Question about EdgeStar Carbon Filter For EAC211TS
Edgestar eac211ts beeping
The unit will beep and the water pump turns off even if it has water in the reservoir. Thanks.
2 Suggested Answers
SOURCE: Add Water issue on Edgestar icemaker
This also applies to the Igloo ICE102.
There is a sensor at the water outlet which fills the ice-making trough, which appears to be poorly assembled. The fix is quite easy.
Remove the rear cover by removing six screws located underneath the unit at the back and sides. Keep the ice-maker upright at all times, per user instructions.
Once you have gently pried the back cover off, remove the top cover and hinged lid by removing two screws on each side, located underneath the top rim.
With the top off, you can see the water outlet at the back left side. Above the inlet is the offending sensor, which has a metal prong angled down. This prong must touch the water stream to detect the flow, but is probably too high. You can check this by filling the unit with water and turning it on. Watch the water as it fills the trough. With the tip of a screwdriver, bend the metal tip down so that it touches the water stream. Run the unit for a while to test.
If everything is ok, then reassemble and enjoy!
Thanks to jimbo from Tampa who provided the hint for this fix.
Posted on Dec 31, 2010
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Unit turns on. no water comes through but beeps as though brewing is finished.
The water line could be broke or clogged and putting the hot water back into the reservoir.
Nov 15, 2015 | Cuisinart DCC-1200 Coffee Maker
My air innovations keeps on beeping when the reservoir is filled
Hello... this humidifier uses timer? then, some humidity has damaged the circuitry. Try to disassemble as far as your skills permit; then put the unit outside of home in a place where the sun and wind can dry this device. And try to use destiled water if is not expensive in your area.
Aug 10, 2014 | Air Innovations Ultrasonic Digital...
Edgestar ip211ss water valve level problems
This unit will pump water into the upper reservoir and at that point it should start the compressor and make ice , if it countinues to fill the upper and flow into the lower than your water level device is not registering .
May 24, 2014 | EdgeStar Portable Stainless Steel Clear...
Aquarius TCL780 keeps beeping
your pump may not be working then it beeps
Dec 09, 2013 | Washing Machines
Climate control panel unit
if voltage to board bad board
Apr 15, 2017 | EdgeStar Heating & Cooling
Edgestar DWP60ES prematurely ending wash cycle, will not drain properly, beeps alot
most likely the dishwasher has a minor leak in the base under the wash sump. this could be tripping the flood switch which causes the pump to run continuously. when the leak dries up you are able to start normally until the leak trips the flood switch once again.
Check for leaky door seal or hose. see edgestar site for instructions on getting to the area under the sump. make sure dishwasher is disconnected from mains when working on it.
Jul 25, 2012 | Dishwashers
Jul 13, 2010 | EdgeStar Titanium Portable Ice Maker
The washer keeps beeping and trying to drain as soon as it is turned on
I have a Haier HDP18PA with the same problem... I tried tilting mine backwards while running...this made a mess BUT the beeping stopped BUT the lights were still flashing. Turned it off and started it again and the lights still were flashing BUT no beeping. Decided to try tilting it forward while running ... made another mess BUT the lights stopped flashing. Turned it off again and restarted it and it is now running fine. Good luck!
May 05, 2008 | Haier HDP18PA Stainless Steel...
Edgestar AP550Z won't heat, goes into some sort of alert mode
http://edgestar.com/ownersmanuals/AP550Z_wire-fix.pdf
This could apply to at least one of your units. Apparently these models have had some trouble with the compressor capacitor wires coming loose. If they're barely touching they could cause the compressor to run intermittently and possibly overheat. The compressor runs in heating and cooling mode.
Dec 04, 2007 | EdgeStar Portable Air Conditioner Heater
EdgeStar Carbon Filter For EAC211TS Logo
104 people viewed this question
Top EdgeStar Heating & Cooling Experts
John Tripp
John Tripp
Gene Tuck
gbob59
Are you an EdgeStar Heating and Cooling Expert? Answer questions, earn points and help others
