Turn off closed caption on insignia - Televison & Video
  • 9 Answers
SOURCE: closed caption
It's all in your menue set up and you need to call or go online to the company for the solution, using your remote to reprogram it correctly. You need to set it differently than cable...I "think" you have it set twice and it basicly doesn't know what to do. It may be seeing it as directly to TV and so the Cable setting would be the wrong setting.
Posted on May 06, 2008
SOURCE: Closed captioning stuck on!!!
yeah i tried that there is a CCD button which controls the CC but it is turned off...also in the menu/setup it is turned off...
Posted on Oct 07, 2008
SOURCE: toshiba 62hx94 cant shut off closed caption have comcast cable
The problem was with the Motorfolla Comcast cable box not my T.V. . I turned off my Comcast cable box, pressed menu on the remote to the cable box. This made a 16:9 ratio appear on the cable box's LED read out, and a bluish screen appear on my television. One of the options on my television was to turn on and off closed captioning. Therfore, I turned off closed captioning and the problem was solved.
Posted on Jan 30, 2009
  • 36 Answers
SOURCE: We just bought a 42'' Insignia, but we cna't get
Did you check settings on the CATV box the also have CC settings. About the gray out maybe your TV is not capable to do CC. Try that!
Posted on Jan 13, 2010
TODDAS
  • 431 Answers
SOURCE: How do we get the closed captioning off
you can turn off using the buttons on the front of the tv go to menu use the vol and channel buttons to navigae go to options and turn cc off
Posted on May 06, 2010
How do I remove close caption wording on my tv screen??? (Insignia 42" TV don't know model number.)
Here is a manual for a 42" Insignia. Hopefully it's similar http://insigniaproducts.com/cms/documents/NS-42LCD%20UM%20EN_SP_FR.pdf
This one says the closed caption settings are in the "system setup" menu.
Feb 11, 2011 | Insignia LCDTV26 26 in. Television
I can't turn the closed captioning OFF on my insgnia flat screen tv model NS-L CD37. i have a universal rca remote & the closed captioning won't go away - HELP !
The problem is that the universal remote is not sending the correct IR signal to your units IR receiver, regaurdless whether or not you turned the captions on with the universal, it is unable to send the signal to turn them off, if you have a menu button on your unit you could try accessing the closed caption option that way, alternatively you can do a system reset, if you can access that menu option, you may need to do a tv retune to get your stations, but the closed captioning should be off. I hope this helps. Good luck.
Jun 07, 2010 | Insignia 37" LCD Flat-Panel HDTV
My brand new Insignia tv has closed captioning that will not turn off. I followed the instructions in the manual but the menu item under settings can not be selected. Please helpw
You can use the TV buttons to get access to close caption by pressing menu. go to features make sure that cc when mute is on.
then use the mute button on your universal remote to toggle to cc1 or off.
May 21, 2010 | Televison & Video
Closed captioning wont turn off
Closed captioning is usually on the original remote, labeled CC.
If not, you can find it within the on-screen menu, under captioning, sometimes it's located under the audio menu, then captioning. Try the remote first, it's usually the one that does it.
Nov 30, 2009 | Insignia Televison & Video
How to turn off closed captioning without orginal remote?
well if it has a menu option go into menu then set up and change cc okay if does not have menu button try to find universal remote w/ menu option and try to change okay
May 18, 2009 | Insignia NS-RTV32 32" TV
Insignia TV and Direct TV Remote issue - cannot get the closed captioning turned off
The TV slowly, all by itself, ran closed caption on the major stations.
Unable to turn off through the menu as that option was greyed out.
Now all channels have this unwanted closed caption.
Any similar problems and ideas.
Thanks, Harold
Jul 07, 2008 | Samsung HCN4226W 42" Rear Projection...
Closed Caption won't turn off
cannot turn off closed caption on 27" insignia. the option screen which illustrates the closed caption category, is not highlighted and you cannot manually choose that option from the remote control.
Dec 08, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
