Question about Home
The freezer in my fridge is all time icing up.
What wrong with my Whirlpool model 6WN V47NS the freezer is full of iced cos it supposed to bE frost free.
I've had this happen twice and it was caused by two different issues, one being a plugged drain in the freezer and the other a much bigger problem with a part. Sorry I can't be more helpful; you'll probably need a repairperson look at it.
Posted on Jul 13, 2013
Why is ice forming in freezer
Ice layer inside freezer box floor - Defrost drain line clogged.
Frost or ice on freezer box top - Room air leaking into the fridge from door seals.
Frost on the Freezer box back wall means unit is not defrosting properly.
Sep 04, 2014 | Whirlpool Refrigerators
Electrolux american fridge freezer cooling problem
There is a defrost timer on the unit. It is supposed to come on and melt the ice that forms on the coils in the evaporator. IF you get a lot of ice built up or something is wrong with the timer, it wont melt the ice or it wont come back on to cool the unit.
Dec 09, 2013 | Electrolux Refrigerators
Freezer froze,ice and frost,freezer door froze, warm in fridge
change thermostat sensors in fridge and freezer easy
Feb 04, 2010 | Refrigerators
Freezer is cold and collecting frost, refrig isn't cooling.
you may have to remove the floor of the freezer. At times they fill with water and freeze. and you cannot see the layer of ice under there. This ice can form in the channel that allows the cold air into the fridge. another suggestion would be to put the fridge on the lowest setting then raise it up about 3-4 hours apart. hope this helps. Good luck.
Apr 24, 2009 | Refrigerators
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a whirlpool fridge freezer and there is too much ice in the freezer how do i stop that happening? i have scraped out the freezer with a plastic spatula and dont want a build up again
If this is a model that is supposed to be frost free you have a defrost system problem. Scraping the ice off is only taking the surface ice off and doing nothing to remove the ice behind the panel that is stopping air circulation and heat from getting to your cooling coil for removal.
If you can located the defrost timer and rotate the clutch head screw clockwise very SLOWLY until you hear one click. This puts the timer into the defrost mode. Wait about 25 Minutes( Unit should restart after 18-22 minutes). If the unit does not restart automatically rotate the time to the second click. If you had to do this it means that the timer is at fault and needs to be replaced. If it does not defrost and the unit restarts automatically then your problem is on the defrost heater circuit.
May 24, 2008 | Whirlpool Refrigerators
Home Logo
65 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
