LE32R86BD manual TV made a loud 'crac' sound and video switched off, TV will not restart, led flashes for remote functions, internal hrc fuse is OK, need ideas or where to find a copy of the service manual for free (unemployed)
tvtek
  • 1284 Answers
SOURCE: 32" Samsung TV, No Power or Sound, power LED on, flashes 3 times
Most likely the set has lost vertical sweep or the feedback from that circuit. This will shut the set down to prevent a horizontal line from burning the face of the CRT. This will have to be looked at by a technician.
Posted on Sep 11, 2009
SOURCE: SONY KDL-40S2010
I2C problem.
Posted on Oct 06, 2009
VinayT
  • 1884 Answers
SOURCE: Toshiba 50HP16 Plasma tv has
Display IC seems to have gone. It will be a replaceable module. Only you have to figure out which one it is. Such thing happen in electronics. Look for any burnt or bulged IC.
Posted on Oct 07, 2009
omaharox
  • 166 Answers
SOURCE: "Function Not Available" error on LG 47LG50 LCD TV
A software upgrade may resolve the issue if not the main Pcb. would need replacement.
Contact LG during normal business hour 8-6 central time.
1 800 243-0000
They may help you out also let them know if you are having a lipsync issue.....Wink wink
Posted on Jan 20, 2010
  • 901 Answers
SOURCE: Adding remote control activated ''mute'' to TV headphone jack
Generally when the head phone jack is inserted the speakers will get disconnected automatically.
If you are going to use external amplifier you can try the AV sockets. Opening the TV you may require the special screw drivers some times.
Posted on Jul 07, 2010
Replaced power supply and reset still on light no sound just a flashing green light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec.
Press Input & Ch Down Switch from LED panel and plug in and start LED
LED will start and "K" will appear on screen
Press Ch Down & Vol Down switch at same time
You will get 1/10 page on screen
Go to 9/10 page by pressing left & right button from remote
Select EEP and press Ok button from remote
After 30Sec remove main plug and restart LED.
Dec 13, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
After replacing power supply and resetting tv still only have green flashing light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
Would like to know the codes for a LG tv, Sony tv, and a TOSHIBA DVD ?
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
Mar 27, 2013 | Televison & Video
I have 153636 5.4 ir remote control I can't Program my sylvania 32" hdtv I tried all the codes in The manual please help
lito3_1416,
Here are the current codes I show available for your Sylvania TV: 722, 908, 569, 590, 566, 600, 610, 568, 764, 632, 573, 652, 654, 656, and 723.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for three seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Please let me know if you need further assistance.
Ray Calo
DISH Internet Response Team
Jun 14, 2011 | DISH Network EZ Remote Remote Control
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jun 12, 2011 | DISH Network IR Remote Control
Tv wont turn on
Check the ff:
1. Power plug - for open internal wire due to frequent bending,pulling.
2. Try to power by remote - if power up by remote then you have a faulty tack switch.
3. Replace Internal Fuse - sometimes because of power surge the fuse fail. However if the fuse blew again this is an indication of shorts.
Next step is not Diy because of the ff reason
3. Voltage regulator - might be open or shorted.
4. H-out transistor - shorted
5. Open fusible resistor in line with the B+.
6.Dry joints
Thanks for using fixya.
Pls rate my help.
Jan 25, 2011 | Hitachi Televison & Video
GE 19GT243 REMOTE CONTROL CODE FOR A RADIO SHACK 3-IN-ONE REMOTE
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Sep 03, 2008 | GE 27GT277 27" TV
I have a rca universal remote control.Model#rcr860 and I lost my manual.I need instructions on how to program.I have the codes.
hope this may help;
Regards,
VOTIT
Aug 12, 2008 | RCA Universal Remote Control
How do i program my remote
hope this may help;
Regards,
VOTIT
Aug 07, 2008 | RCA Universal Remote Control
Can you help me?
hope this may help;
Regards,
VOTIT
Jul 24, 2008 | RCA Universal Remote Control
Televison & Video Logo
Top Televison & Video Experts
