Question about Coffee Makers & Espresso Machines
Siemens TC55 coffee machine trouble
It spills coffee on the inside of the machine not making even a 1/4 of a cup when set on large coffee.
  • Bentley Price-Moore
    Bentley Price-Moore May 06, 2014
    Sounds like the gasket/seal on the brew unit piston is broken. It is easily and cheaply replaceable - get from a Saeco dealer - the Siemens TC 55 is a re-badged Saeco Stratos machine.
Noggin
  • 944 Answers
SOURCE: Krups Nespresso FNA2 coffe/cappucino machine
First thing to try is a descale. Run the machine normally using it (as if making a cup of both types) a couple of times with a 50/50 mix of white vinegar and water. Leave the machine off but uncleaned overnight. run a couple of cycles with just water, and if there is still a slight vinegar taste then run a cycle with a teaspoon of baking soda in water, then flush with just water again. If this doesn't solve the problem, try again with 75% vinegar. If still not working, there is either a control board problem (may be solveable), or the valve/solenoid that stops/allows the water is sticking, almost certainly solveable by taking that apart and cleaning/lubricating. Definitely solveable by replacement. Let me know what you get after a descale if no luck. Hope this helps :)
Posted on Aug 20, 2007
  • 3 Answers
SOURCE: Siemens Espresso machine TK54001 water leaking inside into the tray
Check for a bad o-ring behind the removeable brew group where it attaches to the boiler. I have seen them go bad in as short as 1/2 year.
Posted on Aug 23, 2008
SOURCE: My machine only brews 1/2 cup of coffee. I have
I had some coffee grounds stuck up in the cone shaped hole that the water comes from at the top. I had to use a very long toothpick but it broke up some of the grounds that happened to get caught up inside. Before doing this, I went through 24 oz of vinager ;) .. the toothpick worked!
Posted on Sep 30, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: My Keurig just started only filling my mug 1/2
Have you tried following the descaling procedure given in your owner's manual? The mineral build-up from hard water can cause low flow, and since the machine pumps for a fixed time this means less water in the cup. Descaling usually brings back normal operation.
Posted on Mar 06, 2010
  • 1089 Answers
SOURCE: I can make coffee but end up with a large puddle
Hi
I would suspect the boiler is leaking. If something was broken you wouldn't be able to make a coffee. You will probably have to replace the boiler. If you need on I have them.
Posted on Nov 15, 2010
Manual for a Siemens TC55
http://www.siemens.owner-manuals.com/TC55-owners-manual-SIEMENS.html
Feb 14, 2015 | Coffee Makers & Espresso Machines
Coffee is way to strong
Change the settings to Large Cup.
Jan 07, 2013 | Keurig Platinum B70 Coffee Maker
My Keurig is only making 1/2 cup of coffee on the large setting. Then about 1 minute later, the other 1/2 comes out. Why is this happening, please?
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 07, 2011 | Keurig B70 Coffee Maker
Only brews half a cup on the largest cup setting?
1.Power off machine.
2.Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep.Insert it into slot on right side and again from back of needle.
3.Remove KCup cradle.Separate bottom from top.In the top section, insert the paperclip up into bottom needle from the bottom upwards.It will not go all the way thru and this is normal.
4.Reassemble KCup cradle and reinsert it back into coffee maker.
5.Power on machine.
6.Brew a cup of water only.There may be coffee grounds in the water and these should eventually clear during the remaining steps.NOTE: A large cup brew cycle should output a full 8 ounces (235cc).Less means there is still a blockage
7.Empty reservoir and fill with undiluted distilled white vinegar.Repeatedly run brewing cycle until Add Water light comes on.
8.Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9.Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10.Set Auto-OFF, if preferred.
Mar 26, 2011 | Keurig Special Edition B60 Coffee Maker
Hi. When I try to make a large cup of coffee, the machine makes more like a medium size cup. What can I do to fix that and get a true large cup? Thanks.
Hi!
When making a cup of coffee hold the button in until the coffee reaches the height you want then release button. You can set the 3 sizes in this manner
Ray AU
Feb 09, 2011 | Saeco Royal Professional Espresso Machine
I get lots of watered down coffee. It brews 3/4 cup but it is so watered down. We have descaled etc. I want a thick expresso like taste. This is on a large cup setting Help?>
HI
When you run a lot of water through just a little coffee it gets water down. Try making 2 meduim cups instead. When they make espresso its 1 tablespoon to 1 oz of water. Your running 6 oz of water through the same amount of coffee, and its going to be weak. Program you buttons for 2 shots to fill your cup and it will be pretty strong.
Jan 25, 2011 | Gaggia Syncrony Espresso Machine
Did not make the large cup of coffee. Then we de-scaled the machine with vinegar. The computer seems off. The hot water is coming back into the water reservoir.
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Nov 21, 2010 | Keurig B50 Coffee Maker
Why does my keurig require me to set the process in motion 3 times just to get 1 regular cup of coffee.
Sep 12, 2010 | Keurig Platinum B70 Coffee Maker
Keurig coffee
Apr 28, 2010 | Keurig Elite B40 Coffee Maker
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
Apr 14, 2009 | West Bend 58030 Coffee Maker
Coffee Makers & Espresso Machines Logo
104 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
