Question about Intel Computers & Internet
Bios IC Corrupt
How to solve the problem
  • Intel Master
  • 3,799 Answers
Go to the motherboard makers website and look for the instructions on flashing your BIOS. There will also be a copy of the latest BIOS file for your board.
Posted on Jul 10, 2013
Bios corrupt
open the computer and disconnect the small baterry for CMOS and BIOS, measure the voltage +3vdc if doesnot have replace, clean the contact battery, when your disconnect all information is clean.
Now you need download the new BIOS update from your computer supplier and installing.
God bless you
Jul 10, 2013 | Intel Computers & Internet
Lost the password to enter bois what do I do? Just keeps rebooting
The best way to clear BIOS password is to remove the bios jumper or CMOS battery, as it involves hardware tampering, DO NOT try it yourself, instead call for a good technician.
On the other hand, if it keeps rebooting, then it may not be a BIOS
problem, OS can be corrupt also. In that case, re-installing the OS can solve the problem.
Nov 27, 2010 | Microsoft Windows XP Professional
Ic mobile sempron booting but not reading master drive.
Check the BIOS setting for the master drive or the boot drive sequence. check if the HDD cables are intact. there could also be possibility of a corrupt HDD
Nov 13, 2010 | AMD IC Power CN5560 Laptop
My ASUS P5QL Pro motherboard will not boot up correctly quite often. I have swapped RAM, power supple, video cards and i made no difference. the last time i pulled the bios battery and the bios chip,...
i had just solved this problem yesterday, there this symptom below please checked.
1.won't boot after power on button 2.LED on motherboard is light
3.unable to BIOS setting screen 4.CPU fan doesn't work
How to solve
How to solve
1.Please find this IC on motherboard EPU asp0800 near the CPU Socket
2.Press the IC with finger,at the same time press the power buttom
(If CPU fan is running on short time please do step 3 )
3.Power on your soldering iron and contact each side of this IC about 3 seconds( soldering iron to contact IC lead left to right or right to left)
4.Review each side of IC and check any short between IC lead5.After step 4 done, power on pc again, if PC booting congratulation
6.Final check: put finger on ic top side surface (don't touch the IC lead)feel the temperature if too hot that's mean short between IC
lead,please rechecked step 4
Sep 24, 2010 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Intel SE7501BR2 cant get it to boot any os except ubuntu, curious that it boots and installs ubuntu have the drivers disk for the board but it wont boot tring to install winxp also it keeps giving me...
press delete during boot up process enter BIOS then f1 for general help then run chkdsk/f which will automatically fix any corrupt files on your hard drive
hope this helps good luck
Sep 04, 2010 | Intel Server Board SE7501BR2 Motherboard
How to update bios?
WARNING....
dont ever you try to update BIOS....it will more offten screwup the BIOS than fix it....rather it's a tricky to first do it...only experts ever should make changes to BIOS....
BIOS are basic input and output system files (programs written specialy for that chip) inside the Motherboard....there is no way to recover updated BIOS chips and programs gone corrupt...
The present BIOS is good enough to work... dont change if it does not require a change....
A sincere adivce from an expert who has had/solved these issues in the past...
all the best....
Jul 10, 2010 | IBM Computers & Internet
Cpu volage problem
restore your bios defaults and it should work fine and don't mess with your voltages as it can become very unstable hope this has been of help
May 21, 2010 | Intel Motherboard
I have a corrupted BIOS (Intel 440BX motherboard) with Phoenix bios 4 release 6 (release no. 4S4.EB0X1.86A. 0011.P04). Cannot find the correct bios software to rectify the problem (even the bios software...
Hi, Read this information it might help you. Go to this web site www.hardwaresecrets.com/article/39/2 I hope this information will help you solve you bios problem.
Aug 17, 2009 | Computers & Internet
P5AD2E deluxe bios wont load even after i flashed it with CD
Sounds like your BIOS is corrupt. In general, the only recourse is to replace the CMOS IC outright. You
could remove the IC and reprogram it in a EEPROM programmer. Or you could swap it out with a
similar motherboard. Or you could contact Asus and order a replacement.
Jul 13, 2009 | ASUS P5AD2-E Deluxe Motherboard
Intel 845 gvsr no display
Intel d845 gvsr no display ,but the ram is ok when i incerted the ram there is no beep and there is no sound. may be bios corupted and how to solve the problem
Mar 09, 2008 | Intel Motherboard
Computers & Internet Logo
35 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
