Question about Refrigerators
The refrigerator is not cooling for more than two days
The fridge is from West Point company and we brought seven years ago. Last year was also not working in the complain The technician said that the setting of the cooling is not good .
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 48 Answers
After 2 days when it starts to warm up are you turning it off and then turning it on again later and it works? If it is working repetitively for 2 days at a time and you are having to turn it off in between then you most likely have a circulation problem. It will be either the circulation fan or the defrost element. These are both behind the rear panel. If it is working for 2 day intervals and your doing nothing inbetween then sure it may be the controls.
Posted on Jul 10, 2013
  • 3 Answers
SOURCE: Maytag (Amana) ABC2037DES Refrigerator not cooling
Your condenser coil is frozen up with condensate...need to fix the defrost system, most likely it is the control sub module.
Posted on Aug 20, 2007
SOURCE: Fridge and Freezer losing cooling
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Posted on Dec 10, 2007
eagle338
  • 4889 Answers
SOURCE: zanussi fridge freezer frostfree ZX 57/3 W not working
It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube.
Hope this helps,
Sai.
Posted on Jun 13, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Fridge is not cold freezer works fine.
Try changing the damper settings in fresh food compartment. Your refrigerator has a control board and it is possible the board is no longer working correctly. If your board is bad I can help you locate one. If the fridge is still under warranty I would have the technician come out. He would possibly just change out the board without testing to original board. Other things that could cause problems are thermistor and defrost thermostat located inside the freezer and attached to the evaporator coil. If you continue to have problems, let me know, Thanks, Sea Breeze
Posted on Mar 24, 2009
  • 18 Answers
SOURCE: Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
Posted on May 29, 2009
I want to order a box for the fruit and vegetable for my fridge which is a "Tecnik" make and I am having difficulty locating the company. My fridge/freezer was installed by "Moben...
There are plenty of websites advertising refrigerator spare parts - all you have to do is search them with the model make and number of your fridge and they will tell you if they have the part and how much - simple really.
Tecnik is in Manchester - I think they have gone bust as a subsidiary company of a larger one,
tel 0161 7864295
Aug 06, 2011 | Tecnik TKR6610 Bottom Freezer Refrigerator
Moved refrigerator to new house, power was off for a few days.The last time the power was off for a bit, a few years ago, it would not cool.Repair man came over took a handfull of snow and placed it around...
no!! ? never hear of this kind of vodo treatment :) what is your model#? and what is it doing now? is the compresor working? is the fan in the back runing?
Dec 30, 2009 | Kenmore Refrigerators
Worst refrigerator I ever owned--a lemon
I won't say I can solve your problem short of coming around and loading your POS fridge in to the back of my truck and running by the scrap metal yard. Keep contacting GE and the retailer who sold it to you about your problems. Hopefully one or the other will get sick of hearing from you and give you a replacement. A 20 cubic foot over/under fridge with ice-maker can be had for $450 US, which should last you around 10 years or so, which is pretty much typical for white goods. I have had pretty good luck with Frigidaire and Hotpoint so far. I still wish I hadn't put the 40 year old Wizard Imperial 14 cubic foot bottom mounted freezer that I bought about 23 years ago out at the curb. Given the chance, it would probably still be working today, as ugly and inefficient as it was.
Jun 17, 2009 | GE PFS22SBSSS Stainless Steel French Door...
Refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Feb 27, 2009 | Amana ABB1927DE Bottom Freezer...
Noise from the right side of thr fridge
I would suspect something has come loose, like a panel screw somewhere. When the refrigerator turns on its cooling system, it may be causing the rattling, due to vibration of whatever has come loose.
Jul 11, 2008 | Samsung RS2630SH Side by Side Refrigerator
Sub-zero Fridge not cooling and ice forming
You do have a leak and it will be in the evaporator. So call a factory authorized company and have it replaced.The warranty of a Sub Zero sealed system is full parts and labor for years 1-5 and parts only in year 6-12. Sub Zero expects a lot of their service companies so it behooves you to call one. To find an authorized company go to http://www.subzero.com/locator/locator.aspx?type=0&zip= or call 800-222-7820
May 31, 2008 | Sub-Zero 601R
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
