Question about Packard Bell Computers & Internet
Microphone works but seems mute
Easynote tk36 headset microphone not working
    Top Expert:
  • 12,223 Answers
Go control panel and use the utility system restore, and go to the date that you know was working goo and try it
God bless you
Posted on Jul 10, 2013
acdr
  • 1913 Answers
SOURCE: Microphone Won't Work
check your cpu port for microphone to motherbord.
or may be microphone may be faulty.
Posted on Oct 22, 2008
antilez
SOURCE: microphone Presario C700 not working
Just download audio driver from this link
http://www.mmoogle.org/compaqc751nrwindowsxpdrivershowto
I am sure it will work.
Posted on Nov 15, 2008
  • 71 Answers
SOURCE: microphone not working for presario c700
If it has Realtek device drivers check through that not WDM. Also, make sure you set the record settings for the mic to select it, not the play settings.
Posted on Jul 25, 2009
  • 23 Answers
SOURCE: Computer Does Not Detect Headset Microphone
Sound and Recording jacks stop working on the DV6000 series due to the ribbon cable running under the power button. when the power button is pushed it bends the flex cable and over time it breaks the connection rendering the front jacks useless you can buy a new upper button panel for about 20 dollars on ebay
Posted on Aug 02, 2009
  • 166 Answers
SOURCE: A135 Series on XP Microphone Wont Detect Sound
your laptop might have the microphone listed but it might just be a port to plug one in.thats the way mine is.
Posted on Aug 09, 2009
Tk36 bios recovery
NORMALLY IF YOU ACCESS BIOS IS FOR DO SOME SET UP CHANGES,LIKE BOOT OR POWER OPTIONS.BIOS HAS NO NAME,JUST THE BIOS NAME IS THE MANUFACTURER OF THE BOARD.IT SEEMS THAT YOU LOST OR CORRUPTED YOUR OS?PLEASE NEED MORE INFO.
Apr 26, 2012 | Packard Bell Computers & Internet
Bought several pairs of wired eaphones fo son ash can hear his friends but they cannot hear him have phoned customer service team to solve the problem but not solved
Most likely, it isn't the wired headset that is the problem. It may be the controller. If you haven't already, try testing the headset with another controller.
Since hearing and voice are two separate functions, it may be that the controller is only able to send out sound, but not able to pick it up. Test it out with another controller, and hopefully it will work.
But may I suggest a common issue that is overlooked:
Double check the microphone is not muted. (both in the settings of your Xbox 360 AND the mute option found on the wired headset. It's by the volume.) To check this on your Xbox 360 click on the "home" button (top middle part of the controller with the Xbox logo) go to settings ---> preferences. There you will see the option to mute the microphone.
I sincerely hope Microsoft already suggested all of these things though.
Also, better double check that the Microphone isn't muted in Preferences BEFORE trying another controller because if it is muted in Preferences, (which can only be done when signed into a profile) whichever controller he uses, it will be muted to do preferences being set to any controller/headset used. So please double check that it's not the microphone that is muted to start, and then double check the headset isn't muted (on the actual headset) followed by changing controller if it still isn't working.
Hope this was of some help.
Feb 01, 2010 | Microsoft Xbox 360 Console
Cannot get microphone to work while connected to computer.
I found this on the Turtle Beach website: ________________________________________
Let's make absolutely sure that the microphone in your headset is working correctly. If the mic is working, a replacement talkback cable should fix it. If not, then please send in your name, shipping address, the name of the store where you purchased your X1 and the date (month/day/year) of purchase.
OK, here's how to test the X1 using the Microphone input on your PC:
1) Take the pink plug from the X1 and plug it into the pink jack (Microphone input) on your PC's soundcard.
2) Take the green plug from the X1 and plug it into the green jack (Front L/R Out or Line Out) on your PC's soundcard.
3) Take the USB plug from the X1 and insert it into a USB port on the PC (not a USB hub, please).
4) In the soundcard's control software, enable the Microphone for playback. In the Microphone > Advanced settings, enable the Microphone Boost. Make sure the Microphone is not muted (Mute switch is not enabled).
