Vaultz cash box combination
Need to reset combination
    New Friend:
  • 3 Answers
If it's open you move the handler to the left and move the numbers to whatever combination you decide, as you finish just release the handler! Try it fist before you lock it! Good luck!
Posted on Jul 16, 2013
Sentry. How can I reset combination?
You can't. You bought a paperweight ?? The whole idea of having a safe is that it is secure. If there was some magical way to reset the combination you could do that with all the safes that have 10 grand in cash and the family he wells in them.
The only way is to take it to a locksmith and they will drill the door, open it and fit a new one. You can imagine the cost of that.
Get your money back if you can't get the combination from the seller. My bet is that they sold it to you because I gave them this information a couple of weeks ago.
Nov 18, 2015 | Home Security
I need to reset the combination to the safe.
contact the safe company,only they can help you
Jun 29, 2015 | Office Equipment & Supplies
How to reset combination
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
the door and conceal your combination
7. Close the shutter door
Sep 03, 2014 | Master Lock 5400d: Portable Select Access...
How reset combination lock
1. Open the lock with the factory preset combination of 0005.
2. Find the tab on the end of the part of the locking mechanism that has the numbers.
Combination Reset Tab
3. Flip the tab up (with the combination set to the open combination). When you flip the tab up, you disengage the number dials from the tumblers, so that you can reset the combination without changing the position of the tumblers.
4. Change the combination to the desired combination.
5. Flip the tab back down. The dials are now re-engaged with the tumblers.
Aug 13, 2014 | OnGuard Doberman Series Lock 8030
Unlock pacsafe 100 have forgotten code
How do I reset the combination?
Instructions are included with every combination lock, however if you have lost them, please refer to our instructions which can be downloaded at the respective product page. If you have set the combination once, you will need to remember this combination when resetting again (i.e. replace the 0-0-0 in the instructions with the combination you chose).
Apr 09, 2013 | Pacsafe Daysafe 100 Travel Backpack in...
Forgot my Presto Lock combination!
You cannot reset the lock unless you know the combination. You would need someone to pick the lock, like a locksmith and then once it's open you can reset the lock with a new combination.
Jan 25, 2013 | Locks & Locksmithing
Is it possible to reset a Manifoil MkIV combination lock without having to send it away to a specialist?
Hi, by reset, do you mean you have the combination but want to change it?
If so, then you need the special combination change key that came with the safe and the instruction manual (there are copies of the manual online if you don't have that)
If the door is open, but you don't have the combination, there is a technique for finding the combination.
amania_r@hotmail.com
Jan 06, 2011 | Office Equipment & Supplies
How to reset the combination, GE Hide a Key Storage Lock Box (GE Access Point Series)
Step 1. With the cap closed, set the numbered dials to the combination line. The factory preset combination is "000".
Step 2. While maintaining the combination in place, rotate the "RESET" dial indicator beneath the letters approximately 90 degrees to line-up with the combination line. If the correct combination is not set, the "RESET" dial will not rotate.
Note: Using excessive force can damage the dials.
Step 3. Set the new combination while maintaining the position of the "RESET" dial.
Step 4. While maintaining the combination in place, rotate the "RESET" dial back to the original position. The combination has been changed.
Sep 07, 2010 | GE Home Security
Just bought a sentry digital safe at an estate auction. did not have a manual with it. do not have combination. how do i reset combination.
If you need your lost combination, you must send a notarized letter stating you are the owner of the safe. The link below will tell you everything that you will need to get your combination:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Jun 11, 2010 | Sentry Fireproof Safe
Need to open a Sentry keyless combination safe
First, has the factory combination been changed? Sentry has the code for the factory combination that they can supply you.
If the factory combination has been changed to something else, then Sentry won't have it.
In that case you need to ask Sentry for a 'reset' code combination. There is (at least) one back door to your safe -- a reset code.
The reset code will not tell you what your combination is, it will simply reset the combination to the factory combination.
You can take it from there.
Now, this isn't as hard as it may sound. There is an actual department that handles this at Sentry because you aren't the only one that cannot open his safe.
They'll want some proof of ownership, some $$ for the service, the safe serial number, and probably a notarized form claiming that the safe is yours.
Get 'hold of Sentry on the web and the rest is just process.
BTW -- this is exactly what the locksmith would do.
Apr 10, 2009 | Sentry Fireproof Safe
890 people viewed this question
k24674
jasbo
jasbo
