Di5510 code 2304 - Office Equipment & Supplies
Error code sc36-03 ?
On what model of machine is the code showing?
Feb 15, 2015 | Konica Minolta Office Equipment & Supplies
Power off the machine. Now hold down the 2 and the 5 and power on. Mode 25 screen appears. touch the Soft switch tab in the first box on your left you will put a 3 in the middle box you will put a "1" the third box you will change the "1" to a "0". close out to original screen and power off the machine. wait 10 second power on should get your ready to copy, if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
Feb 15, 2015 | Konica Minolta Minolta Dialta Di5510 Laser...
How i change the developper of konica di5510 plus the code of it
I would recommended you get a konicaminolta tech to that it not simple in will require developer, knowing the service mode 36. Clearing counters in mode 25. Try a web site that sell the old Konica Minolta service manual. follow step by step.
Feb 04, 2015 | Konica Minolta Minolta Dialta Di5510 Laser...
Konica minolta bizhub Di5510 driver for windos 8
You can try konicaminolta web site drivers are free. But Di5510 I believe best you can do is XP or windows 95. But give the web site a try.
Sep 26, 2013 | Minolta bizhub 200 All-In-One Printer
Bios password for acer travelmate 2304 series
I need to know if your computer gives a code after entering the wrong code 3 times if so what is the code and I can then give you the correct Bios Password or you can see this post http://dogber1.blogspot.com/2009/05/table-of-reverse-engineered-bios.html
Mar 17, 2013 | Acer TravelMate 2304 Series Laptop Charger...
I have a bios password on my acer travelmate 2304 and i forgot it. can you help me reset my password?
Bizhub Di5510
SC49-01, SC49-02, or SC49-03 codes.
[Solution]
PROBABLE CAUSES:
1. Outdated firmware.
A flash ROM upgrade is available to correct this problem.
Notes:
a. See bulletin 3481A for details on this issue.
b. Make sure that the current version of system software (with applicable patches) is installed on the controller.
2. Improper shut down procedure of the controller.
Here is the correct shutdown procedure:
a. Shutdown the controller via the Di5510 control panel.
b. Turn off the sub switch (front switch) of the printer.
c. Turn off the main switch (rear switch) of the printer.
This procedure assures that the controller and printer are properly synchronized when power is applied. If the sub switch (front switch) is the only switch turned off, the Service Code will be generated the next time the printer is restarted.
Jan 03, 2008 | Office Equipment & Supplies
52 people viewed this question
jasbo
jasbo