5) Adjust the volume for the Microphone to about half-way up.
6) Adjust the overall playback volume to about half-way up.
7) Put on the headset. Make sure the Mute switch on the X1 amp box is not set to Mute (the LED should be green).
Now speak into the microphone. Do you hear your voice in the headphones? If so, the mic works and your X1 headphones should be OK. If you still cannot get the X1 mic to work over Xbox Live, then you need to take a closer look at Dashboard settings and other connections, or check the integrity of your X1-Xbox Controller Cable.
In order to enable the chat make sure that the Mute button in the Off position. If it is on the ON position the Mic will not work.
Red = Muted Green = UN-Muted
_________________________________________________________________
If you're having trouble adjusting the Mic in Windows:
WINDOWS XP:
For Windows XP, there's a nice video on YouTube that takes you through all the steps of setting up your microphone: http://www.youtube.com/watch?v=Vissxo8furo
WINDOWS VISTA:
Please follow these instructions to configure your microphone within Windows Vista:
1. Left-click on the Start button. The Start Menu will appear.
2. Left-click on Control Panel. The Control Panel will open.
3. Left-click on the Hardware and Sound option. The Hardware and Sound window will open.
4. Left-click on the Sound option. The Sound window will open.
5. Left-click on Recording from the three tabs at the top of the Sound window. While in the Recording tab of the Sound window, you will see all options available for recording - Microphone should be one of them. (If you don’t see an option for Microphone, ensure your microphone is plugged into your computer using the jacks commonly located on either the front or back of the machine.)
6. Left-click on the Microphone option to highlight it. This will enable the Properties button toward the bottom-right of the window. Left-click on the Properties button.
7. You should see the Properties for your recording (input) devices. One of these should be Microphone.
8. Left-click on the Levels tab (or similar). Adjust the Level (Volume) and Mic Boost controls to at least half-way up. If your Mic Boost control is a simple check box, please make sure it is checked (Enabled). You should hear your microphone in your headset or speakers.
Once the levels are adjusted to your satisfaction, left-click OK and OK to save your settings. You can then close the Control Panel.
Your microphone should now be ready!
Apr 17, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
Blinking green light on microphone, headset not working
The blinking light means headset is muted. Un-mute the headset by pushing the small toggle switch on the back of the headset.
You may need to reset the headset. You can do this by first pressing the mute switch on the back of the headset and then simultaneously pressing the call switch on the side of the headset for about 4-5 seconds.
You will need to pair the headset with the base again.
Mar 13, 2009 | Plantronics CS55 Wireless Headset
No sound from headset
MUTE THE SPAKER SOUND AND ADJUST THE SOUND SETTING FOR HEADSET
Jan 26, 2009 | Audio Players & Recorders
No speaking ability
The mute button on these is the little black button on top of the earpiece. It will only be on if you turn it on during a call. If you turn the headset off, the mute button goes off as well.
Check the compaibility 'wheel' on the side of the base station. The most common setting is 1 but some phones use 2,3 & 4. Just try it on each setting until it works. Other than that, check the microphone volume adjust setting underneath the base (ABCD switch) and see if changing that makes a difference. Of course there is always a small chance that the microphone is dead.
Oct 31, 2008 | Plantronics CS50 Wireless Headset
Microphone doesn't work
go to the control panel, sound and devices, voice test hardware there you can check your headset is working or not if working there voice playback or voice recording both check the volume if mute then unmute it
if solve rate me
Sep 27, 2008 | Intel REALTEK nc-r150201 Network Adapter
H700 - microphone not working or am I on mute?
Ok here is the answer. There H700 have a small foam windscreen inside over the microphone that over time block the sound. The answer is to carefully open the unit and remove the obstruction and clean residue from the microphone and it will work like new. here is a link to pictures and instructions. http://www.geocities.com/jconkwright/H700fix.html
Jul 23, 2008 | Motorola Mobility H700 Wireless Headset
I get no sound and my my microphone doesnt work.
man this is all **** i got same problem no one knows how to fix !!!
Jul 22, 2007 | Logitech 250 Headset
Computers & Internet Logo
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
