Question about Samsung PS50A410C1D 50 in. Plasma TV
2 inch wide vertical line RHS of screen - Samsung PS50A410C1D 50 in. Plasma TV
  • 579 Answers
SOURCE: 40 inch lcd blue line vertical
The display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Hope ya fix it!
Posted on Jan 06, 2008
  • 118 Answers
SOURCE: Black Vertical Lines in screen
All I can tell you is that you maybe have left your T.V. on a channel that didn't move for so long, or maybe someone else did and it burnt the screen. Plasma's run off of plasma gas to create the great picture and they collect on the screen and stick. What you need to do is go to your menu and look for "screen burn protection" and put it on white and let it sit for 20 minutes. All of one color such as white doesn't harm your T.V. The only way anything burns is like a bright white line in front of a black background.
Posted on Jan 30, 2009
roety
  • 585 Answers
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Posted on Aug 19, 2009
  • 1382 Answers
SOURCE: got black line in the middle of my 42 inch plasma screen
Perform the following tasks:
Determine if the "line" is an external cause or internal.
By external, it means a result of the interface, cabling or other boxes that are connected to the set.By internal, it means a defect within the hardware or software of the set itself.
Do find out you must disconnect everything but, say one video source. The best would be to unplug, pull everything from the back or front of the tv .By a process of elimination you should be able to convince yourself the source of the vertical line is external to the tv or internal to it.
Then, once you have decided that, you can attack the place that is most likely to be the source. For example, some of the early sets had some non-standard processors and had to be upgraged to the new standard after they were purchased by the consumer. It had to do with the HD and HDMI interface connections, but could have effected other stuff. Also, some S video inputs have glitches in them.
Posted on Aug 30, 2009
  • 113 Answers
SOURCE: I have a Samsung 52
hi,
it is time to replace the panel. the micron tube in the panel has already worn out.
Posted on May 10, 2010
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
Got white vertical lines on left side of display
Vertical lines on an LCD screen are not a good sign. This usually means that your screen is going bad.
Jul 21, 2010 | Toshiba Computers & Internet
Thin green vertical line on rhs of the screen
Likely the panel is bad. If it's not covered by your mfc warr or you did not buy an extended warr then replace the tv. the panel is more expensive to replace than a new set.
Mar 25, 2010 | Televison & Video
I have a PS42A410 Samsung that has developed a 10cm black line
Your control board needs replaced most likely. Does it work fine on a cool morning when you first turn it on, then develops the line when it warms up? Good indication it is the control board.
Feb 23, 2010 | Samsung PS42A410 42 in. HD-Ready Plasma TV
Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Nov 28, 2009 | Sony BRAVIA KDL-46V3000 Television
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Two inch wide vertical band spreads across half of screen
this is a problem is your scan section either letf or right scan boards are bad. if its under warranty take it back if not it needs to be serviced. you can probably do it yourself.
Jul 01, 2009 | Televison & Video
Samsung 52 Inch LCD 120hz. 3 inch wide vertical line on screen
This is a problem with the LCD panel. If the tv is out of warranty, I would call Samsung and see if they will pay for the panel and you pay for the labor. The panel is not cost effective to repair. If Samsung will not do anything you will need to buy a new tv.
Nov 16, 2008 | Televison & Video
Samsung PS50A410C1D 50 in. Plasma TV Logo
44 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
