Question about Refrigerators
LG refrigerator noise sound.
I bought new LG Fridge(GL-205KL5/2012 model) 6 months back. It gives buzzy noice from key hole up to 1 min when ever i close the door. Recently i observed and listen the water gurgling sound (once i open and close the door) from back after plug in after 24hrs(which my unit power was off by 24hrs). What is the problem for the sound and how should i fix this?
  • Refrigerators Master
  • 15,557 Answers
This is under warranty call for repairs.
Posted on Jul 10, 2013
  • 184 Answers
SOURCE: LG Fridge making intermittent sound - like something hitting fan
GAIN ACCESS TO THE FAN IN THE FREEZER(EASIER SAID THAN DONE) AND INSPECT THE FAN BLADE AND FAN SHROUD. HAVE REFRIGERATOR TURNED OFF AND MANUALLY ADVANCE FAN BLADE. WATCH FOR SLIGHT CONTACT BETWEEN THE FAN BLADE AND OTHER OBJECTS NEAR IT-ELECTRICAL WIRING, FAN SHROUD, ICE CYCLE,ETC. ADJUST FAN BLADE OR OBJECT TO INCREASE CLEARANCE.
Posted on Mar 27, 2008
  • 1462 Answers
SOURCE: gurgling noise
gurgling noises are not unusual - after all there is a gas/liquid mixture being circulated
Posted on Sep 04, 2008
SOURCE: Right Door is making loud popping noise
replace the door cam assy. and door stop.
Posted on Nov 05, 2008
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Posted on Dec 25, 2008
  • 5 Answers
SOURCE: gurgling noise for about 5 seconds when closing
See tis for sources of noise:
http://www.applianceaid.com/images/fridgenoises.JPG
Posted on Feb 16, 2010
Have an LG fridge about 10 years old... makes a loud buzzing noise occasionally. Fridge seem to be running fine.. Thoughts??
Dear Sir
I think this abnormal buzzing sound coming from you
Compressor inside thats creating the buzzi sounds its normal. After a long time used it can possible. Neednt to worry
Hope answer the question
Jul 19, 2016 | LG Refrigerators
I'm getting frost and ice build up on the bottom and back of the fridge compartment on my LG French door fridge.
To me This is on all Makes and models build up of frost means warmer humid air is entering into colder air this will cause a frost build up from entrance of warm air coming in so your looking at your air flow in all compartments of your ref,freezer so on.
blocked air will give false readings to sensors when compartment is asking for lower temp colder temp will be noticed.
bad or obstructed door seals door not closing properly
Follow your frost line it will point the way.
Jul 21, 2015 | LG Refrigerators
Water is leaking inside the fridge on the one side. Then fridge starts making a noise when closed. Stops when you opeb the door.
has your fridge got a water drain hole at the bottom/back? if so, it might be blocked.
Sep 08, 2014 | Refrigerators
LG LMX28988ST freezer at 30 degrees
What it the reason that my fridge is freezing my food. The temp. IS set to 37 F. Why
Mar 14, 2012 | LG LMX28988 (27.5 cu. ft.) Bottom Freezer...
I bought an LG fridge, initially it worked well
U go in firmly demmanding the manager and tell him u want a new refridgerator cause the one u sold me is junk
Oct 31, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Fridge is cold but always runs.
CHECK THE DOOR GASKETS ON THE FREEZER AND FRIG.,IT SOUNDS LIKE THERE IS A AIR LEAK SOMEWHERE,LET ME KNOW-MIKE
Nov 01, 2008 | Refrigerators
Brand new refrigerator not cooling
ok what he was trying to say is that the freezer does all the cooling for both sides as nothing in the fride side cools and in order for the fridge to reach its proper temp the freezer should run any where between -0 to-10 then the fan in the freezer draw-es air from the fridge and cools it and circulates to the fridge now i need to know a few things is the compressor running is the freezer fan running do you see any frost on the back wall of the freezer section is the fan running in the back that's near the compressor to cool the condenser coils then i can better advise pleas hold my rating till we are done where did you purchase the unit
Jul 22, 2008 | LG LRTBC1825T Top Freezer Refrigerator
Problem with GL-T 242 QM LG Fridge
Pull out the freezer and ckeck for ice build up on the back. Unplug and defrost the freezer for 3-4 hours - leave the freezer door open. There may be ice covering the vents to the fridge.
Apr 28, 2008 | LG LRBN22514ST Bottom Freezer Refrigerator
Samsung Side by Side Refrigerator RS2556SH - Making loud noise
Hi, had the same problem with my RS21DCNS engineer came and made a modification to drain hole (made the hole bigger!) this allows for a little more ice to form without causing the horrid noise. A new backplate was ordered as all new models have a larger hole in the backplate already. It only takes a few mins and it under guarantee if you bought less than 2 yrs ago, but you will have to empty fridge side to allow them to get to inside at the back. Good luck.
Sep 17, 2006 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
