Question about Vehicle Parts & Accessories
I have a 2006 Chrysler 300 3.5 limited edition w 160,000 miles now I drive 25 miles a day for the past 3 years but I always get an oil change. However last night my oil light came on and disappeared as soon as I was braking to a corner and I've notice an odd ticking noise coming from my engine at firs I thought it was my belt
I am a master technition for Chrysler jeep and dodge. The only issue would be the oil being a little lower then Normal and you braking or going around a corner will create a earth for the warning in the sump no real issue just top it up a little with oil.
Posted on Jul 10, 2013
4 Suggested Answers
vetteman3002
  • 2299 Answers
SOURCE: Driving home from work my
What I would suggest is go out tonight when it is dark and open the hood. It sounds like one of the spark plug wires is not making a good connection with the plug and is firing to ground. When it is dark you will see the spark. It will be very very noticeable.
Posted on Sep 22, 2010
george_karas
  • 207 Answers
SOURCE: engine brake not working
Engine brake light.// Can be low oil on master cylinder or brake pad low/ LOW pressure in the system it has to be check by mechanic for your safety.
Posted on Aug 19, 2012
  • 18 Answers
SOURCE: Engine Brake does not work properly
Check oil leakage from brake pipe or wheel cylender&replace it
Posted on Dec 11, 2012
Should you do a transmission flush on a chrysler 300
If you want it to last 2 or 3 hundred thousand miles yes and have it done every year if you can afford it. You wouldn't except your engine to last if you never changed the oil
Feb 23, 2013 | 2005 Chrysler 300
Have a chrysler 300 awd 3.5l losing a quart of oil every 1300 miles. Is this going to cause more prob.
Oil alone is not enough anymore, I use Pennzoil platinum synthetic and add 1/3 of a quart/ litre of lucas oil stabilizer; to bring up to the full mark. (Add the lucas first.;)(I also use the lucas fuel conditioner every 4th fuel-up.). With all this being said, I hope you have checked the obvious, the pvc valve, take it out and shake it, it should rattle or it's bad, and needs to be changed; If that is not it, Make sure you ck the water/antifreeze to see if it is contaminated with oil. If that doesn't find it, there are special additives to add color to help track leaks, Could you have possible had a loose oil plug or filter not quite tight enough? (**** happens) so again don't be surprised...!!! Could you have gotten taken for a ride at some oil change had someone pull a fast one on you? Due you change your oil and service your car yourself? Also, i did notice on one oil change, an inconsistent situation, i always change my own oil, and one time it just didn't look right, at 5000 k's / 3000 miles the oil was blacker than usual, and when I changed the filter, there was more sludge than usual, which really alarmed me. (I chocked it up to maybe possibly time of year winter snows, cold weather, longer warm-ups / -30 temps BBBBBRRRRR, but I think the same can happen with HOT weather causing the viscosity of the oil to be lost, rember when oil loses it's viscosity ,,, it needs to be changed and this is when it's down 1 litre/quart, (If you can catch it just when this happens, throw a little lucas stabilizer in, 1/3 of a litre, i feel an engine is not really broken in until it has 60,000 miles; (of course it all depends on how you drive it) are you the only driver of the vehicle? back in my younger days, dad's old car could really smoke them tires Ugh Huh,,,,,ha ha ha ha ha ha
Jan 12, 2012 | 2005 Chrysler 300
HI,I HAVE A CHRYSLER PACIFICA 2006 3.5L W SYNTHETIC OIL ,EVERY HOW MANY MILES NEED TO BE CHANGED?
Everyone say's 3000 miles. I was a technician for 16 years, I own three cars. One with 194000, one with 140000 and one with 107000 miles on it. I change my oil every 4000 to 5000 miles. From my experience most engine problems are from a lack of oil, not from a lack of oil changes. Remember to always keep an eye on your oil level.
Dec 09, 2010 | 2006 Chrysler Pacifica
My manual says to use 5w-20. I have a 2006 chrysler 300 v6 2.7. Which brand is best and would using a synthetic be better or worse?
any brand of oil is ok but you have to do the oil change every 3k miles or under
this motor will go bad if you don't do the oil change
synthetic will be better and cost more but you still have to do the oil change every 3k
go only and search chrysler or dodge 2.7 engines
Nov 19, 2010 | 2006 Chrysler 300
2005 chrysler 300 limited burning oil
Try changing oil brands. If you want some good info on oil burnoff rates etc google noac volatility tests.I could explain it here but it would take an hour.
Oct 02, 2009 | 2005 Chrysler 300
Chrysler 300 3.5 v6 Slight engine knock - oil always changed
I have a 2006 with a 3.5 (41,000 miles). No oil consumption but had the knock. Started as a slight knock and continued to get louder. My buddy works at the dealer and hooked me up. Chrysler knows about this problem, it's the rocker arm assembly coming apart. They have a new revised part to fix the problem. THEY NEED TO RECAL THIS.
Sep 02, 2009 | 2006 Chrysler 300
Advice on purchasing a 2005 Chrysler 300 Limited with 98000 miles
Hello scottym88...The chrysler 300 engine is the weak point on this vehicle, the 2.7 litre was a major headache for owners, dealers and Chrysler...the problem was due to engine sludge, poor oil circulation, poor crankcase ventilation, faulty timing chain tensioners...etc...From 1998-2004 the Chrysler 2.7L was prone to Oil Sludge often caused by internal coolant leakage that has to do with the design of the Water Pump that allows coolant to enter the Engine over time and causes oil sludge...result..ENGINE FAILURE. For 2005, changes included improvements to the PCV system and improved oil circulation, to even later increasing oil capacity by an extra quart in an attempt to make the engine more reliable... Unfortunately, even with all of these modifications premature engine failure is common. I've seen this first hand...and the really sad part is CHRYSLER knows...yet refuses to cover prematurely failed engines even when under its own 3 Year / 36,000 mile warranty while blaming consumers for these problems.
If you want to research this further, check out the consumer complaints on this vehicle and/or the 2.7 litre engine. I have been a MOPAR enthusiast all my life, and in my opinion this was the worst engine that chrysler ever released to the public.
Good luck...i hope this helps answer your question..please rate me a fixya.
Jul 27, 2009 | 2005 Chrysler 300
2006 Chrysler Minivan - oil consumption - time is running out
I do not believe there is a fix by Chrysler. My van has 50000 and seems oil consumption is getting worse. It is either past the valve seals or the piston oil control ring. I believe Chrysler KNOWS ALL ABOUT THIS! If you google search this there are to many complaints! 1 quart every 3 thousand miles is not exceptable unless you are driving a model T!
Jan 19, 2009 | 2006 Chrysler Town & Country
Vehicle Parts & Accessories Logo
87 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
