Question about EdgeStar Carbon Filter For EAC211TS
Beeping and pump stops working
My Edgestar EAC211TSOB makes a beeping sound and turns off the water pump. The water reservoir is filled and the fan works. So does all other functions including the remote control. What could it be?
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: edgestar twr125 9 bottle wine cooler cooler
Yes, I would agree with you...
Is there a NO and a NC contact on the thermostat??? amybe somehow the wires got placed on the wrong terminal...that would make things work backwards...
There also could be that possibility on the logic board also... check the wiring for the possibility that the wires are crossed up somewhere...
heatman101
Posted on Oct 07, 2010
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
My air innovations keeps on beeping when the reservoir is filled
Hello... this humidifier uses timer? then, some humidity has damaged the circuitry. Try to disassemble as far as your skills permit; then put the unit outside of home in a place where the sun and wind can dry this device. And try to use destiled water if is not expensive in your area.
Aug 10, 2014 | Air Innovations Ultrasonic Digital...
Edgestar ip211ss water valve level problems
This unit will pump water into the upper reservoir and at that point it should start the compressor and make ice , if it countinues to fill the upper and flow into the lower than your water level device is not registering .
May 24, 2014 | EdgeStar Portable Stainless Steel Clear...
Our fridge is beeping randomly. Why? Can't find a reason and sometimes it stops other times won't stop. It's a beeping a bell sound. HELP please!!!!
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 23, 2011 | Kenmore Elite 78722 78729 Bottom Freezer...
2001 Beetle GLS 2.0 Overheating- Two weeks ago the car was overheating quickly, red temperature light flashing and beeping. I changed the thermostat, flushed the radiator and filled it with new fluid. As...
It is possible that the pump failed because of an overheating problem. Make sure the fans run by turning on the air conditioning. They should operate as soon as it is turned on. Bad fans are a common problem. The pump should not have been leaking after replacement though. Make sure you have no leaks first and foremost. Then make sure the fans work. There is also a fan control module located in the area under the battery, but it is difficult to properly diagnose. If the fans do not turn on with the a/c, you can jump the wires at the thermo switch. One should be power, and when you jump to one wire they should go to low speed, the other high.
If you like you can ask more questions directly, I was a VW master tech from 2000 to 2008.
Feb 04, 2011 | 2001 Volkswagen Beetle
The washer keeps beeping and trying to drain as soon as it is turned on
I have a Haier HDP18PA with the same problem... I tried tilting mine backwards while running...this made a mess BUT the beeping stopped BUT the lights were still flashing. Turned it off and started it again and the lights still were flashing BUT no beeping. Decided to try tilting it forward while running ... made another mess BUT the lights stopped flashing. Turned it off again and restarted it and it is now running fine. Good luck!
May 05, 2008 | Haier HDP18PA Stainless Steel...
GLW10US won't do anything but beep
well i don't have any experience with this brand but i would say you need to change the fill switch it senses how much water is in the tub shuts the water off then starts the washer its also called the pressure switch
Feb 16, 2008 | Washing Machines
EdgeStar Carbon Filter For EAC211TS Logo
44 people viewed this question
Top EdgeStar Heating & Cooling Experts
Donni Steen
John Tripp
John Tripp
James Coghill
Are you an EdgeStar Heating and Cooling Expert? Answer questions, earn points and help others
