Question about Ovens
Simpson la scala oven
Model 3W601S#02 Power went off and need to know how to set clock and take it off Automatic. No manuel held
SOURCE: Can not set clock on Simpson La Stella oven
How do i set the time on a Simpson La Scala wal oven
Posted on Dec 07, 2009
SOURCE: Kleenmaid Scala Oven. My oven will not turn on.
I had exactly the same problem. I followed the directions to reset the clock. That is the cooking button and finish cooking button. They look like a caserole dish and a casserole dish with a cross through it. Hold them down at the same time and the + and - button to advance the time. Be aware I had to try this a few times before it worked. Hope this helps, Dean
Posted on May 14, 2010
  • 250 Answers
SOURCE: Simpson Apollo can't set clock so oven won't work
I don't know if this will help. For the 720ef , this is what you need to do.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Posted on May 29, 2010
rickead1
  • 1998 Answers
SOURCE: cannot set the time on
if you are unable to set the time first try unplugging the unit for 7 minutes this causes the control to reset if after you replug the unit in you still have are unable to set the clock you can if you are electically inclined replace either the touchpad or the erc depending on which one has the fault on some models the erc (electronic control) has the touch pad built into the erc and you would order one piece whereas other units this is a two piece control and you would have to distinguish between which is the fault part if you have any further questions message me back I await your reply Thanks
Rick
Posted on Apr 03, 2011
  • 5370 Answers
SOURCE: How do you set the
You press and hold "cook" and "stop" then - or + to set the clock. Also click this link for more details:---- http://technoanswers.blogspot.com/2011/04/how-to-set-clock-on-simpson-oven.html --------- Check out.Keep updated.Thanks.Helpmech.
Posted on Apr 06, 2011
I want to remove the oven door for cleaning but not sure how.
Try opening the door about 6" (15 cm) and pull straight up.
May 08, 2017 | Ovens
I AM GETTING GAS TO MY STOVE TOP,BUT NOT MY OVEN. I HAVE A CROSLEY OVEN. I MOVED IT ABOUT A MONTH OR SO AGO TO INSTALL A FLOOR. ANY IDEAS?
yes, check your timer or clock if the clock is set on automatic it will not work, needs to be on manuel. or it may need the oven ignitor, its berry sensitive its the part nest to the oven burner on the back.
Jul 12, 2011 | Amana Ovens
Correct wattage bulb in Simpson La Scala electric oven.
if you are refering to the light inside the oven, I dont think there is a problem with wattage as the oven is rates to high wattage
and it is also inside the oven, so in an area that can cope with heat.
if possible check remove the old bulb and check the wattage on the glass or on the side of the fitting.
I personally would recommend that a 40W should be suitable.
I hope this was useful
May 23, 2011 | Ovens
How do i reset the time clock on a simpson evolution 912
Can you add a full model number? I am having trouble finding the manual from the information given. From other oven manuals from simpson, it sounds like the clock is programmable when power is first supplied, so unplug the unit, wait a few minutes, and plug it back in. Then press the - and + buttons to set the time. 5 seconds after the last change the time will be set.
Oct 03, 2010 | Ovens
Apr 30, 2010 | Stoves 720EF Electric Double Oven
Jun 30, 2009 | Electrolux Ovens
Cannot set the time on kleenmaid scala oven
My kleenmaid scala oven clock will not set and I can't turn oven on. I have re set the power etc. Do I need a repair man?
May 14, 2009 | Ovens
Kleenmaid Scala wall oven and grill
manual available at www.kleenmaid.com/care
Jan 17, 2009 | Ovens
Electric stoves
if the model has a digital clock and when the power went of it may have fried the little computor.if you dont have trip switchs in fuse box
Nov 07, 2008 | GE JGRP17 Gas Single Oven
Ovens Logo
79 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
