Question about Cell Phones
No signal detected how to repair - Cell Phones
    New Friend:
Nokia 7230 unlock price?
Posted on Jul 10, 2013
2002 jeep grand cherokee diagnostic trouble code P 0320? how do i repair?
No Crank Reference Signal at PCM No reference signal (crank-shaft position sensor) detected during engine cranking. Use this youtube step-by-step to fix it. How to diagnose P0320 crankshaft position sensor circuit failure
May 01, 2014 | 2002 Jeep Grand Cherokee
How do I detect signal strength?
You need a signal strength meter. I remember the ones we used when I was in the TV repair business 30 years ago. I think you are going to have to find someone who installs antennas. The ones that Cable TV installers use have a very high minimum signal indicator and most antennas won't register a signal on that type.
Oct 30, 2013 | Proscan Televison & Video
Po336 crankshaft position sensor A range / performance
Trouble Code: P0134
HO2S-11 (Bank 1 Sensor 1) No Activity Detected
Trouble Code Conditions: Engine started, engine running in closed loop at a speed over 3 mph for more than 2 minutes, and the PCM detected the HO2S signal stroke rationality was more than the threshold value (0.250 volt) during the Heated Oxygen Sensor Monitor test.
Possible Causes:
HO2S signal circuit is open or shorted to ground.HO2S has deteriorated, is contaminated or has failed.PCM has failed.YOUR HO2S SENSOR IS BAD,IT COST 80.00,USE EXACT FIT PART.EASY TO REMOVE,DISCONNECT ELECTRICAL CONNECTOR,GET WRENCH AND REMOVE.5 MINUTES TO DO.Trouble Code: P0336
Crankshaft Position Sensor Performance
Trouble Code Conditions: Engine running and the PCM detected the number of CKP sensor signals counted (between the reference mark gap). did not equal the Actual number of available teeth (i.e., the CKP signals. were out or the normal window" of operation with the CMP sensor. signals okay).
Possible Causes:
CKP sensor signal circuit connections loose (intermittent fault).CKP sensor wiring harness has a connection fault (intermittent).CKP to Target Wheel "air gap" is incorrect.CKP sensor is damaged or has failed.Must remove to see.Trouble Code: P0440
EVAP System Malfunction
Trouble Code Conditions: Engine started, ECT sensor signal less than158?F at startup, IAT sensor signal more than 9.5?F, system voltage over 10.0 volts engine runtime 15-20 minutes at cruise speed, then returned to idle speed, VSS indicating 0 mph, load value 2.2 ms, canister load factor less than 4.0, fuel tank pressure less than 0.5" Hg, then after the Idle Control system and Fuel Trim had stabilized, the PCM detected a fuel vapor leak (as small as 0.040") in the EVAP system during the EVAP Leak Test.
Possible Causes:
Fuel filler cap damaged, cross-threaded or loosely installed.Small hoses or cuts present in the EVAP vapor hoses/lines.EVAP purge valve is damaged or has failed.Here you are the symptons.
Jan 17, 2013 | 1998 Kia Sephia
Is there a list for computer codes for 1980-1990's Chrysler Le Baron
Yes here is that list.
Chrysler products COMMON CODES OBD1 (vehicles made before 1995)
Part 1: Chrysler Domestic vehicles
CODES/Meaning
88 display used for start or test
11 camshaft signal or ignition signal, no reference signal during cranking
12 memory to controller has been cleared within 50-100 engine starts
13 map sensor not detecting any change during test
14 map voltage too high or too low
15 vehicle speed sensor, no signal detected
16 knock sensor circuit. open or short detected
17 low engine temperature, possible thermostat fault
21 oxygen sensor signal, neither rich or lean detected
22 coolant sensor voltage low
23 air charge voltage high/low detected
24 throttle positioner sensor voltage high/low
25 automatic idle speed motor driver circuit, short or open detected
26 injectors 1,2,3 peak current not reached
27 injector control circuit does not respond to control signal
31 purge solenoid circuit, open or short detected
32 egr solenoid circuit, open or short detected
33 a/c clutch relay circuit, open or short detected
34 speed control servo solenoid, open or short detected
35 radiator fan control relay circuit, open or short detected
36 wastegate solenoid, open or short detected
37 part throttle unlock(PTU) circuit, open or short detected
41 charging system circuit not responding to control signal
42 fuel pump or auto shutdown (ASD) relay voltage sensed at controller
43 ignition control circuit not responding
44 battery temperature voltage circuit problem
45 turbo boost limit exceeded-map sensor detects overboost
46 battery voltage too high
47 battery voltage too low
51 air/fuel at limit
52 logic module fault
53 internal controller failure
54 camshaft reference circuit not detected
55 end of message
61 baro read solenoid, open or short detected
62 emr mileage not stored
63 eeprom write denied
64 flex fuel sensor signal out of range
65 manifold tuning valve, open or short detected
66 no ccd messages
76 ballast bypass relay, open or short detected
77 speed control relay, open or short detected
May 31, 2011 | Chrysler LeBaron Cars & Trucks
Kyocera mita 5035 code 6400 c
Zero-crossing signal problem
• The main PCB does not detect the zero-crossing signal (Z CROSS SIG) for the time specified below.
Causes
Poor contact in the connector terminals. - Check the connection of connectors YC1-3 on the main PCB and YC2-6 on the power source PCB, and the continuity across the connector terminals. Repair or replace if necessary.
Defective power source PCB. - Check if the zero-crossing signal is output from YC2-6 on the power source PCB. If not, replace the power source PCB.
Defective main PCB. - Replace the main PCB if C6400 is detected while YC2-6 on the power source PCB outputs the zero-crossing signal.
Dec 18, 2010 | Kyocera Mita KM-5035 Printer
C6400 error problem of kyocera printer
C6400
Contents: Zero-crossing signal problem
• The engine PWB does not detect the zero-crossing signal for the time
specified below.
At power-on: 3 s
Others: 5 s
Causes: Poor contact in the connector terminals.
Check procedures/corrective measures: Check the connection of connectors YC7
on the engine PWB and YC2 on the power
supply PWB, and the continuity across the
necessary.
Causes: Defective power supply PWB.
Check procedures/corrective measures: Check if the zero-crossing signal is output
from YC2-11 on the power supply PWB. If
not, replace the power supply PWB.
Causes: Defective engine PWB.
Check procedures/corrective measures: Replace the engine PWB if C6400 is detected
while YC2-11 on the power supply
PWB outputs the zero-crossing signal.
Dec 17, 2010 | Kyocera FS-1118MFP Laser Printer
My kyocera km1820 displays error code c6400
specified below.
At power-on: 3 s
Others: 5 s
Causes:
- Poor contact in the connector terminals.
- Defective power supply PWB.
- Defective engine PWB.
- Check the connection of connectors YC7
necessary.
- Replace the engine PWB if C6400 is detected
Sep 24, 2010 | Kyocera Copystar CS-1820 Black and White...
No signal detected
Where the cable is plugged in, a terminal probably came loose internally. DO NOT ATTEMPT TO REPAIR THIS YOURSELF! There are very high voltages inside. Buy a new monitor or take it to a repair shop.
Jun 28, 2010 | ViewSonic VG150 15" LCD Monitor
Signal no detecting in W810i
ASH - teh phone needs to be checked take it to a mobile repair store
RACHEL + gr43m3 - the internal antenna has to be check or you can manually set the network on the phone...menu/settings/connectivity/network and manually search for the band.
Oct 02, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
