Question about Kenmore Dehumidifiers
Kenmore 50701 won't turn on. #8 displays with loud continuous beep. Any ideas?
It had not been running for some time and I moved it to a different location and plugged it in.
2 Suggested Answers
  • 5 Answers
SOURCE: We own a kenmore dehumidifier
It should move unless it's been glued shut. I'd try with a handle of a hammer and knock at where you would put your hand to open it and nudge one end at a time.
Posted on Jul 17, 2011
Followed turn on instructions in manual.CO display 2 days. continually. Unit gets Very warm & fan runs if turned off. Have to unplug to stop. Unit used approx.3 mo in '14 & just restartd this week.
could you be mistaking the room humidity indicator for the time? reason I ask is on these one display units this happens more frequently than Id care it too , the one display shows both time and room humidity also set point humidity , the only way one can tell is on some models there is a tiny light that shows up next to labeled function , easy to miss It , also if your machine is sort of new (last few years) it has been decided that it's more efficient to let the circulation fan run all the time , regardless of room humidity . this makes it a little annoying (noise) but they do cycle the compressor to regulate the room humidity
May 28, 2015 | Dehumidifiers
My Kenmore dehumidifier fan runs all the time & compressor kicks in & out. I the fan supposed to run continually.
yes if its less than two years old the new ones run the fan all the time and cycle the compressor off humidity of room , the fans even have speeds on some models so you can turn em down
Nov 08, 2014 | Dehumidifiers
Why does it turn itself off and continuously beep
water retention bucket full ???
or maybe sensor inside bucket is out of alinement ??
Oct 17, 2014 | Dehumidifiers
We own a kenmore dehumidifier model 50701 and the water container is stuck-any ideas of how to remove it?
Jul 16, 2011 | Kenmore Dehumidifiers
I have a 580.54501801 dehumidifier and it shows a code of 01 on the display and doesn't do anything after that but beep 2 times. What does that code mean and is it worth sending it to a shop to be...
Its not worth sending it to the shop! Dehumidifiers are made extremely cheap dont waste your money you will regret it later trust me. Sounds like circuit board issue costs almost what a new one runs.
Jun 23, 2011 | Kenmore Dehumidifiers
My Kenmore dehumidifier has stopped drawing water from the air to the collection receptical. Fan still runs at high and low speeds.
A couple of things may be happening: The humidity extraction level may be set to high and it can't extract any humidity at that level. Reset/Lower it to 35%. The fans on most dehumidifiers run almost constantly (designed that way) so that it keeps moving the air around. If the sensor picks up a higher humidity level than what it's set to maintain, the compressor will turn ON. This is particularly true, if you operate the unit in continual mode, rather than a timed mode. Also, a dirty or clogged air intake filter, hinders the units ability to remove humidity/moisture.
In addition, operating the unit is ambient air temperature of between 40 & 60 degrees F, causes the unit to struggle to dehumidify the air and the fan to run continuously. Obstructing the air flow around the unit, will also cause it to not function as it should. Maintain a minimum of 12" of free air space around all 4 sides of the unit.
Hope this helps you troubleshoot and solve the problem. Please let me know.
May 28, 2011 | Kenmore Dehumidifiers
Makes a loud beep every minute or so. Doesn't seem like basket is filling with water either.
Turn the Master ON/Off Switch to OFF and unplug the unit. Remove the air intake filter and clean it. Allow it to thoroughly dry, before reinstalling it. Once the filter is thoroughly dry, reinstall it, plug the unit back in and turn the Master ON/OFF Switch to ON. Set the humidity level at 35% and allow the unit to run as you normally would. The beating should have stopped, since you cleaned the filter. Be sure to maintain at least 2 feet of clear air space around the dehumidifier.
Hope this helped you to solve the problem. Please let me know. Thanks.
May 24, 2011 | Kenmore 54501 Dehumidifier
My dehumidfier won't shut off. I check everything out and it's good but it just won't shut off it keep running.
It may be, that you have it running in continuous mode, rather than timed mode. Also, most dehumidifiers fans will run almost continually, to keep the air moving, so the humidity sensor can pickup and increase in humidity, if there is one.
If the above doesn't seem to be the problem with your unit, turn The Master ON/OFF Switch to OFF and unplug the unit for 12-15 minutes. This will give the electronics time to reset themselves, if necessary.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 23, 2011 | Fedders A7DH45B2A Dehumidifier
Slight beep but no action/can't get the back off
I had the same problem (minus the cover issue) . To get the cover off, take off all visible screws. Slide a small screwdriver into the space between the back and the side cover. You will see a slight opening where the tabs fit in, you will need to carefully pry the tabs out. However, most likely your problem is with the front panel. You take the front panel off much the same way. 2 screws are concealed by the bucket. I had the same beep no display, thought it was the main pcb, which I ordered and installed. That did not fix it. I cleaned the display pcb, and jiggled the buttons, that seemed to fix it. I think the button to increase the humidity was stuck closed, as I could replicate the problem by holding that button down and then plugging in the dehumidifier. I would start by cleaning or replacing the front panel pcb, which is about $14.
Jul 28, 2008 | Kenmore 54701 Dehumidifier
Blinking bucket full light and humidity setting stuck at '01%'
yes but i might be late. if you still have this let me know
Jan 09, 2007 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
