Operating Manuals For Kverneland bale wrapper 7558
2 Suggested Answers
  • 5159 Answers
SOURCE: Looking for a manual for
The manual is available here: http://media.tanco.ie/media/manuals/manuals/500-550-580/Old%20Machines/450s.550s%20&%20550a.%20%201996.pdf . Another copy is here: http://media.tanco.ie/media/manuals/manuals/500-550-580/Old%20Machines/450s%20&%20550S.%201995.pdf . The second version was easier for me to read; however I didn't check all of the diagrams for clarity.
I hope this helps.
Posted on Jun 01, 2011
690 honda engine won t charge battery. battery tests good. what do we try next?
check the stator to see if any AC output. If so then check the regulator input. All wires should be yellow, however, some manufacturers use a different color. Also, hook up a meter to the battery with the engine running and your voltage should be in the 14 to 15volt range.
Oct 21, 2017 | Honda Motorcycles
Bale wrapper parts
We do not sell parts or have allocator service to find them.
Jul 20, 2017 | Garden
New Holland 72 bale thrower will not increase or decrease speed on belts.
From what I've discovered there's a lot of issues a hand---I found a site that has different issues with model---variety of various items contribute to the same problem----you'll have to find you particular issue--there a list of items that may apply to you situation that you'll have to check out---GL
https://www.google.com/search?q=New+Holland+72+bale+thrower&rlz=1C1NHXL_enUS713US714&oq=New+Holland+72+bale+thrower&aqs=chrome..69i57j0l3.2071j0j9&sourceid=chrome&ie=UTF-8#q=control+speed+of+belt+New+Holland+72+bale+thrower
Jul 05, 2017 | Cars & Trucks
Which one you prefer for native installers or wrappers?
Great question. I've used wrappers a lot these days because of the ease of use. Simple take your file give to a rep and good to go. If you do a silent 'carrier' install (by carrier i mean the actual software the user was looking for - your actual product), then its seemless. I think that the best method for take rates is always the 'unknown' method. Once stuff gets saturated you gotta switch it. So classic INNO looks are common, and if they are distributing a lot of PPI then you want to move to a wrapper that 'looks different' or is customized to your software. Over time if this same styles of wrappers get notice more. . then its time to switch them or perhaps go back to an old look that is now not remembered as offers.
Ultimately the right answer to this question is 'hard work'. Create em both, run some splits. . . take the winner.
3w0lp4ibwiox3pza-1-0.jpg">
http://ppitalk.com/
Dec 02, 2015 | Computers & Internet
The shear pins on the rake keep breaking on a 853 NEW HOLLAND ROUND BALER. What is ?
Do you mean the driveline protection shear pin (pickup, roll the bale and wrap it) or the overfill protection shear pin?
For the driveline shear pin, check the type of pickup that you have. Make sure that you have the correct shear pin for the pickup (wide or regular). Also check the year of your baler, there are substitute shear bolts available that do not work on a range of the 853 baler. New Holland has a parts list for the baler on their site. Start at http://partstore.agriculture.newholland.com/us/ and use the Look up parts by equipment on the left of the page or see your manual. Next check the air bag pressure. (Make sure that you are in the operating range with a regular pressure gauge. It's possible for the gauge on the baler to read low.) If the pressure is out of the operating range, the roller bars can hit other parts of the baler and cause the shear pin to break.
If your baler uses net wrap, make sure that the wrap isn't caught in the unit. (If the knife doesn't cut the net wrap, it will get caught in the tailgate and the rest of the baler. If it tears in use, it may wrap around the pickup and cause the shear pin to break.) This may apply to twine as well but I do not have experience with it happening with the twine tied 853 baler.)
For the rest of the checks, you will have to remove any bale that is in the baler. If it is large enough it may roll out even if it isn't wrapped when the tailgate is up (try driving up hill). Otherwise, you need to pull, cut or pry the bale out. Standing on the kicker can help the bale roll out if sufficient weight is added. We've found that a spare bale spear works well. Removing the hay in small sections can also work.
What is the moisture of the bale? If the bale is too wet, it will be too heavy and shear the pin before the bale chamber is full.
Next check all of the roller bars in the unit. If any are bent significantly, that one can hit another part of the baler and break the shear pin. It's possible to straighten some of the bars out depending on the damage. If the bar is S-shaped or severely bent, replace it. (Your New Holland parts store may have someone who will demonstrate the technique for bar straightening. It involves hammering the bar straight when it is securely held in a vise. If you can hold the bar safely, I've also seen a bucket on a front-loader straighten the bars.) If a rock gets past the windrow guard, the bars can get bent.
Check that the chains are centered and that none of the gears are shifted to narrow or wider paths in a spot. (There are bars that can be adjusted between two sets of gears near the top front of the baler. Loosen the four bolts and push the parts closer or pull them farther apart.) Check that none of the bearings for the apron motion are frozen or damaged. Replace or repair anything that is damaged.
Do not make the bales too large or uneven. (If you have a Bale Command unit on the baler, it is easier to control the even formation of the bale.)
For the overfill protection, make sure to reset the unit after replacing the shear pin. It can be tough to pull the trip arm fully back. Make sure that nothing is in the tailgate. If your baler has a kicker, make sure that that the two springs on the sides are undamaged and holding the kicker level.
I hope this helps.
(my 853 baler with the wide pickup uses Driveline shear pin 46520 and Overfill shear pin 46047. I'm not sure of the year of the unit. When we got shear pins with a different number, we broke 3 or 4 in a row before realizing that we'd gotten the wrong ones; they were noticably thinner than the required ones. Roller bars are what I call the bars between the chains and we've replaced/straightened many of them.)
Aug 09, 2011 | Computers & Internet
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
