Question about White Rodgers Water Heaters
Thermostat started beeps every three minutes
Our White-Rodgers Thermostat 90 Series 1F95-371 started beeping about every three minutes today. The settings seem to have switched from "cool" to "auto" overnight and when pushing the buttons nothing happens. Any suggestions would be very helpful. Thanks.
  • White Rodgers Master
  • 16,181 Answers
Change the batteries.
Posted on Jul 18, 2013
Testimonial: "The Thermostat is hard wired, but thanks for the advice. We actually ended up replacing the thermostat with a brand new one."
2 Suggested Answers
  • 3287 Answers
SOURCE: We have a White-Rodgers 90
Susan, the "90" series of thermostats covers a couple of different thermostats made by White-Rodgers. Here's how to find your model number. With that info, I can check the manual specific to your thermostat.
In the mean time, check the display for the word BATTERY or BAT. (Flashing) on the display. Battery flashing or blinking on the digital display indicates low batteries. If the batteries have recently been changed and the thermostat continues to indicate low batteries, use a pencil eraser to polish each of the battery contacts inside the back of the thermostat. Do not bend them up and down when polishing or you might break them. When complete, they should all be as shiny as a mirror. This will assure proper battery back-up, allow the backlight to work correctly and remove the flashing battery symbol from the screen. Battery (Solid) on Display The battery symbol (not blinking) indicates a loss of power (24 volts) from the heating and cooling equipment to the thermostat. Normally the heating and cooling do not operate when the battery indicator is on. If the battery indicator is on, check the fuses or breakers, make sure the furnace is switched on, and verify the blower compartment door is closed properly. The battery display is designed to indicate the thermostat is running on batteries, so replacing batteries has no effect on the indicator. See No Heat/No Cool for more information. Note: Some heat only systems (zoned systems) disconnect power from the thermostat during a normal heating cycle and display the battery symbol. Millivolt heating systems always indicate battery because they do not supply 24 volts to the thermostat.
A beep often is provided as audible feedback when keys are depressed on many thermostats. You should check to make sure that no key is stuck in the "in" position or is otherwise activated.
Posted on Jan 10, 2011
Sequencer wiring
This manual provides specifications of the timers and contacts, and a description of the 3 types of contacts.
http://s3.supplyhouse.com/product_files/White%20Rodgers%20-%2024A34-6%20-%20Install%20Instructions.pdf
Mar 05, 2014 | White Rodgers Water Heaters
I need help reprogramming a White Rogers thermostat Please call 352-561-6082
you need to look at the model number and then give me a call back and I will help you fine a way to get you hot water
Sep 08, 2011 | White Rodgers Water Heaters
Thermostat read out changed to cel instead of faren. .. How do I change it back?
hello cwest.... If your thermostat is reading Celsius instead of Fahrenheit press the 'Set Time' & 'Hold Temp' buttons at the same time to toggle it back to read Fahrenheit again.
J.
Jul 16, 2011 | White Rodgers 0754-1 Electric Water Heater...
My white rodgers control panel is set on vacation (green light) is on. I have held down the arrow buttons to get it off of vacation mode but it is not working. Obviously i need to switch it off as we have...
Water heater and gas valve are not clear:
Add a comment with description of water heater and gas valve for possible help.
Open following link for White Rodgers intelli-vent gas valve thermostat:
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#Intellivent
1) Typical instructions for Kenmore and AO Smith water heater with Intelli-vent say:
Set on-off switch to ON position.
Hold down both arrow buttons for 1 second.
Then press hotter button.
2) Also check that 120Volt electrical outlet has power, and check outlet with cheap circuit analyzer from home center.
3) If Intelli-vent gas valve thermostat is malfunctioning, and won't reset, then contact manufacturer of water heater for replacement gas valve.
Label on side of tank will have Model number, manufacturer, type of gas LP NG, serial number for part ordering.
Add a comment for more help.
Jun 10, 2011 | White Rodgers Water Heaters
I have a white Rodgers ac thermostat and the temperature in my apartment stays on 88 no matter how low I set the temp. If I turn it off, of course it gets even hotter. This started happening when I pressed...
I'm not quite sure I understand what you have done but, make sure your compresor(outside is running and, that you don't have the thermostat set to "fan". You want the display to show "cool" and then adjust your temp. It sounds like you have the system set to fan and not cool. Provide me with a model number and I will see about getting you a manual.
Jun 04, 2011 | White Rodgers 0754-1 Electric Water Heater...
We have a White-Rodgers 90 series thermostat that started beeping last night. We have had it for about 4 years. Does it have a battery? I couldn't find anything about that in the manual.
Jan 10, 2011 | White Rodgers Water Heaters
White rodgers motor turning heat not going thru
This item is a buy -out from Thermodisc send a inquiry to there contact us.
Link: Contact Us
Dec 10, 2009 | White Rodgers 0754-1 Electric Water Heater...
Water Heaters Logo
224 people viewed this question
Top White Rodgers Water Heaters Experts
Donni Steen
Gil Shultz
Are you a White Rodgers Water Heater Expert? Answer questions, earn points and help others
