Engine Fluids and Washer System
~Check Power Steering System
~Check Wiper Blades
~Check Restraint System
~Lube Body Components (See manual)
~Replace Cabin Air Filter (Located in firewall on passenger side.)
Every 25K miles do the following:
~ Inspect Fuel System, Exhaust System, Accessory Drive Belts for damage or wear.
~ Replace Air Cleaner
Ever 50K Miles
~ If used for Towing - Replace Transfer Case Fluid :: If not change fluid ever 75Kk miles.
Every 100k Miles
~ Change Automatic Transmission Fluid and Filter
~ Change Automatic Transmission Fluid and Filter again at 150k if heavy service
~ Replace Spark Plugs
Every 150k miles
~ Change Engine Coolant (Or every 5 years which ever comes first!)
~ Replace Engine Accessory Drive Belt
optional y are supposed to change the transfer case fluid every 50k if towing
Feb 27, 2011 | 2005 Cadillac SRX
I was trying to uninstall something on my laptop then deleted the wrong thing and i dont know what the name was and know when i try to listen to something the volume doesnt work even if its not on mute
Use System Restore to Undo Changes if Problems Occur
Every time you download or install a new game, application, or software update, you make changes to your computer. Sometimes that change may make your system unstable. Have you ever wanted to go back to the way it was? With System Restore, you can.
System Restore works a lot like the Undo command in Microsoft Word. You can use System Restore to remove any system changes that were made since the last time you remember your computer working correctly. System Restore does not affect your personal data files (such as Microsoft Word documents, browsing history, drawings, favorites, or e–mail) so you won't lose changes made to these files.
Use System Restore to undo changes you’ve made to your computer
Before you open the System Restore console, you may want to save your work and close all programs since System Restore requires you to restart your computer.
There are two ways to access System Restore – through Help and Support or through your All Programs folder.
Through Help and Support:
1. Click Start, and then click Help and Support.
2. Under Pick a Task, click Undo changes to your computer with System Restore.
3. Follow the instructions on the wizard.
Through the All Programs menu:
1. Click Start.
2. Point to All Programs.
3. Point to Accessories.
4. Point to System Tools.
5. Click System Restore.
6. Follow the instructions on the wizard.
Click to go to the
Windows XP System Restore Tutorial
Windows Vista System Restore Tutorial
Aug 26, 2010 | Computers & Internet
How do you change the time on the phones. Since Daylight Savings time My clock is off by an hour
How do I change the Time and Date on a Merlin Legend system?
To change either the Date or the Time on the Legend system, you must program it from the main System Programming console (MLX-20L). This will change the Time or Date on all the display phones throughout the system, except the ATL (Analog) display sets. These phones must be programmed on each individual set.
How to change the Date in the Legend system:
  1. Press Menu.
  2. Press System Program.
  3. Press Exit.
  4. Press System.
  5. Press Date.
  6. Enter date in following format: mmddyy (where MM is the month, DD is the day, and YY is the year).
  7. Press Enter.
  8. Press Exit.
  9. Press Home to exit programming mode.
How to change the Time in the Legend system:
  1. Press Menu.
  3. Press Exit
  4. Press System.
  5. Press Time.
  6. Enter the time in military/24 hour format: HH:MM (where HH is the hour, 01-24, and MM is minutes, 00-60).
  7. Press Enter.
  8. Press Exit
Nov 04, 2009 | Lucent Merlin Legend MLX-20L Phone
I need to change the time.
Must be done on a MLX20-L
Changing the time on a Avaya Merlin Magix system is accomplished from the system programming console. The date is change separately from the time.
Changing the date:
1. Press Menu
3. Press Exit or Start
4. Press System
5. Press Date
6. Enter the date as: mmddyy where mm = month, dd = day, yy = year
7. Press Enter
8. Press Exit or Back
9. Press Home or Exit
Changing the time:
1. Press Menu
4. Press System
5. Press Time
6. Enter the date as: hhmm where hh = hours & mm = minutes
7. Press Enter
Nov 02, 2009 | Avaya MLX 5D Corded Phone
Changing to NTCS to PAL. I've accidently changed
If you haven't solved this yet, just turn off the system. Press and hold the enter button on the front panel. While holding enter tap the store button a few times until you see "Video: PAL ###" and change this back to "Video: NTSC"
Apr 19, 2009 | Bose Lifestyle 38 DVD Home Entertainment...
Can we change Chinies mobile PDA TV Phones operating system
You can't change it. Why?
Because the Chinese mobile doesn't have enough ram (64, 128, 256)MB to run OS system such as the windows mobile 5.0 or 6 or even doesn't have processor such as pocket pc (200,400,...)MHz so no point in trying to change the OS system which has
Dec 17, 2008 | Siemens M56 Earbud Hands Free Headset
Have a philips tv and a home theatre system but the remote off the surround system just changes the tv settings. Its kind of frustrating when I want to watch a dvd! Do I have to assign a freq?
When you press a function key on the remote control, not only does it change the function on the system (eg DISC, TUNER, TV etc) but it also changes the function on the remote.
However, if you change the function or source on the system, then only the system changes.
It sounds like you have changed the function on the system to DVD, but the remote is still set to TV. When in TV mode the remote will send Philips TV codes.
Press the DVD or DISC button on the remote.
May 10, 2008 | Televison & Video
Change the time on the phone system
The time for the phone system must be changed within the system programming itself. We have SuperSet 4025s as part of our Mitel SX 2000 Light system. The technician we use was able to remote into the system and change the time for us. As far as I know that is the only way to do it unless someone in your building knows how to program the system.
Mar 10, 2008 | Mitel Superset 4025 Corded Phone...
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
12 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
