your best sequence to remove PLYM NEO 1P3ES47C7SD237183 NEON
The alternator for a 95 neon
1 first take the right tire off
2 then lift the car
3 then get a 15mm socket and loosen the blots of the bracket
4 then open the hood and undo the power steering and take off the top bot of the alternator
5 then take off the bottom blots and take off the bracket
6 then move the alternator so you can disconnect the wiring i think you need a 10mm for that maybe smaller
7 then pull it out(when i did it to mine it was hard to pull it out)
8 then to put it back just the same way but backwards
mine broke too if you need more help email me ozark99@hotmail .com
thank you for your time we managed to work it out
no power out of alternator
