Brivis wombat service manual
Have a brivis 2p wombat 20 with a starting issue and was wondering if anyone would have a service manual to aid in diagnosing the issue. pilot light lights for a second then goes out... have tried cleaning flame sensor but have no idea how to test it. ac signal at gas solenoid spikes then drops out and once pilot goes out a relay can be heard clicking about 1 second after from ignition box.
Can we turn the heat off 2-3 rooms with this brivis wombat 92 gas heating system - heating just the parts of the house we choose.
You could freeze water pipes if bathrooms are connected to those rooms - on a cold winter day (depending where you are). All gas appliances should have a shutoff valve. Shutting that off may screw up the main controller - it won't get the proper signal that the flame started ok.
Aug 24, 2014 | Heating & Cooling
A new fan put in a Bravis 2P wombat 20 and now fan wont start red light flashing
either wrong fan or not plugged in correctly, was this fan new or used
Aug 25, 2013 | Cars & Trucks
Brivis wombat 2P 20
love to know how you went , i have a similar problem with the same unit.....
May 29, 2013 | Heating & Cooling
Pilot light is large and yellow on the brivis 92 wombat
blocked pilot , lack of air so it burns yellow needs blowing out with air line or can of air , or undo and clean pilot .
Jul 25, 2011 | Heating & Cooling
Brivis gas heater - Wombat 20 - fan doesnt seem to be operating at full speed
Take fan apart - easy. Clean with WD40 and then oil with 3and1
Works on all fans.
Jul 15, 2011 | Heating & Cooling
My brivis wombat 120 igniter won't work so I can't light the pilot
I have a brivis wombat 120. When room temperature is lower than required temperature, it starts to fire up and sends heating air. Now, it does start firing. If I increase the temperature testing, you can hear ant click sound from heater, but no firing. Can anyone help
Mar 26, 2011 | Heating & Cooling
Hi i have a brivis eh 30 unit that comes up with error 65 and 30 the display inside the unit says fan limp, if i reset it from the unit it works for about 1 hr then the same thing can anyone help please
Hi. Here are the error codes for your Brivis Heater. Error Codes 30 - relating to speed sensor, 40 - overheating, 65 - motor lock-out. Usually resetting the unit will resolved the issue. In your case, you already reset the unit and problem came back. This will require immediate attention by Brivis technician.
Jul 12, 2010 | Heating & Cooling
Air blowing out - Pilot on but no heat.
Possibly overheating or previously overheated, these units are also prone to control box issues usually a buzzing noise at the unit it present if this is the case.
Apr 28, 2010 | Heating & Cooling
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Heating & Cooling Logo
89 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
