Question about Bosch SHU9915UC Dishwasher
Diswasher Leaked, now Won't Work
Hi, Our Bosch has run without trouble for six years, but yesterday I discovered a puddle outside it and the machine in an endless growl. I think that's the pump trying to remove water, but the dishwasher was almost dry. Dishes were clean. Now the machine merely growls whenever I turn the power on. Buttons appear to work to start a new cycle, but as soon as I shut the door the growl is back and no water enters. Any advice on simple things this mere homeowner can do to check out and possible fix the trouble? Thanks.
  • 1 more comment
  • franzmetcalf Aug 27, 2007
    bigg t,
    Thanks for the strategy. I'll look around in there and see what I can find. It makes sense that the float would be stuck, making the poor thing believe there's water when there's not. Am I going to need to pull the unit out for this kind of thing? I guess I'll find out soon enough.
    Thanks.
  • franzmetcalf Sep 04, 2007
    Hi all,
    Amazingly, the problem is fixed. All I did was to prime the drain pump by pouring in a couple liters of water. I put the water in, set the dishwasher to start and the machine performed flawlessly. I guess the trouble was simply with a faulty seal when we did the dishes the previous time.
    I really appreciate the help folks have given me here. This is how the internet can make the world better.
    Franz
  • Anonymous Mar 20, 2008
    kitchen aide water not coming in
Tip your dihwasher ono its right side (as you look at it from the front)you will get a spillage of water then right it that should free the float
Posted on Sep 02, 2007
  • 640 Answers
If you see a float inside of the dishwasher make sure its cleaned well.that float tells the control board when to drain and to fill with water.the symptom you descibe tells me its trying to drain,make sure the float moves freely.if you dont have a float you will see a metal probe clean that up as well.try this and if it doesnt fix the sensor may be part of the drain body and it has failed(leaking).
Posted on Aug 27, 2007
  • anthony james
    anthony james Aug 27, 2007
    just open the door and look inside.
SOURCE:
Bosch diswasher,model Sms68m02AU trips circuit breaker
rcd units trip from the milliamps that are in a short
it trips the rcd to prevent electrocution and acts in nano seconds besides being a circuit breaker for excessive current
the trip can be from moisture allowing a current leakage to ground or some other simple operation
I suggest that you get in a qualified electrician / bosch service technician to find the reason for the problem rcd
Sep 15, 2016 | Bosch Dishwashers
My new Bosch B26FT70SNS fridege which i got delivery yesterday morning compressor motor won't turn off. Since yesterday afternoon around 5pm until now 11am. More than 18 hours continue running, the...
HI JAMES.ummmm new bosh...should work.if not and motor running cont.then it sound to me like is out of refrigerant or motor faulty.check condenser unit.should hot.if cold call under warranty or replacement i would say.good luck Ali
Jun 30, 2012 | Refrigerators
No control panel lights on Bosch SGV43A03GB/17 diswasher
i have nearly the same problem ! but my one have no water left in it !but pump still running if i put bucket of water in it will drain it away but no lights on panel and anyone know what that is please ?
May 14, 2012 | Bosch 24 in. SGV43A03 Built-In Dishwasher
Water is not collecting properly in the bucket. I ran it for an entire day, and only about half an inch collected in the bucket while more than that amount of water leaked from the unit. There was a puddle...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 30, 2011 | Soleus 8649045FB Dehumidifier
I have a problem that appears to be a bad motor on a Whirlpool dishwasher. The motor costs $300 and the dishwasher is about 6 years old...Does it make sense to replace the motor or just replace the...
Hello, W/D here.
I try to work replacement vs. repair like this:
If the cost of repair is greater than 50% of replacement, I always go for the replacement. My reasoning is that the remainder of the appliance is more likely to develop faults, and a new one is less likely to be trouble.
My 50% rule can go down lower if I have already had any trouble with the machine, or if it has significant age on it.
In my opinion, your case is right on the bubble.
I have replaced motor/pump components, only to have the pump go out again after six months ($200). When faced with another $200 for the same repair on the same machine (with me doing the work), it became too much to bear. I elected at that point to replace it. You very well may get another six years out of your dishwasher, but then again, you may not. In the next six years, other things may break. If you feel like your machine will be serviceable for the next six years after making your repair, then go for it. On the other hand, a new machine will have a warranty, and an extended warranty will be offered at extra cost.
I guess what I'm trying to say is that you could go either way in my equation, and still be OK, probably. Let your feelings guide you, and you'll make the right decision.
Best regards, (and let me know what you decide), --W/D--
Feb 28, 2011 | Dishwashers
Bosch tankless watwer heater GWH 2700 ES NG - no error codes. I have low water flow on my hot water and unit will not start? reviewed trouble shooting guide, tried everything - no solution?
The unit is plugged up with mineral buildup from the water going through it... it will need to be cleaned internally....this is done by running an acid solution through it to clean out the mineral buildup...
Then it will work again...
heatman101
Feb 01, 2011 | Bosch AquaStar 2400ES-NG
My Bosch diswasher SHU5312UC runs down to one min and won't pump the water in or out.
hi,theres a overflow swich it the pan under the dishwasher...it might be sticking or your control board behind the disply for 1 min..is bad...call i will fun you through it...
May 12, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch diswasher SGS5942 does not heat up
this is a common problem with dishwashers.the thermostats are faulty and be replaced by someone who knows what they are doing.
Oct 24, 2009 | Dishwashers
Bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Dec 17, 2008 | Bosch Ovens
Bosch SHU9915UC Dishwasher Logo
174 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
