Question about Symbol LS-4071 / LS4071-I111 Barcode Scanner with RL475-I1US Base Station - NO CABLES
Symbol LS4071 Won't Scan
I have a heavily used LS4071 that won't scan. It is charging properly. I have changed out the base. I get a good red line, but it won't read the barcodes. I would reset the options, but I can't get it to scan any of the barcodes from the manual. Any idea?
5 Suggested Answers
SOURCE: I have an LS4071 with an RL474 base. The cable
When I connected this scanner (purchased at a great discount through eBay) to my computer using the keyboard wedge (with a ps2 connection - the round connector) I received the error message that my computer could not recognize this external hardware. I went to barcodediscount.com and ordered the usb connector for this scanner as usb connections are usually recognized. The part # for this connector is STI85-0200R. It cost 72.55 with shipping, but I received the scanner at such a wonderful price that I thought I'd chance it and try it with a usb rather than a keyboard wedge connector.
The computer immediately recognized the usb connection, and the usb connector comes with a manual with codes to enable proper scanning, but still no luck getting the data into the computer. So I called Symbol's technical support department. The technician told me to remove the rubber "boot" at the bottom of the hand held scanner (not the scanner base) by pulling on the front of it (where the 2 little round circles are). It's tough to remove, but keep at it. Then gently remove the battery and unplug it, then plug it back in and reattach the base. He said this would reset the battery. Voila!!!! Sucess!!!!
If your scanner's keyboard wedge connection is recognized (a little popup window will say that it is a Symbol barcode scanner and that it is installed and ready to use), try taking the battery out and putting it back in to reset it. Hopefully this will also work for you. Symbol's technical support # is (800) 722-6234.
Posted on Mar 23, 2009
thesuperdude
  • 97 Answers
SOURCE: Symbol PDT 8100 and I2of5 barcode reading problems
Normally I2of5 comes disabled as default in wavelink software.
You will need to enable it and if you are scanning barcodes of different legths, set both the maximum and minimum to 0 value. This will allow any length.
If you still have problems, get back in touch with me and send me a sample barcode as I have a verifier which will allow me to determine whether there may be a problem or not.
Posted on Mar 26, 2009
thesuperdude
  • 97 Answers
SOURCE: Types of Barcode that can be scanned using Symbol MC9090
It can read all standard symbologies apart from PDF symbologies unless it is equipped with an imager scan engine.
  • 74 Answers
SOURCE: i want to my m2004 to enter barcode scan after each scan automati
Print Adobe pages 128 and 129 of 302 of the M2000 Series Product Reference Guide and scan the "Scan Options" "Data Suffix" and "Enter" barcodes. The scanner will give two beeps after the first barcode, two beeps after the second and a warble after the third programming (Enter) barcode.
The manual can be downloaded from this link: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3969605apdf&sliceId=&dialogID=114420706&stateId=1%200%20114410949
Posted on Jul 13, 2009
I am looking for a way to make sure all scans on LS4071 comes over in Uppercase. Do not want to reverse case, just everything scan in CAPS.
You can generate and print barcodes using uppercase letters. This way, you don't have to do any reconfiguration of your barcode scanner.
Apr 02, 2014 | Symbol LS 4071 Handheld
Hp c4580 on mac 10.6 won't scan
Based on the information you gave this may help:
Go to 'system preferences'
select 'print and scan'
Above the picture of the listed printer select 'scan'
Then select 'open scanner'
Follow onscreen directions from here.
Jun 08, 2012 | HP Photosmart C4580 All-in-One InkJet...
Blackberry playbook red light flashes but it won 't turn on
this happened to me, it needs charging make sure the lead has the blackberry symbol facing up....
May 12, 2012 | RIM Blackberry Playbook 7Inch Tablet...
Won't scan
Hold the right button press for about 10 or more seconds and the menu will appear and you can scan. (the red button with a triangle in the middle on the right of the printer underneath the mini LCD)
Mar 06, 2012 | Canon PIXMA Office Equipment & Supplies
Hello, I have a custom application but the scanner won't work with it. is there some way to enable the scanner to tell it to work. I have a quick scan sample app that works fine, but my custon app...
there are several ways to use the scanner: you can have an application directly with scanner drivers implemented. Or you can install the application DataWedge provided by the manufacturer.
The DataWedge application will activate the scanner and the decoded barcode is sent as usual keypad input to the system. The application is running in background, so you can have your favourite simple application in foreground and scan data directly.
To download the DataWedge application please go to support.symbol.com website and search for DataWedge, or use this direct link http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12685
Aug 04, 2011 | Zebra Symbol Technologies MC909X-G Series...
Symbol LS4071 not charging
I would suggest to replace the battery. Is it the smallest part and also only one which could degrade during the time.
Jul 13, 2010 | Symbol LS 4071 Handheld
Symbol Scanner LS4071-I1us
transltor and data comparison failed?
Jul 27, 2009 | Symbol LS 4071 Handheld
I have an LS4071 with an RL474 base. The cable has the PS2 Keyboard end. Scanner gets a good scan but no data goes into the computer. Testing with notepad open to receive the scan.
Mar 11, 2009 | Symbol LS 4071 Handheld
Symbol LS-4071 / LS4071-I111 Barcode Scanner with RL475-I1US Base Station - NO CABLES Logo
48 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
