Question about Konica Minolta bizhub C450 Scanner
Display Code C-E002 - Konica Minolta bizhub C450 Scanner
Error code E002
I googled: canon imagerunner 2022 copier error code e002
This appears to be the best and most informative: http://www.fortwayneprinterrepair.com/wordpress/2014/08/12/canon-ir-2200-2800-reset-fuser-error/
If not, try some of the others from the above search.
May 07, 2015 | Canon Image Runner 2022 Copier
My machine is canon NP3050 type F127500 and the problem is that, when you start up the machine, the screan show error code E002 please what can i do?
E002 is a clasic Fuser error
"E002Fuser temperature too low"
Turn OFF and ON the machine, if that dosent help you need to replace the Fuser Unit.
May 25, 2012 | Canon Office Equipment & Supplies
I have canon ir400 machine... it displayed error codes e002.. what i do? plz help me....
If the fuser assy has been repaired and you keep experiancing an E002 the problem is most likely a faulty DC Controller (main board) The DC Controller handles the voltage applied to the fuser assy and gives the error code E002 or E003. Have your tech clean & reseat connectors on the DC Controller before just replacing it. I have found cleaning the connectors & reseating them solves the problem 75% of the time.
Jan 12, 2011 | Canon imageRUNNER 400S Copier
Code error E002 for Canon NP6030
hi 1. cheq the fuser heater lamp & thermal fuse,
2. enter in the sim mod by pressing service swich located in side the front cove you can see the $ sing at the screen left upper corner then press *4* then scroll to find the error then ok macine will re start and hope your error will go
thanks
May 13, 2010 | Office Equipment & Supplies
Error code E002 cannon 6612 photocopier
this is a canon generic error code that points that the fixing/fusing heaters or sensor has a problem try to swtch off & on the unit, check the ac power supply maybe its not stable, if the problem persist.you have to call your service provider regarding this.
Jul 04, 2009 | Canon Office Equipment & Supplies
Error code e002 on canon copier np6050
Also this code needs to be cleared in service mode. Despite what the display says, turning it off and on will not reset it. To enter service mode insert a straightened paper clip into the small hole in the front cover, near the meters, a "$" sign will appear on the display. Press * 4 * in order. Press ">>" to select "error" then press "OK" then power cycle.
(I cant remember on that model but you may need to defeat the interlock on the front door in order to enter service mode.)
Jun 02, 2008 | Canon NP 6551 Black and White Copier
Cannon MF8180c - E002
Go to this link. Type "error E002" in the search window and click Search. Select the System Error E002 link and you will see some things to try to resolve the problem. If it persists, you may need to have the unit serviced.
May 22, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Konica Minolta bizhub C450 Scanner Logo
27 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
